Everything posted by Clifton
Didn't see this until today. I was running a 17x8 in the front with a 25mm offset. I pushed them out 10mm so I think a 9" with a 35mm offset would work. It would only be 5mm out more than mine. On the rear I ran a different hat than his standard that was thinner with a 35mm wheel and it was perfect. Dave and I went over all the measurements on the rear with both hats and a 43mm 17x9 was within 1mm of how my set up is. If you aren't running adj arms in the rear I would run a 43mm 17x9. You can always space it out a mill or two but if you are our 5mm too much it will rub. If you are only going to run a 255 you will have a little more tire room. I ran a 245 on an 8 and 275 on the 9. I rolled the front when I painted but not before and it didn't rub. Watch the front lower fender when turned though. I trimmed the inner rear with a grinder after I painted when I went to a MT drag radial. They are pretty wide for a 275.
Clifton
Hi Clifton!
My name is Jayson, and I've been working on a 1977 280Z for a while now. I noticed on the "Wheel Show!" thread that you had the exact wheels I was eyeing, and I wanted to know if you had done anything to fit the 17" x 9" wheels in the stock wells. I currently have the complete set of Arizona Z car suspension parts front and back (including coilovers), along with the 5-lug disc brake conversion and big slotted 13" front rotor with 4-pots on all wheels. Dave at Arizona Z Car said the 5-lug conversion adds .5" space to the front and .75" to the back.
I want to put the 5Zigen FN01R-C 17x9 wheels with +35 offset at all 4 corners , on 245 or 255 tires. Do you think this setup could work with the 280? Will I need to roll the fenders? I'm going to keep the stock fender width (i.e. not put in ZG flares or wide-body kits).
Thanks for ANY advice you could give me! Your car is incredible btw.. I LOVE the grey super-sleeper idea. Got myself a 7M supra turbo in the garage too
