A little bit of misinformation above...
The fan will spin an infinite number of turns in either direction, no matter it's temperature. There is no solid mechanical link between the fan and belt. The fluid in there makes a viscous connection, very similar to a torque convertor.
It will never lock up, regardless of temperature. It should just be easier to spin while cold, and harder to spin while hot (there is a wound metal spring on the front of it, similar to an electric choke or a cheap outdoor dial thermometor. It expands as it warms up, turning a valve inside the fan clutch, which makes it harder to turn). If it takes the same effort to turn cold and hot, then that spring is broken/missing or there is another problem with it, and it needs to be replaced.
As to slapping on an electric fan to cure a cooling issue, it's not going to help...see link below, page 5. The stock fan is adaquate, provided it's working correctly.
http://www.grapeaperacing.com/GrapeApeRacing/tech/coolingsystems.pdf
