MONZTER
    37
Everything posted by MONZTER
  1. I also don’t want anyone to forget Mike (TurboBlueStreak) He is the computer genius who started this hole CFD testing process. He taught me how to do it and I thank him. He was also responsible for all of the first test, as well as Ron’s test. He is currently working on some really good stuff.
  2. Hi Tony, I did the mods you requested, and it appears as I thought, the restriction is not between the upper and lower plenum and not really the problem. Here is what I did - 1.) Standard HKS Type 2 - flowed 442CFM at 25" 2.) Standard HKS Type 2 - Same test but without the bolt on inlet, just straight into the two openings on the plenum - 640CFM at 25" 3.) Standard HKS Type 2 - same test but opened up the outlet from the bolt on inlet as big as possible between it and the plenum - 582CFm at 25" 4.) I also tested it with the same as above, but with 1 inch holes in 4 places between the upper and lower plenum like you suggested - no real difference, just the flow into the runners did not seem as even. Pictures below are of this test. As a side note - with the above changes the pressure drop went way down as well. My opinion would be to leave the plenum alone and work on the bolt on inlet. Currently the inlet is only 60mm inlet where the others I have been testing are at 70mm. (Rons flowed a huge 844CFM and mine is at 650CFM both at 25â€) There is a lot of thick walls in the inlet and some serious porting really seems like it would help without messing up the nice even flow. I hope this helps Jeff As usual, click the pics to enlarge
  3. When I first saw them I thought they were these http://forums.hybridz.org/showthread.php?t=129095 This was a post a while ago, about some wide flares that sold on E-bay. I believe they were special 432-R flares. The bolt holes look different on yours. I wonder if Alan (HS30-H) has any info about what they really are? Jeff
  4. I use a Tec3R with an AIC solenoid. I turn the car on, wait for the fuel pump to run for a second or two then turn the key and it starts. The AIC opens a programmed amount for startup and then closes a little to keep the idle at 1200 until warm. Works great. The better part of the AIC is after blipping the throttle. It acts like a dashpot to keep the car from dropping the RPMs too fast and stalling with a very light flywheel. Electromotive makes a billet remote block for mounting an AIC valve really easy.
  5. I have never had a problem. Been running them for years. Set up on the Z-head rocker wipe pattern is very critical. If you get it wrong, good-bye cam. I wonder if people blame the cam for their poor set-up, or lack of understanding?
  6. Tony, I'll add some holes in the divider floor, but I dont think that is the only restriction point. I think it may also be between the seperate elbow part and the main plenum (lots of room for enlargement). I will do a little work to figure it out for you. Jeff
  7. Just a little update. Been working non stop on the design trying to get it perfect. I have the flow really balanced out nicely between all runners. Now I am just looking at pressure drop, and total flow. I should be posting some final results of this design as well as all the other designs tested in my research. As far as making a quantity of these! It was never my intention to make any more than 1 for myself, but provide the information to the group to use it in the creation of their own designs. I am not really into the idea of using the forum as a sales tool as much as I am into it as a fantastic knowledge base.
  8. I have been running the Bilsteins for about a year now, re-valved 300-100. I keep having a problem with the gland nuts loosing up. I locktited them this time, I hope I can get them apart someday? Anybody else have a problem with them coming loose?
  9. It does sound like the correct center section, I just have no idea how the standard size wheel will react with the smaller A/R compressor housing. You would need to see a compressor map for that combo, as the standard map for the stock .7 A/R will no longer be accurate. Who knows it might be really good, but then, why doesnt Garrett offer it that way?
  10. I know this thread is about who rides to work, but I would like to see some pictures of your bikes. Lets see those Hybrid rides. I know a lot of commuters and their bikes are usually pretty custom for these specific purposes.
  11. It looks like a GT 35r with a T40e compressor housing on it. You will have to pull of the turbine and compressor housings and measure the inducer and exducer size to figure out if the wheels are 35r specs. It’s hard to tell from the pictures, but the turbine housing looks like a 35r. FYI my GT30r has a ported 4" inlet and a 2' outlet on the compressor. My 35r has a 4" inlet and a 2.5" outlet on the compressor.
  12. Me and a group from the office ride during our lunch break 3x a week. It is a full on beat each other up sprint for an hour. Well usually cover 17-19 miles. Its great for stress releif, and fun to talk @#&* on each other out on the road:razz: The technology in the bike business is simply getting crazy
  13. I have bought a GT 35r .82 with hopes of making 500 hp to the wheels on a completely built engine and system. I do not believe a 30r is capable of 500 hp to the wheels on our old 2 valve type motor. If you goal is 400hp and better response then I think the GT30 will be great (but I would want it with the Garrett ported compressor housing, and high nickel turbine housing) if I paid for it. That’s just my opinion
  14. I believe Garrett sell the bearing cartridge by itself. The compressor and turbine housings can be purchased separately. I believe people use the Garrett cartridge and then buy a cheap non Garrett compressor and turbine housing. By cheap I mean less expensive as the Garrett stuff is pretty expensive, but I also believe the turbine housings are made of a better material. What did you pay for it? If you paid full GT35R pricing then I would be bummed, but if you got a great deal on it, then that’s probably how. I was just shopping for the same turbo and all of the E-bay 35r's I saw did not have true Garrett housings, hence the good price. Check ATP Turbo. They sell them both ways; usually they only sell the non-Garrett housings for special fitting problems.
  15. You cant. Sal at Motorsport Auto ordered 2 custom sets from Japan. One for me and one for his 280. I am running 8" springs in the back with coilovers. The perches just fit above the tire so I actually can fit some 265 Kumos under there as well, its really tight.
  16. Ron asked if I would run a test on his revised plenum. I thought it would be interesting to compare his revised design with his old design. I also thought it would be interesting to compare this single throttle open plenum design to what I am trying to do, as well as the HKS. Here is a link to Rons old results and pictures below of his new design http://forums.hybridz.org/showthread.php?t=117607 Picture of his old design Some pictures of his new design - 5 psi 20 psi As usual, click on the picture for a bigger view. Looking for comments, and yes Ron gave me permission to post his results, thanks Ron:D
