JSM
    5
Everything posted by JSM
  1. What R200 are you looking for? LSD? What gear ratio?
  2. The wheel size really sets it off. What tail lights are those. Subtle, but different.
  3. Man, only 40K on the MB, tell me how you put so many miles on such a piece!
  4. Mine is also for the round top carbs. Not the original 73 carbs.
  5. Likely no. Did you look at it? The 260 has square intake on the carbs and the 240z has round, if you have round top carbs.
  6. I looking to add a simple, stock, 280zxt system to my car and be happy w/ the results even at 5-7 PSI. I'm doing this to keep the cost low. I would add an intercooler though. My current setup is an N42 block, slightly bored w/ flat top pistons and a fairly massaged E31 head with a pretty big lift and duration cam. Rats, I just realized I don't have the injector releifs in the head.
  7. Thanks for this. For a NA high compression motor 10.5 what would be the highest boost you would run If I were to mess w/ something like this?
  8. Very nicely done. Keep up the great work. The attention to detail is amazing.
  9. What are you looking to spend? I have one from a 73.
  10. Was empty and drove by a Sunoco that was selling race fuel so I bought 3 gallons, $23.00 later, ouch! 100 octane. I can get 110, but can't put it in the car, only containers. But what a difference, it was a blast to drive. No more 5500 to 6K drop. Pulled hard all the way to 6500. It makes me think my current timing is to far advanced for 93 octane with the 5500 drop?
  11. Yep, I agree. I bought my Z from ZGad off of ebay. I was quite happy. You may not have the best luck, if your a first time seller though. If you have at least 10 Positive feedbacks you should be fine.
  12. Nice general write up. I was curious if you left the trany mount in the stock position, not moved an inch, what would the outcome have been? Was this done to make the trany fit or just to move the engine back an inch? If only to move the engine back an inch, would the hassle been less w/ mounting, drive shaft, etc. or did it HAVE to be moved to accommodate the trany? Thanks
  13. No one has any ideas? I couldn't find a single identifying mark for SR71 other than some of the parts it had on it. I drove it today. Wow, I was in awe. 14 LBS of boost on a massaged 300zx TT is absolutely amazing!
  14. Any body have one? Any one know how to identify one for sure? Badging etc.? Any idea on what there worth? http://sportscarforums.com/post/77601-nr1.html Thanks!
  15. Lacquer thinner, just don't do it real hard and wipe it off immediately. Shouldn't hurt it at all and it is very quick. The sooner you get it off the easier it will be.
  16. I've got a set. Still on my car and still has fluid in them. $50 plus shipping.
  17. Have you all seen this: http://www.streetlens.com/japanese.html They are selling reproduction lenses on ebay. Note from the seller: Hi Jeff, we have them on our website www.streetlens.com (chrome bar not supplied sorry) Price is AUD$245 a pair, $24 insured post to USA. I will be listing on ebay next week Thanx - David dazzardy is his ebay ID
  18. Got to love them! The ending is great.
  19. Memorable Gift thoughts: http://searchwarp.com/swa1879.htm
  20. http://www.collegehumor.com/video:1899220
  21. This is my experience, itt is never about the gift itself or the cost, it is about the quality of the gift you give. Make something by hand that will mean the most to her and you. Certain gifts I gave over the years have been so meaningful because they meant just as much to me, as it did giving it to her. Making something by hand would completely fit the crazy type description she likes. Give it some thought and your answer should appear.
  22. Does it matter if the head is a P90 or P90A?
  23. Nissan made two ZCAR distributor IC modules from 1979-'83 E12-80 1 top plug (2 terminals). Used on 1979-7/80 ZX, Maximas, B210. This module works best on carbureted motors. The dwell curve is preset into the module, it only needs the distributor and coil to function. E12-92 1 top plug, 1 side plug. Used on 8/81-83 ZX's, Maximas. I found when using a E12-92 in place of a E12-80 it automatically retarded the timing 8 degrees. Even setting the time up 8 degrees made my engine feel sluggish, so I don't recommend it on carbureted motors. According to the shop manual, the 2nd plug on the side is for a spark advance signal from the brain and other sensors. Some claim this module is identical to the E12-80. Not on my engine unfortunately. E12-80
