4
Everything posted by G-Tech
What year car ? You cant tell what its held up on?
im no expert but i have looked at altering or making new trailing arms for my zx and it doesn't seem so straight forward. they are a semi-trailing arm, they are not just 90deg to the wheel, they are mounted on an angle. i wanted to do something because the wheel pulls forward when the car squats. and the zx's like to squat. i have 17x8 with 0-offset with 235/45 tires and i had to clearance the front of the wheel well lip. it was actually hitting the front of the wheel well. i have a 400whp LS motor in it but i also have 380lb springs in the rear and the car comes stock with 125lb springs. you can put like eibach springs in it but its still gonna squat pretty good even with a stock motor. i want to eventually figure out how to move the mounting point for the semi-trailing arm back more. you can play with the offsets and run inward more. i have lots of room to the inside left over but my opinion (again im no expert) but with a car that squats alot, once it does, and you have some crazy offset wheel, the tire is not gonna stay flat on the road and you will just end up riding on the inside edge. so i stuck with 0-offset cause thats what the car was designed for. and i get lots of traction. ive road coarsed it and i go to the dragstrip alot and i am very happy with it. even when i had a stock v8 in it and was still running the 14x6's the car hooked pretty good. the zx's get lots of traction as is. im not saying something different cant be done or that it would be wrong so do whatever you can do. i see that there is others with the wider tires but id be curious if they rub when they are hard on them. good luck
think you mean patch panels? i have yet to see anything for that. and get a hard dash cover. they are still cheap and look really good. just put down some good RTV or the sun will warp it. but if you keep a sun visor for the windshield that will make the cover last a lifetime.
welcome to the odd ball s130 club. thats exactly what my car started as (exterior and interior)..if your on a budget, spend your money wisely. these are hard cars to do on the cheap. stay away from showcars.com for any fiberglass parts. those wheels are 14x6 with 0-offset. the only things your gonna get to replace them cheap is some standard steel wheels. id start with getting it running first. atleast at that point you could get more money for it if you decide to sell it. not a quick car for todays standards but they are very fun cars to drive. and as you have been informed, almost nothing on them relates to a 240,260,or even a 280z. they dont look so cool with the bumpers off like the older ones do. but hey everyone has a taste. enjoy whatever you do and good luck with it.
280zx door seal weatherstripping alternative?
G-Tech replied to Luke_elkins32's topic in S130 Series - 280ZX
try them, think they have what you need...you will run into trouble when you need door weatherstripping or if you have t-tops and need the rubber that mounts to the car https://zcarsource.com/weatherstrip-seals/weatherstrip-280zx/hatch-seals-bumper -
i was hoping someone else would check in since my info is all over this thread but not sure since there isnt many out there. ive seen 2 or 3 that have been finished but not much if any info from them in a while. and a few more that are in the same boat you are. the problem with the oil pan is on most of them, the front of the pan and the rear sump hang too low. my front is so shallow on mine that i cant run a stroker motor but it allowed me to get the motor low enuff. on most pans, the rear sump ends up below the crossmember and become the lowest part of the car. the one from Canton just had all the right dimensions and 5+ years ago that was the only one. look up the dimensions for canton pan and see what might be out there now. the dirty dingo mounts can probably work but mostlikly will require some sort of mods. the mounting holes on a LS end up behind the crossmember so you will mount the motor mounts to the cross member then you will need a plate that moves the mounting holes towards the rear of the car. the ones dirty dingo has for the older Z's looks like thats what it does but note that the older Z's are different so its not going to be exact. good luck, anything is possible if your able to put in the work.
From the album: 280zx customization
That is definitely a different steering rack then mine. Might help for clearing the manifolds. Block huggers would run right into that box. That's strang how different the rack is. Similar shaft but your right how it stays over the frame more. That's good
thank you much. i hope to have it back and driving in 2 months. just intime to drive it a couple times then tuck it away for the winter. im sure you might have noticed the gas cap beeing a fellow s130 owner. there was also engine bay smoothing out, shaved blinkers front bumper for blinkers built into headlights, some other mods and a yet to be reveled new design of tail lights.
