Pasquale
Everything posted by Pasquale
Mounting wideband sensor to stock exhuast
Pasquale replied to Pasquale's topic in S30 Series - 240z, 260z, 280z
Ok great! I was worried that might be to far away.- 4 replies
- wideband bung location
- stock exhuast
(and 2 more)
Tagged with:
Hey guys I was wondering what your recommendation would be for welding in a bung for a wideband on a stock 240z exhuast (71 series 1 if it makes a difference). I recently rebuilt and installed a set of Mikuni triples so to help with tuning I'm in need of a wideband which is something I've never used before. I've been researching on the net about placement and I can't seem to find a definitive answer I know it's recommended that the sensor be placed at least 18 inches from the head so I don't overheat my sensor but considering I'm still running the stock manifold and dual down piping do you think if I welded the bung into one of the dual down pipes that it would give me an inaccurate reading even though the down piping is collected at both sides. Any advice would be greatly appreciated!
- 4 replies
- stock exhuast
(and 2 more)
Tagged with:
It's hard to tell for sure but it sounds like you may have a vacuum leak. Does anybody else hear hissing?
I wish that's what stuff looks like when I mess around in photoshop lol
Hello, Im on the look out for some 240z window regulators. I really dont care how they look all im really worried about is that they work smoothly and will fit my '73. Prefered if these are in Southern California so I could pick them up but if they're cheap enough I can consider shipping also.
OK cool I called raw brokerage today they pretty much said the same thing. I just want to be sure before I cause damage. I've been rebuilding this motor for over a year now piece by piece.
I bought a S1 head from a seller on Hybridz and after thinking about it I desided to get a S2 instead. I ended taking both heads to the machine shop to have both of them cleaned and rebuilt but I gave the machinest specific instructions to keep everything seperated and labeled becuase I've read that some S1 and S2 parts arent interchangable and can damage the motor if you try to use them in a head they werent meant for such as the cams. I was given one complete head and one head with a box of valves springs cams but with no Indication if he used the right parts or which head is which. I've been looking on the web for indicators but I really havent come up with anything. I was wondering if you guys know of any indicators to look for on a rb25 head that will give me some indication as to which head is which and the same goes for the cams. Any pointers would be awesome! I'll post pictures in a little bit.
Im located in Beaumont Ca. (Southern Calforina) pickup would be awesome but we can work out shipping if need be. Something in good working order thats about it the extent shape. Text me at 951-532-944SIX OR PM me thanks!
what an interesting wheel. What brand are they?
1972 240Z Fuel Cap Alternatives???
Pasquale replied to HCS01's topic in S30 Series - 240z, 260z, 280z
I have a locking gas door/lid.. Is that normal? -
its not O-ring boss it would have a groove cut into the first thread where the o-ring would seat. Most likely its Japanes Standard Pipe or British Standard Pipe which you might have better luck finding on the internet.
skyline r30 tail lights on a s30?
Pasquale replied to sid240z's topic in S30 Series - 240z, 260z, 280z
it has been done. I bought the tails from japan to do it but I ended up selling them. -
It seems more like a brake pressure issue. There are few variables that could be causing the issue such as a tired brake line or even a cracked hardline although it could very well be a bad caliper that would be the last thing I replace when diagnosing the problem. Its simple enought to pull it off and see if the caliper is at least engaging while still plumbed though.
sounds like you need a proportioning valve. Either your brakes are only engaging on the side/corner or they're engaging more when braking on that side. The easist way to tell is to jack the car up have one of your buddies work the peddle and see if you can spin the tire while somebody is braking.
Exactly!
Sorry for the confusion I meant the upper pull handle that you use to shut the door has the plastic chrome ends.
I need one in good shape the one on my passenger side broke I'll buy the whole pull handle if need be as long ad the price is within reason.
I have the Mckinney set-up on my car and I love it. Trust me it goes plenty low and they ride very nice once you get them dialed in.
what about where the stock horn bolts in? is there room for it to run directly from the center?
I would installed it where the stock horn bolts in or sandwich it onto where bumper brackets bolt in for the rear on a 240 the strongest place is going to be where the rear bumper is.
I welded in camber plates the metal on metal sound is enough to make you deaf lol
Why not just have one made? I could make the one from zccjdm on autocad in about 5min and have it cut out on a cnc plasma cutting in even less time.
you can make one at most industrial stores all you need is a steel coupler in the length and diameter you require, two heims in the stud diameter the bolt thats being bolted through it are and two jam nuts. Its shouldnt cost you more then 20$ Hope that helps!
I believe that personal and nardi use the same bolt patern but the momo one is different. I have a Nardi wheel in my car with a grant hub.
