I started a thread a few days ago regarding the shape of air horns for the new intake plenum I am working on for my Turbo L-28. Here is a link http://forums.hybridz.org/showthread.php?t=127653
So I have begun to develop the shape and design of the plenum itself. Been doing a bunch of reading on this forum as well other sites. Seems like everybody is trying to do the same thing, get the air as smoothly and evenly into each intake runner. Ron Tyler made a nice looking manifold, but determined there was room for improvement. I have also heard Tony D talk about the internal baffles on the Japanese plenums used back in the day. This is where I began my design. Luckily, no one ever re-invents the wheel and I found exactly what I was looking for on some 80's Audi rally cars. Check the link http://www.bufkinengineering.com/intake%20manifolds.htm and pics below:
Here is also a link to some stuff BMW was doing (big Volume boxes) http://e30m3performance.com/tech_articles/engine-tech/airbox_symposium/page5.htm
So you can see in the pictures of the Audis, they are putting the air into a sub-chamber that then lets the air enter the main plenum evenly the entire length it. This will eliminate the action of the air passing the first few ports and favoring the back ports. I think this is more of a problem on turbo applications as opposed to NA.
So I designed a plenum with the same concept as above with the following specs.
-Plenum volume (without the sub plenum and air horns = 5853cc
-The area of the 3-inch sub plenum tube where it enters the bottom is 45.6cm
-The area of the slot between the two chambers is a little bigger at 57.4cm. Extra material is designed into the slot area to allow enlarging or changing the shape after testing.
Here are some pics of the concept so far:
In this cross section you can see the slot connecting the two chambers-
this view kinda looks like the inside of a turbo when looking down the outlet-
You can see the clean entry into each runner-
And the cross section of the chambers-
I saw in Ron Tylers design that someone on this forum did a CFD analysis of his design. I can provide any type of 3-D file of this idea if anybody is interested in doing some CFD work on it and seeing how it looks.
So I am looking for comments suggestions or simply holes blown in this concept. Thanks
Jeff
