I thnk you are missing the point here. Turbo injectors are larger than NA injectors, so they flow more fuel for a given pulsewidth. With the NA ECU and the turbo injectors you are going to have too much fuel below atmospheric pressure, (the turbo ECU will have a lower pulsewidth here) and you'll gradually lean out as you build boost, as the NA ECU is going to keep a steady pulsewidth independant of boost level (ie: afm door fully open) but with 44% (or whatever the increase in fueling is from NA to Turbo injectors... 180cc/min -> 260cc/min IIRC) more fuel flowing than it would have with the NA injectors. All things equal, you would achieve the same AFR on your setup as a stock NA engine has at 6.5psi boost, when using turbo injectors and a NA ECU.
The AFM being smaller is going to decrease the amount of air flowing for a given fuel setting, therefore leading to a richer mixture throughout the range as well... something that bodes well for a turbo setup, as the stock AFM on an NA 280zx seems to dyno in the 12.5-13.0 range at full throttle in my experience.
In summary, I would think an NA ECU, NA AFM, NA FPR and turbo injectors would put you in the right ballpark for fueling below 7psi, though you are going to be too rich at manifold pressures less than atmospheric.
