MONZTER
    34
Everything posted by MONZTER
  1. I ran the test at lower boost on the HKS Plenum. Looks the same, same equal flow distrabusion, so I wont be posting the pics. Can anybody see anything negative about the results above?, If there was room for improvement, what would it be, and how would that be acomplished. I would still like to see less swirling and less bends in the airflow.
  2. So once again, Thanks Tony D for the loan of his HKS Type 2 intake for testing. I was really interested in seeing how this plenum would flow given the success of it over the years. My plenum I have been working on has been plagued with a couple of vortices that have been causing the front two cylinders to run with less airflow. I wanted to see how consistent the HKS would be. So wouldn’t you know it? the HKS plenum looks pretty good. There is still swirling, but this doesn’t seem to be affecting the flow down the runners like my design is doing. The pressure looks to be even down the runners as well as the velocity. So check out the pictures below and let me know your comments, I know now I have more work to do on my design to even out the runner flow more. I have posted pictures of cut away views so everybody can see the internal baffling at work. I went as far as to model the plenum very accurately, down to the internal casting bumps for threads, to the shape of the runner inlet. It’s as close to the real thing as I could get. The test was run at 20psi boost 793CFM the inlet ID was 62mm so a inlet velocity of 4880in/sec was used. I will be running less boost on the next analysis and post the results soon. One more thanks to TurboBlueStreak for the lessons in the Floworks software by the use of his models from previous test. Click on the picture for a bigger view in my gallery Jeff
  3. I was actually going to look into the opening of the valves in relationship to the cam I will be using. I don’t think only 1 valve is open 100% at one time. There may be 1 valve open at 100% and 1 or 2 more partially open. I will look into it. I have most of the HKS type 2 modeled and have run a quick analysis on it. Looking really very good and even flowing so far. I will post the results soon. MonZter
  4. On the V-8 engines they use a carb before the intake so the manifold is wet. On this intake the plenum it is dry because of the injector placement. Getting the air to start to swirl once it enters the runners and into the cylinder is a good thing for what you say, but having it swirl in the plenum will just make heat and reduce flow.
  5. Just so you guys understand, I have a day job, actually one I quite enjoy. Z cars are my hobby and will stay that way. I have no plans to make, reproduce, sell, devalue or profit from any Z plenums out there. I will have spent way more time and money on my design than if I just went and paid top dollar for an HKS. This is purely a fun learning experience that I am going through to build myself a plenum for my project. My purpose to this thread is to show all what we learn so that everybody may better have a idea of what to do when they make their own. This is what I thought this forum is about and why I like it so much. A group of intelligent creative people who love to build and fabricate their own z parts to make their z-cars into what they always dreamed about. I am seeing more and more post of people trying to sell stuff on this forum, I hope this site doesn’t become that, you won’t see this from me. So seriously don’t you think that if somebody really wanted to copy and rip off the old HKS plenums they would have by now? MonZter
  6. Tony, Thanks again for letting me borrow these. Much appreciated Jeff
  7. That sounds great Tony. I'll get with you to check them out. It will be good to see if there is any magic in those old HKS intakes. BTW my computer fried the other day, so I have been recovering all of my files (nothing lost) and my new computer will be in soon. This is why there have been no updates lately. Back on real soon. Jeff
  8. Yes, the angled plugs are all part of the master plan. First a few more details. Like I said above the head of the pistons will be a mirror image of the head. What I did not say was that the shape of the piston under the intake valve will be domed, and the shape under the exhaust valve will be dished. The idea is to use the domed portion under the intake to make some squish which will force the charge to the exhaust side, right where it needs to be to flow out. The angled plug will now be closer the true center of the mixture, just like you said. You just have to imagine the chambers are no longer traditionally shaped, they will now be offset towards the exhaust valve. So, a few things that will make this work. First all of the chambers are designed in 3-d on Pro-Engineer, so it will be easy to design the piston tops to be exactly a match to what I am trying to do. Second, since the chambers are all CNC machined at one time, they will be perfect in shape, size, and volume to perfectly match the CNC’d piston heads. I am hoping the small tight chambers from the above idea will make for a very fast burning set-up, which means less detonation, and less timing. All good things. Check out the link I posted above, It goes into much more detail BTW The head above (P90) is just roughed out. Once the head is surfaced, and all of the valve guides and seat installed, it will be put back in the CNC machine and cut to its final depth with a much finer step-over
  9. OTM, Have you ever seen the heads I modified? Here is what I currently run a N-42 welded for max quench with 36cc chambers. On a 1mm over 240 lower end with flat tops .015 out the deck with a comp gasket. Runs great on 91 octane all day Here is a picture of my next head (P-90), not finished yet. I took it to the next level with welding up the chambers, ports, and plug holes. Made a CAD model for the CNC to cut them out all the same. High quench, lots of swirl. I will be doing as 1 fast Z states, in the fact the piston will mirror the head. I will be using this on my 280 turbo project.
  10. Maybe some have you have read this http://www.theoldone.com/articles/The_Soft_Head_1999/ Good overview
  11. The AZC rear control arms used to be this way. At least a few years ago. I was told you had to run the style of camber plates like John C sells that dont require welding. After you installed the arms you would have to line up the camber plates as if you were tying to add more caster as in the front. This should eliminate the binding, because both top and bottom are now moved back.
  12. Have you seen this one? FP3582HTA Turbo http://store.forcedperformance.net/merchant2/merchant.mvc?Screen=PROD&Store_Code=FP&Product_Code=NTFP3582HTA Not cheap but, it is supposed to spool better than a standard 35r
  13. Hi Justin, The plate is .250. Punching 4130 that thick will work but the coined edges are not so pretty. For high volume production that would be the ticket. So what do you guys think about the urethane bushings? are they going to hold up, and do you think the set-up will be too stiff and noisy? I have a urethane filled stock mount now, and the gearbox rattles around pretty good at idle with cam I use. I could always put some rubber ones in there for the street?
