RB26powered74zcar
Super Moderators
    23
Everything posted by RB26powered74zcar
  1. Turned out real nice. I really like how it looks, clean and simple... just like it came that way from day 1.
  2. Do you need: diff input stub shafts u joint / CV 1/2 shafts companion flanges for stub axles ??
  3. Long as the det did not collapse a ring land (I doubt it from the looks of that hint of det) you should be fine using those for that mentioned re fresh....
  4. The condition on this center valance is a 9.5 out of a 10 ..... PM me your best offer.
  5. I will take some for you tomorrow in the a.m., if that will work for you....
  6. I might be interested in buying that orange mount from you. PM me if you want to sell it.... thanks - joel
  7. Looking good on the engine bay spray. Don't forget to spray the engine side of the pan bolted under the radiator/sway bar...
  8. I have all 3 pieces. Please put your location so I know where I'm dealing with (it's part of the rules here).
  9. Showing pictures of the diff will get you the best responses....
  10. Get used to it (sad to say). We are on the fast train now in this "once" great country, to where getting a good USA made quality tool is almost impossible any more....
  11. This is re dyck useless.... Come on guy's......
  12. I think it depends on what look you are after. If you just change out the clock, it tends to stick out with a different gauge placed in it's place. I went this route with the Innovate WB with the XD-16 gauge over the steering column....
  13. Great, thanks!! Looks like I'll be ok getting the Mobil 1 15w50w. That one has the highest zinc levels...
  14. Thank You for that info also. I will pick me up some Mobil 1 20W50 V twin oil asap...
  15. I'll turn you on to my secret eBay contact stash EBAY PH# 800-701-EBAY (800-701-3229) Edit: Sorry, I miss read your request. I'll try to find a email...
  16. Derek, did I miss the size of gauge this will be for posted already? If so, sorry.... I would really like it if a 2 5/8 option was available.
  17. Same here Tim. Only this one, and had it since '90
  18. Put up a designated section titled " All Newbie Questions HERE ". This way, new comers have a place to start at, and make it a no bashing zone... Edit: Never mind.... there is a section
  19. Agreed!! That is the best/correct way to loosen them back up. But, if you want a quick fix, w/o pulling the carbs, try the spring method...
