Everything posted by awd92gsx
Urgent Engine Advice Please - About to part with $$$
awd92gsx replied to ZHeadV8's topic in Gen I & II Chevy V8 Tech Board
What are you planning on doing with the car? I mean...what are your ultimate HP goals? Or...are there any HP goals? It almost sounds like (and this is in no way meant to be an offense) you just like having the bells and whistles more than the actual power. Just watching a few videos of a V8Z will show that it doesn't take much to overpower the car. As far as your questions go: The LS1 is a great motor!! I *believe* Darius has an 383ci LS1 (supercharged) in his Z and judging from the videos of his car doubt it could handle any more power...it can't even handle the power he has in it now. Maybe I'm naive..but...$14k sounds like alot of money to me to put into an engine unless you put the same amount into tubbing your rear end and redoing your suspension/brakes/frame. -
700r4 and full throttle into overdrive
awd92gsx replied to a topic in Gen I & II Chevy V8 Tech Board
Isn't that tranny equipped with a lockup torque converter? You could make a switch or something to manually engage lockup (just don't forget to turn it off) -
Got My V8 240Z !!! BUT.....
awd92gsx replied to TheNeedForZ's topic in Gen I & II Chevy V8 Tech Board
I plan on installing a fuel pressure guage anyway. They're cheap and might tell me if I am running too much fuel. I finally got the exhaust on and drove it. I havent' really mashed it, but, it didn't give me the "oh my Gawd!!" type of accelleration I was hoping for...but, I've only been driving around on the primaries and haven't really opened it up. Something is definitely up with the carb, though. Even though it was just rebuilt it doesn't idle quite right...seems to have kind of a rough idle. Hell...maybe it has a hot cam in it and I just don't know it. (I doubt it). I used my old muffler...but, I'm thinking it's not quite loud enough...so I'll replace it in the future. -
Do you mean the S&S in Glendale, AZ? If so...they're very close to my job, too...however, they didn't seem to interested in any more Z development when I talked to them.
...ok, it's at the exhaust shop now. I drove it there (only about 1/3 mile), but, didn't get on it still...I actually passed a cop on the way there, though!! Scary as all get out! For some reason my turn signals aren't working now, though. I think I might have left a ground undone when I did my harness....will need to check that out when I get it back.
Drove it around the block...I'm still through open headers so I didn't really mash on it. Am going to ease it down to the exhaust shop in a few minutes.
Believe it or not, but, I've found that http://www.autozone.com is actually quite an invaluable resource. I found all of the vaccum wiring diagrams for my engine ('77 El Camino 350) there along with quite a bit of other "book" only info. -
Hmm...now that you mention it there is a little bit of fuel seeping from the accelerator pump. Now, it's while cranking basically...it just shoots a jet of fuel right out the top...maybe I'll try the fuel pressure regulator...I'm not sure of the fuel pressure, but the pump was rated for 5-7psi @ 35gph, doesn't necessarily mean it's not putting more than that out, though...especially since I rewired my fuel pump with something like 8 guage wire and a relay setup. -
Just so I don't have to start a new thread...I'll post in this one... Sometimes (most of the time) when I go to start my Z (350 with a Quadrajet) fuel actually spits out of the top the carb...then I gotta pump it a couple of times to get it to start. Once it start it *seems* to run ok...maybe slightly rough, but, I don't know if that's because I'm still running through open block hugger headers. Never owned a carbureted car before, but, I wouldn't *think* this is normal...is it? Or is it because of the electric fuel pump forcing fuel into the carb during startup? Confused in Arizona. (note, while running it DOES NOT spit out fuel from the top of the carb) -
I'm running a stock oil pan. Of course...my car has made it to just about the end of the driveway before turning back home.
Well, it would be one thing if I was actually driving the thing, but, it only idled for about 5 minutes or so and it was hanging very steadily in the same spot. So...I dunno if the guage isnt' exactly correct or what. I have a 3300CFM fan sitting on a Camaro radiator set at about 180 (can't go any lower than that) I never have really trusted this guage anyway. I'll start saving up for a full set of Autometer guages for the dash.
When using the stock Datsun guage with the JTR bushing for the temp sensor...where is the needle suppose to sit? I mean...is it supposed to sit right in the middle? (mine doesn't...it sits about 3/4 over and I haven't even taken it on the street...just idling) Searched, but, couldn't quite find the answer...
Alright....well... I decided to just cut up the plates, screwed them to the tranny tunnel, and then screwed the shifter to the plates. It'll do for now. Car moves under it's own power now All that's left is to wire the fan, tidy up the tranny cooler lines, and then drive it down to the exhaust shop tomorrow for the exhaust (it's only 1/3 mile from me...if that) Getting excited, but, pretty nervous all at the same time.
If all goes well, mine should be "done" this week. All I have to do is finish wiring the cooling fan, get a couple of vaccum lines for the carb, and install the plate to mount my shifter to. I think I started around the middle to end of January.
Hmm...well, the tranny is already in the car, so I don't think I could do it from underneath...but, I *could* possibly bend the plate in a way that it sits further down into the hole and still bolt from the top...sorta like the lower JTR radiator mount.
Sorry for what may seem like an uber-n00b question...but... Even after searching through the forums I haven't really been able to find an answer... The stock shifter hole obviously needs to be covered up and some kind of plate made for mounting an an auto shifter...I have a B&M Z-Gate (I don't really like that it sits so tall, but, I'm stuck with it for now) and am not sure as the best way to mount it. I purchased a 6" x 22" plate (22 guage). I think I can cut it into a couple of pieces and rivet it over the stock shifter hole and then mount the shifter to it. Does this sound like the best way to do it? Other than a few odds/ends the car is almost done. I let it run for a few minutes (still through open headers until the car can move under it's own power) and whoever told me the paint would bubble off the headers was absolutely correct!!! The engine sounds incredibly mean and I can't wait to drive this sucker!!
Yeah, according to plan, my car was done about a month and a half ago. I fired it up for the first time 2 nights ago and it's still not driveable.
I despratly need some help with my swap!
awd92gsx replied to 240ZR's topic in Gen I & II Chevy V8 Tech Board
It sounds like somebody caused themselves much more work than needed... The engine and tranny should have went in as a unit and the starter coulda been installed prior to the drop in. In any case, good luck with the swap!! As I'm finding out, it's the tedious work AFTER the engine is in that's most time consuming. -
OK Runs good enough so that when I get everything else hooked up I can throw a timing light on it. Of course, without an exhaust it's loud as hell!! I love it!
LOL, it was only around 8:30pm when I started it last, so I should be ok. I did, however, have a neighbor come all the way up the street to tell me that there were flames coming out from underneath my car.
OK...I know I said I wouldn't work on it any more tonight, but, I had to try. I kept messing with the timing and it would run a little better each time until finally I can't adjust the timing any more due to clearance issues...however, it at least tries to fire on all 8 cylinders. So...I'm thinking I probably just have either the distributor stabbed wrong (I had it 180 out the first try...!!!) or the plug wires off by 1. Wow! That's all I can say. It sounds like a friggen top fueler!! I'm really excited to at least have gotten this far. I still have some work left to do, but...excited beyond all belief that it's FINALLY coming together and semi-runs.
Yeah, that was what I was going to try....but, I was so excited that it actually does what it does that I decided to call it a night and work on it tomorrow. I'll let you guys know what happens
Hehe...well, if it ran I wouldn't mind It sounds like a gigantic Harley Davidson...but, I don't have all of the vacuum lines and everything hooked up yet. I just wanted to check the fuel pump/ignition/starter wiring. At least I know it's getting fuel, spark, and turns over.
It tries to run, but, flames shoot out the headers while doing so...sooo close
Honestly, If you drove that thing up to me and told me it was a Ferrari, I'd be like..."ok" I wouldn't know the difference, tbh, just as I'm sure 99% of the people who see it on the street don't know the difference.
