ok here goes, a friend and I installed a comp cams 268 duration cam in my car yesterday, was told by comp cams it was a 420 lift, with stock lash pads i have about 2 mm left on the lifter side of the rocker arm pad on all of the rockers, so i know i will need to get some slightly thicker ones to center it, but it does run. its a lot more lopey than i thought it would be for such a mild cam. 110 degree separation. anyway, around 600-700 rpm, idling, i'm having what sounds like knock around the #3 and #4 cylinder area. when i first let off the throttle after break in, it idled at around 500 rpm, before the cam it was closer to 900 rpms. the cam sprocket is at the #3 setting, where it was with the stock cam. my timing was 14 initial. i have the 240sx tb and adjusted idle up to about 900-1000. it ran smoother with the timing set at 18 initial so i left it there, don't have but a basic timing light so i cant check total advance . i also have headers and full 2.5 mandrel exhaust, and cold air intake. car is bone stock internally other than the new cam. one other prob is i am running the zx dizzy with E12-80 module, new everything, fully rebuilt, including a fairly new vac advance from MSA. with the vac advance plugged in it will rev up on its on and stay around 2000 plus RPMs, or more, sometimes it won't do it till the first time you rev it, then it'll stay high. any ideas about the vac advance? what about the knock? thanks guys. PS, probably gonna put the cam on the #1 setting today.
edit: wouldn't hurt to say this is a 77 280z 4 speed, stock 3.54 gearing.
