KevinE
Everything posted by KevinE
Why don't you find a reputable tuner in your area that is familiar with the software and boosted applications and see if he can workout your boost issues! You're so freakin close man! I hate seeing ppl give up just cuz of a frustration. Its not running right for a particular reason....once u figure the problem out its going to be a nasty a$$ Z straight up. I feel u need to take a break from wrenching and getting worked up about it, go do something outside of workon in the Z, then try to jump back in to tuning. Read up on tuning, call tuners and ask for any input they might have. YOU CAN DO THIS!!!!!!!! I have faith, especially when we see ur fab skills with a $200 welder. lol Anyways, take care and good luck with whatever path you choose...
All you need to do is paint that from mesh grill black and it will look 1000x better. Other than that...i love it. Good job
Thanks guys! appreciate the comments! -Kev
I feel it's coming along quite nicely... Can't wait to buy a Z though...still miss mine... Anyways, thanks guys! -Kevin
Blue foam for fiberglass mold ? what is it
KevinE replied to gretchen/jason's topic in Fabrication / Welding
There was actually a show on Spike TV (Musclecar) where they created their own fender flares for a mustang they were going to track. They used the Blue foam from wherever (floral store or home depot), and stated that you can use anything to create the shape you want; i.e. any type of foam, sheet metal, cardboard, WHATEVER gets you the shape you are looking for. The only thing you need to worry about is a release agent. They actually used aluminum foil as their "release agent." They got the flare to a shape they liked, wrapped the foam in aluminum foil, then started laying fiberglass over it. They had stated they did 3 layers of fiberglass for strength. (Oh, and on a side note, they were testing different glues out to try and find something that would allow the blue foam to stick to itself so they could get some depth to the flares. They tried, I believe, 5 or 6 different glues out and finally found one that would actually hold the foam. They didn't 'tell' the viewers what glue they ended up with, but I'm 99% sure they found that the "Gorrilla Glue" ended up working the best. You can get this stuff at Kragen Autoparts or wherever.) I have never fiberglassed before but it honestly didn't look too hard. Set the foam up on your fender then start sanding away to shape it into something you are looking for. Once they had their mold glassed, thats when they started to sand, fill with kitty hair fiberglass, sand more, then bondo, sand, bondo more, sand more, etc. I'm sure it is a very tedious process of sanding and filling, but the end result will be worth it if you just take your time. Also, one last side note (I swear), the guys creating the flares also molded in bolts to their flare so all you need to do is drill a hole in the fender, and throw a washer and nut on the other end. Looks clean and took no time to do. -
http://www.venus-auto.com for us Cali people! Got SR20's, RB26's, 2JZ's, etc. Full front clips. Just thought i'de throw that up. -Kevin
gotta love the shocker.... Damn that thing sounds wonderful...can't wait to hear the T88 spool! Good job!!!!!!! -Kevin
I'm with Allen on this one. What is causing those small explosions to occur? I mean I can assume that its backfiring...but I've never seen a backfire with that much power behind it...jesus. I'm guessing with his FI it is adding a little more exhaust flow along with the misfire? Who knows...but I do know those guys are pretty much jackasses. lol -Kevin
probably to protect the finish on the metal from fabrication?
I like! What are you using to create it? Flash? Dreamweaver?
Nice ride! Mine is in my sig....definitely love my WRX.
I've been doing my own powder coating for that last couple months in my oven at home. It's not hard at all, just sucks cuz you are limited to certain size items (aka....no rims). But i've been using my buddies powder coat gun that he bought off ebay, its jenky but sticks that powder to the metal! So far everything seems to bake evenly and solid. We have been doing parts for his car like his intake manifold, valve covers, etc. We put whatever base coat on, and for the items in plain sight, we usually throw a clear coat over them. Overall works good!
beastly!
damn...that stuff looks CLEAN!!!!!!
Basically drain your tranny fluid, pull the drive shaft, disconnect your shifter linkage, disconnect your starter, all the bellhousing bolts, and that baby should drop right out. It isn't very difficult, you should be able to do it in an evening
Rusty Datsun Army RepreZent (56k drives a Yugo)
KevinE replied to mario_82_ZXT's topic in Non Tech Board
ultimate sleeper with a turbo'd L, or an LS1/2 -
street test runs...on my lt1/t56...
KevinE replied to piston's topic in Gen I & II Chevy V8 Tech Board
You would think that if it were the clutch not getting full engagement it would be slipping even worse in the upper gears due to longer pulls. Hmmmm....are you letting the clutch completely out when going WOT in your first 2 gears? -
What happens when your bored have tools but nothing to work on...
KevinE replied to Some-Guy's topic in Non Tech Board
that looks pretty gangster -
come on....you know those are the cleanest welds you have EVER seen...HA!
hahahaha....I definitely know. How's the new R1? I've watched the vids on ur website....the new bike sounds nice. Where does darius live in comparison to your house? Pretty close i assume....just hurry up and put that 383 into the Z and go ravage some cars.
Kilten one....where do you plan on getting parts from for the 240sx? http://www.amsperformance.com/ has some pretty nice parts. they just had a KA motor'd 240sx go into the 9's. pretty nice.
hahahaha. That would be too funny. Mine IS black...but not for sale. I was looking to get a Z on top of keeping my wrx. What year WRX is he looking to get? And if he is looking to get something within the WRX range....tell him to get a used EVO VIII or maybe even an EVO IX. Those cars are nasty when modded correctly and VERY reliable. They also hold their own pretty good at the track. If I could do it over again, I would have bought an EVO instead of the WRX because they respond to mods a lot better. Here is a link to a thread I started. the first pics are of my WRX, they can look pretty clean if you ask me.... http://forums.hybridz.org/showthread.php?t=119598
Hey Brian its Kevin. So you guys are tossing out the stroker! I'm now looking to get another Z to put a V8 in. My WRX just ain't fast enough for how much money I'm throwing at it, plus I love Z's and I want another project car. The 383 w/ 500hp sounds extremely tempting for $5k and a warranty. Now figure out what u guys want to do for tranny....t5 or a t56...i vote t56. Good luck with the build! -Kevin
