5
mtnickel last won the day on October 10 2019
mtnickel had the most liked content!
About mtnickel
- Birthday 05/15/1984
Contact Methods
Website URL
www.tsawwassenhearing.com
Gender
Male
Location
Surrey, BC, CANADA
Interests
Most cars, Audio/speakers, technology, woodworking.
Recent Profile Visitors
mtnickel's Achievements
FS: Z31T axle adapter flanges for S30 + R200. Slim design
mtnickel replied to mtnickel's topic in Parts for Sale
No longer available. undercut by silvermine with worse product…and finding strong oe axles is becoming too challenging. -
Ford Super 8.8 irs swap thread. Rear brakes too
mtnickel replied to Invincibleextremes's topic in Drivetrain
It'd be a ton of machining to be able to somehow bolt the mustang Bearing to the stock strut. Otherwise it'd be next to impossible to somehow get the mustang CV end and hub to work in the stock bearing housing. You're not replacing your "straight/true" control arms...they will be utilized. I am utilizing the stock strut tube. I'll be cutting it off, caping the bottom appropriately, and then welding to the new hub housing. It's more or less just fabricating a new chapman strut housing, but all the hard part of that fabrication is done for you. SIDENOTE for this thread...if anyone has modified the mustang hub for 4 bolt use, please let me know. Just wanting to know the nitty gritties if you somehow reinforced the hub or just utilized relocated studs in the thinner portion of the hub.- 280 replies
- disc brakes
- suspension
(and 7 more)
Tagged with:
This might explain a few of them. This guide is old and verbose and not great, but could help. https://www.dropbox.com/s/bwjujmf4ixtzmhb/Final RB Guide Draft 4.docx?dl=0 If you're using the stock ECU, I have a nistune setup if you're wanting to tune it. You are going down the right track as far as stripping the harness to make things fit...especially if you are converting to the Greddy style manifold. I originally just tapped into wires needed and bundled everything else up, but I got fed up with the mess after a while and did as you said. It was quite the rats nest, but I stripped the harness to whats needed and cut out all the excess. Some of the big spade plugs were deleted completely once sorted What gen is your RB25?
- 5 replies
- unknown plugs on engine harness
- rb25det
(and 1 more)
Tagged with:
There’s a PDF in my FS thread frogon posted. Covers anything and everything on the swap. First of all, don’t spend any money modifying those axles. They’re actually not that strong and much much smaller shaft than the OE z31t axles. Though it does matter what power you’re running, along with intended use, trans type, and tire traction. Secondly, did the silvermine kit come with any documentation on how to weld? Did you adjust it all so that it’s centered? When designing ours we found out the square part of the flange is not concentric. If you have a dial gauge, try to measure your runout. I’m curious how thick the center part of the silvermine adapters are, as they are adding to the problem of being too tight. That’s why I decided to design these. With the rock auto axles mine just BARELY fit on the passenger side. Was it only the passenger side you had problems with? If that’s the case, I have a solution for you. You could buy another driver side axle. It is shorter. But you will have to swap the diff side Cv end from the passenger unit as the splined end is longer on that side and a DS axle can’t be swapped in as is. They’re actually pretty cheap I think ($75?). If you’re over 300whp and intend to drag race, then it might not be the best solution as you’ll probably break them anyways. In that case I’d keep eye out for z31T axles. Also, the axle is tightest when at full droop. You could install droop limiters to limit how close it gets. You should find if you jack up the suspension 1-1.5” you suddenly have more room. Anyways, rambling now, message me if you have questions.
Messaged you back. Yes, i think about 10-15 sets available. -
Electric Power Steering Information Compiled
mtnickel replied to seattlejester's topic in Fabrication / Welding
To add to this thread, I picked up an 08 Prius motor. One really nice thing about the Prius vs Vue motor is that the motor orientation is opposite, and the bracketry is minimal. In the Prius the computer is remotely mounted. I think locating in the Z will be much much easier as it will angle up and to the right towards the radio. Lots of room above the gas pedal. Will document the swap here. pd $150cdn for motor and Ecu and all wiring I wanted from the Prius (got lots of the thick white 8 gauge). -
I am. Currently about 12 sets left. I plan on making more if there is a demand. -
Broken images fixed with Imgur. So you're not using the stock switch? What type of wiper switch do you have? I'd start there. From the above diagrams, you might need more than just 3 wires. when in double I can show you how to wire a single interrupt switch that will park it. The Honda motor will give you ground on that blue/white wire when the wiper is in mid stroke. So you may need some sort of relay. Show us your switch first and we may be able to help. if in a pinch, i'm sure I can show you how to wire it as a push button that you hold to park.
Found it, 94-00 integra. See my post:
I kept all the Evap lines. The one that went to the engine I instead connected to a fuel tank check valve. It’s like a valve that lets air in when fuel contracting but also seals below like 1-2psi to keep vapours from leaking out. I grabbed it from a civic or something.
Electric power steering. $100 > $1500
mtnickel replied to sectumsempra's topic in S30 Series - 240z, 260z, 280z
Messaged. I can host a Dropbox link- 74 replies
- power steering
- electric power steering
(and 1 more)
Tagged with:
I know many systems reduce assist the faster you go. That could certainly have an impact on highway driving. The system basically should not assist much at higher speeds. I got the Yaris non-abs computer as this one uses a direct speed input and not can bus. Had hoped to play with tricking the speed ( over read my stock speed to reduce assistance faster, or maybe some variable curve). But all this driveability and feel complaints have got me wondering whether it’s worth the effort. Perhaps the heavy parking lot steering is just the cost of admission for an old car.- 74 replies
- power steering
(and 1 more)
Tagged with:
Will message you regarding purchase. All other questions covered in PDF https://www.dropbox.com/s/23dj8il5rru20i3/Z31%20Turbo%20CV%20axle%20ConversionV4.pdf?dl=0 -
Just make sure the shop that welds yours Centers the square flange in the adapter. The stock square flange isn’t concentric and if they just throw it in the adapter and weld you’ll be SOL. It make have lots of runout and vibrate. We designed a jig to locate the adapter ring to the stock flange for welding. It also clamps it flat so the part doesn’t warp while welding.
