MSnS ignores IAT once water injection is started until you drop below a set psi. I am not sure what that means fully, does it just ignore IAT so water injection doesn't turn off based on IAT or does it actually ignore it for fuel correction. I believe the former, anyone else looked into it further?
Now, how did you slip that in there without an edit showing up??? I could swear there was no other reply after z-ya
I would email that pic to Klaus at innovate and let us know if he recommends you to use the heatsink. He should give you a quick answer for that distance, which is easy to see in the picture. I would like to know straight from the expert.
Yeah, sounds like you have a short. A wire perhaps that has worn through the shielding and shorts intermittently at the firewall maybe, or under the seat. Do you still have the box under the seat? Is there a rubber grommet where all the wires pass through the firewall?
Excellent, thanks for the tip. I wondered about the IAT placement.
Bernard, I will control the water injection with MSnS so I don't think I need anything else, just a relay for the pump. I forgot about that when I saw your post earlier.
I checked the water injection page for MSnS and it also uses a fast acting valve to pulse the injection nozzle along with the fuel injectors.
I figured it out
scroll clear to the bottom and look left where it says posting rules
in there it says smilies are on/off
click on smilies text and it takes you to the FAQ window with the entire list
atleast its the manual way but hey I'm a smilie
If you just want the VE map itself, install a copy of extra code on your pc (not on your megasquirt box) and open up the .msq files we have here and just write it down so you can manually enter it in whatever version you want to use.
I think the sticky shows a screenshot of my origianl fuel VE table.
That may be the easiest way to get a VE entered to get you started.
Just to make sure we are all on the same page, all wideband O2 sensors have there own heater run by the wideband controller. They do not need any heat from the exhaust to work. It is important that they are not close enough to the engine to see more than 900 degrees because that overheats the sensor and the reading will not be accurate. When in doubt use the heatsink from innovate.
Some narrowband sensors do not have a heater and must be close to the engine to use the exhaust heat.
A single LC-1 wideband setup is capable of running the megasquirt and an AFR gauge because it has 2 outputs as mentioned.
Your on the right track, find someone with a wideband or go to a dyno so you can use the dyno and wideband to tune. LC-1 for $200 is the cheapest wideband option other than that.
where does this line come from? It is in the article:
Women, far more than men, are likely to act out their behaviors in real life, such as having multiple partners, casual sex, or affairs.
What studies back that up?
From everything I have researched I put the wideband about 3 feet downstream from the turbo. It is not a concern to be farther away unless you have exhaust leaks or you need ultra fast wideband updates (which the $35 bosch sensor has been argued to be slower at responding than the $120 bosch sensor anyway). I don't believe in the response time argument for street applications. just my 2 cents
Of course position the sensor so exhaust condensation won't puddle up on it (put it on top of the pipe, or top portion)
ok, and I'll be the noob to ask, how do you see all the smilies so you can put them in posts? I swear I have looked everywhere when I reply, like right now???
Yes, I plan to use the stock knock sensor on my Talon install. It does require building a seperate circuit, a fairly involved circuit. Look on the MSnS_Extra website to read more.
I don't have a water injection kit yet, i just wanted to pop in a fitting while everything was apart and I only have a 3/8npt tap. SO I went ahead and added it. It is plugged for now and if I don't end up needing it, no big deal.
Thanks
I will be drilling and tapping a 3/8 NPT hole right before my TB today for an air temp sensor. It would be real easy while everything is apart to drill and tap a second for water injection. I plan to run that shortly, is a 3/8 NPT hole OK, will that let me get a nozzle in there? And is right before the TB OK? I will be running a water/methanol mixture. I could search up some of this, but if you help me out on this one I can get everything finished today.
