auxilary
Everything posted by auxilary
  1. http://cgi.ebay.com/ebaymotors/Custom-Built-Coyote-3-on-Fiero-Chassis_W0QQitemZ4579600123QQcategoryZ6737QQrdZ1QQcmdZViewItem
  2. Since we have so many newbies asking so many questions, I wrote up this faq with links and pics (most from my own conversions) for hybridz. Please feel free to correct any info and add your own. jmortensen's FAQ is also listed in the FAQ section of the forum here Mods, please STICKY this: Front Brake upgrade options: Toyota 4 piston bolt on conversion Description: direct swap, only modifications needed are to trim the dust plate and bend brake lines. MSA offers this as an overpriced kit here trimmed backing plate Parts needed: -a pair of calipers from a 79-84 toyota 4x4 pickup with S12 stamping on the side. Napa carries these rebuilt units for about $50-60/each. -good pads. EBC, Hawk, or Porterfields -recommended, but not required: a 15/16 master cylinder, SS brake lines, and new rotors Toyota 4 piston vented swap Description: wider toyota 4x4 calipers using 300zx vented rotors. You can buy the whole setup from Ross C. at http://www.modern-motorsports.com, or at Motorsport Auto. Both offer the exact same thing (spacer, calipers, bolts, rotors. MSA offers crossdrilled rotors in their more expensive package comparison of new vented rotor set caliper vs. stock caliper on the right Parts needed: -pair of '86-95 Toyota 4x4 or 86-91 4runner calipers stamped S12/W on the side '86 toyota 4x4 pickup 94 toyota 4x4 pickup this is the caliper shown for the 89 4runner v6: -new pads -pair of '84 300zx non-turbo front rotors (4 lug, http://www.buyautoparts.com has them for under 50/ea) -machined spacer to correctly move the hub from the rotor for wheel clearance and matching bolts (see pic above). You can buy these spacers separately from Ross at Modern Motorsports following the link specified above. -15/16 master cylinder from a '79 280zx (it will have 15/16 stamped on it) and SS brake lines. Also get some ready make hard brake lines in 3/16mm pitch at 6" long. Pictured above is my brake swap, and you will need to make sure that your wheels will clear the swap. I had 15" Snowflake 280zx wheels, and they would not clear the caliper because of the width. 13" Cobra kit description: Ford Cobra 13" brake setup adapted to an S30 chassis. Requires 17" wheels for clearance. Kit sold at Modern Motorsports Arizona Z car kit Description: Arizona Z car makes a complete conversion kit using Wilwood 4 piston calipers and curved vane rotors. Recommended racing use only. This kit features 4 to 5 lug conversion, new aluminum front hubs with bearings. There are also optional 13" brake kits with SIX piston calipers. Their products are listed here: www.arizonazcar.com Rear brakes: Maxima bracket/280zx caliper swap Description: Using '85-'88 maxima rear caliper brackets, 280zx rear calipers and rotors to convert rear to disk. Source of parts would be mainly junkyard, and you would have to either remove the stub axle (don't do it unless you absolutely have to) or cut out the drum backing plates to install. The downside is sourcing your own caliper brackets at the JY, and then REMOVING them. You will likely need cordless power tools to do so. Motorsport auto sells their bracket swap kit, which is CNC'd maxima brackets here. It is $320, and does not include rotors, pads, and calipers. You have to source your own. MM bracket/240SX caliper swap Description: Using '90-94 Nissan 240sx (S13) rear calipers, '84 300zx non-turbo rear rotors, and Modern Motorsports rear bracket to convert rear drums to disks. You can make your own adapters for the brake lines, or buy a set from MM here MSA rear disk conversion Description: Motor Sport Auto offers this *cough* moderately *cough* priced conversion that includes rotors, 280zx calipers, and all necessary hardware to convert rear to disk. Sean73's maxima bracket and caliper conversion Other rear disk swaps: Modern Motorsports 13" rear disk conversion Arizonazcar.com 4 piston rear disk swap
  3. His name wouldn't be Mac, and he wouldn't happen to own Irvington Arms, would he? lol
  4. haha yeah, they even mention on3go in the first link!
  5. Evangelical Scientists Refute Gravity With New 'Intelligent Falling' Theory
  6. oh yeah? http://moon.google.com/ and zoom all the way in.
  7. my friend has a tanfoglio witness 9mm. that gun sucks, lol
  8. http://ag.ca.gov/firearms/ anything that is centerfire rifle, has a pistol grip and more than 10 round detachable magazine = assault rifle
  9. Yeap. Every one of those is illegal in California here are mine:
  10. you guys do realize that neons just got cancelled, right? They're being replaced by Dodge Caliber, and the srt4 is no more.
  11. you can go to the photo album section of hybridZ and upload the pictures. then right click on picture after upload on hybridz album, select 'properties' and copy the URL (the internet address for it, starts with http://) then in your post, put in
  12. The shop owner said it was filipino made, he said. Pricing was $370 or so, I forgot to ask if they were new or used, they looked almost new. He said they were very nice, good slide pull (i checked'em out), but he said the machining on some internals was a bit rough. Anyone have any personal experience/thoughts?
  13. auxilary
    Eye Trick
    i think you got it wrong. you have to back away frm the screen, then it gets easier to read
  14. auxilary
    On3go
    mike drives a small yellow BUS. a SHORT YELLOW BUS
  15. no. that's only true for a breathalyzer. If you deny it, you will be taken to jail to have a blood test done. If they ask to search your car, you can deny it. However, then the officer can simply use 'probable cause' to search your vehicle.
  16. yeah, like Dennis Miller said about Lebanon... "It's the few rotten millions that spoil it for the other 11"
  17. http://www.otbackup.net/files/AdriaBmwDriftCrash.mpg
  18. uh yeah, you just need to check the proper forum: http://forums.hybridz.org/showthread.php?t=103237
  19. 16ga steel for floorpans. I'd advise getting the parts from zedd findings... save you the hassle of measuring, cutting, and scratching your head
  20. i'd say 2400lb curb. you can trim .5 inches off, but like john said, you can't tell until you drive it hard. if you feel the car jounce a little on a turn and the body bounces back up, trim the bump stop
