RB26powered74zcar
Super Moderators
    23
Everything posted by RB26powered74zcar
  1. When I had SU's, I went to the hardware store and purchased myself two tiny, long springs, and hooked them to the Phillips head screw holding the jet nozzle, then pulled them up and attached the other end some where above to have tension when choke lever is pulled. Iit should spring them back up all the way. Just play with that till you get it adjusted right.... it will work!!!
  2. Nice job!! I wish I could get the enthusiasm back I once had, (like you now have). I went thru many of the same things when I changed out the color from it's orig. blue, to the current red... It's a job to pull every part and panel when changing the color. I commend you on doing the paint yourself... it turned out nice!
  3. I have one but it's still on a complete N42 motor in a parts car. I'm not able to remove it, so if you want to make the trip and pull it, maybe we can make a deal....
  4. I would not trust a molded kit from ebay, unless it's from MotorSport Auto (MSA). I've included the link to my carpet thread here> CLICK Good luck!
  5. Scottie, I hope you and your family all the best through this tough time!! ~joel
  6. That's the best RB trans mount style yet IMHO to come from McKinney.
  7. Glad you made it out of that ok JT.... Man that music sucks .....
  8. I finished mine up last week with the parts I linked in above post. So far, so good....
  9. I've been using the same Odyssey PC680 in my Z w/o any problems since 2006. I do use the negative cable disconnect switch I have installed, in between use of the car.
  10. Good deal I myself have two Z31T boxs, and two RB26 front bell's that need mating, so now I'm sure how to do it... thanks!
  11. Did you remove the steel flat tab with the black wire wrap attached to it shown at the top of the front bell (right side) in Andy's pic?
  12. I have one from a 70-72. I'll take a pic of it tomorrow (Sat) and PM you.
  13. That's one of the swaps done, but with just the front bell case piece being swapped, I don't think it's nessarey to remove much but the front plate, snap rings... To remove the rear case piece from the gear set, that's a bit more involved. I'm hoping someone who has actually done it will confirm, or tell me where I'm wrong.
  14. Are just swapping bell housings only? I don't think removing those are required if so... RBZ32's swap link
  15. He's a member here... forgot his screen name though.
  16. IF that's the actual one you get from them, that looks to be a nice cond. motorset... Make sure they guarantee its the one shown!
  17. Sounds great, looks great! I remember way back when I installed Mikuni triples on mine. It was a great feeling driving around with that mean, throaty sound...
  18. AVG is great in my opinion (user for years!).
  19. Dang... I did not know MSA sold trash gaskets. I was under the impression they sold Nissan gaskets when it comes to needing a good quality product in that application. I would not buy a fel-pro for use there.. I always used oem, purchased from Courtesy Nissan.
  20. Intake/Exhaust Manifold Gasket, 79-83 280ZX Code:10-2515 Price: $17.96 Please Call Quantity in Basket: none
  21. Have you asked around on these other Nissan sites? They tend to be a bit more active with that sort of info CLICK>> . Nico and Here too
  22. I have the Q45 TB if you want.. PM me if you want to buy. joel
