SoCal-s130
Everything posted by SoCal-s130
Local here in Southern California: http://www.jdmcalifornia.com/product-category/nissan/engine-wtransmission-nissan/
240sx suspension swap kit interest?
SoCal-s130 replied to noilan's topic in Brakes, Wheels, Suspension and Chassis
Definitely interested in seeing some photos. -
What flares are these?
Anywhere I can see more pics of this car? Interested in the side splitters and how you installed them. Are they the s2000 ones?
Smoke break at Hoonigan last weekend.
The external regulator had a white/black, black, white, yellow, and solid green. I have already followed the steps shown on atlantic z by connecting the white wire with the yellow wire. I now just need a wire that I can connect to the white/black wire coming from the L of the alternator. The write up says to connect it to the green/red wire that is supposed to be in the plug that goes to the old voltage regulator but I guess the 75 models did not have the green/red wire. So I am looking for an alternative at the moment.
- 10 replies
- 280zx
- alternator
(and 3 more)
Tagged with:
The only wire I have to work with from the original harness going to the regulator would be the solid green which routes to the tach, "switching module", floor temperature relay, and the "checker". From what I recall while searching where the green wire went into my cabin it appeared that the previous owner had cut it. Would this wire work for the L(amp) connection of the alternator?
- 10 replies
- 280zx
- alternator
(and 3 more)
Tagged with:
Yeah I mis-worded that. The only wires that are in the harness leading to the voltage regulator is ; green, black, white/black, yellow, and white. The FSM for the 1975 does have the green and red going into the ign interlock unit but my vehicle does not have the green and red nor the ign interlock unit. I have read about this specifically for the 1975 only.
- 10 replies
- 280zx
- alternator
(and 3 more)
Tagged with:
Hello all, I have searched low and high to no avail. I am upgrading to a 280zx alternator in my 75 280. I was following the diagram below and carried out with the white to yellow but had noticed that my volage regulator did not have the specified green and red. It appears that the pin hole of the voltage regulator for the G/R was capped from the factory. So I am hoping that there are some guys here that have figured something out for the 75s that could help me finish this up? Thank you in advance... Connect 1-5 (lamp to windings common) green&red to white&black Connect 2-3 (+12V to Sense) white to yellow
- 10 replies
- 280zx
- alternator
(and 3 more)
Tagged with:
So I have a 75 280z with an l24 in it. Every time I pop the hood it drives me crazy seeing the mess of wires lying there. So I pulled everything out to strip everything out that I absolutely don't need... I've searched all the diagrams in my fsm for these boxes and for the life if me can't find them. I did buy the vehicle from someone with the l24 in it already and I have no idea if this is actually even a 75 harness. So to sum it up I am assuming these are some sort of relays and would like to know if I actually need them.
EBay Fender Mount Mirrors: ols_eucs (Philippines)
SoCal-s130 replied to devgru38's topic in Body Kits & Paint
Love the way these look. Like everyone else has mentioned they suck when it comes to visibility. Above post with the convex glass is an excellent idea. I'll have to try that as well. Installed on my car. -
Looks like an actual C/F bumper to me.
Ebay fender mirrors mounted.
Wheel Swap: 15x10 for stagger ...
SoCal-s130 replied to duragg's topic in Brakes, Wheels, Suspension and Chassis
Eagle Alloy 028's. -
Hey guys, getting ready to commit to a an SBC swap. Which is the best sbc for the swap? I've had a few people tell me which ones they prefer but no solid answers.
Having a problem with my 72 completely stock l24 other than a Crane xr-700 electronic ignition. I will be driving and the ignition will just cut out and leave me stranded on the side of the road. There will be times where it will drive like a champ for a week then screw me over the next day. Last time I drove it, it was wanting to cut out but then it seemed like spark kicked back in and let out some gnarly back fires. This leads me to believe it is ignition. I plan and changing out plug wires, ignition coil, cap and rotor, and check all my connectors just to single things out. But as of right now I almost feel like it's the Crane xr-700. Any input would be greatly appreciated. Thank you.
SoCal-s130 replied to k3werra's topic in Brakes, Wheels, Suspension and Chassis
Finally dropped by MSA yesterday to pick up some flares. Going to look 13 times better after installing them. 15x10-15 all around. -
Good old widened steelies tickle my fancy. 15x10 -15 all around. -
Anybody? Would help me out a lot...
