i've been messing with zs now for about 10 years...since i got my first one at 17. story started with an 81zxt which i wrecked. i had a friend with a 73 with a blown motor...i picked up the shell for a few hundred dollars and swapped the motor in. i drove that for a few years as it would allow, and finally parked and started working on it in jan 06. i had been working on it off and on for the last 4 years, i think it drug out so long because there was so much wrong with it. it had been rear ended at some point and it rippled the back floor, stolen (while i had it) and then lit on fire, FD crushed the firewall prying the hood open. every part of the undercarrage had been used as a jack point, PO installed flares, but cut the inner and outer fender apart, it was cut too far and used some tar paper to fill the gap. sometimes i would just stare and it to form a plan of attack on some of the parts...i have some nice parts and i want the whole package to be equally as nice...and i didn't think that chassis would give it to me. i came across an ad on CL for 72 parts..i thought i'd snag some to repair my z. well it ends up the kid bought the car to drift..it had rust..and he couldn't weld...so i picked it up for $240. it had good glass, a nice interior, a hatch full of extra parts, and the rust was just in all the "normal" areas. i dropped all the parts off the 73 and scrapped the shell, minues a few parts id use for patches on the new z, and the roof and couple other little parts i gave to proxlamus. most of that time down was spent fixing parts that will easily swap into the 72.
the z is running a l28et, bored .080 over and forged
SDS6f with coil packs for fuel and spark
powdercoated underneath with GC coilover, sectioned tubes with MR2 front struts and TTT camber plates.
low pressure pump into a hand built surge tank and walbro feeding the engine. all SS braided line.
no more fuel cell, PITA to lift the hatch and fill. surge tank will work with the stock tank..i'm keepin it this time.
holset hx35 turbo (will prob change)
and offcourse all the little pieces required to make it all work
SVT 42lb hr injectors
greddy boost controller
autometer gauges
z32 trans adapter (need z32 tranny!)
pallnet fuel rail
aeromotive FPR
AN fittings throughout
i'm pulling everything out of the engine bay, i will be repainting it the original 918 orange...engine bay will be a single stage
i will be beefing these up anyway.
battery tray was good on the 73...saved it to patch this.
old z, i know some people will think i'm crazy...but this one is honestly in much better condition. i don't have to deal with PO fixes.
i got some new rear quarters from a 260z, i will use parts from that to patch this area, it's literally the side of the car since the panel was cut on the inside up through the wheel well...that area was rust free on the 260z..im doing both sides.
rear suspension
the seams at the rear roll pan had rust, as did the orignal quarter fender lips. as i cut the lips off i saw rust up inside...it appears this car was not dipped after assembly. so i blasted the area clean and por15 it all, also applied weld through primer where i will be reattaching the quarter.
i will be welding to the inner panel so it will go out straight to meet the outer fender where i will attach the fiberglass flares.
same with the rear roll pan area..this had some surface rust...blasted and por15ed
4x4 stance
the parts that are going in. i will be putting in camber plates. i used the top hats to mount them on the 73 so i could roll it.
for now i will be putting in a lot of my time to get all my parts back in and car solid. theres not much money for the z now,but i did manage to get all the parts i needed over the last few years to pretty much complete the build.
