Everything posted by Daeron
	Too Cool!!! Any better carburetor porn? I sure would like to meet the guy who first thought "Lets put SIX single-throat carbs, breathing through FOUR ports, on our Eight cylinder motor!" After all, it takes a little crazy to make good people. I noticed that motor had a non-crossflow head on it. I BET you could take a couple of RB heads, cut one in half right down the middle......................... ..but seriously, any chance of a video so we could hear that beast?
				DIY 180 Degree/Single plane/Flat plane V-8 crankshaft…
Daeron replied to BRAAP's topic in Powertrain
......so, then, it sounds like maybe getting a raw, un-twisted crank forging and having it treated and prepared for hi-po use might not be out of the question after all????? And where, in all this buzz, is the question?!! Racerstech: How did you get those cranks, from whom, for how much, and how long did Satan tell you before he came back to claim your eternal soul??? -
	I would, if I had any.. I was merely stepping back from the "anti-hybrid" stance on this chassis. Really, about the only thing that makes any sense in my mind would be to lop the front half off and go tube frame on it.... but then we once again run into the "but its chassis #935!" conflict. I have put that conflict to bed in my mind, for this case, and just wanna see that 4200cc, dual overhead cam, cross-flow'd headed in line six cylinder in an S30.
				need double check on VG alternator into '79 ZX
Daeron replied to Niku-Sama's topic in Ignition and Electrical
I was sounding kinda dickish last night.. but its kinda interesting. From what I have gathered, Fuji Heavy decided they wanted to make cars back in the fifties or so. They knew VW was doing great with their setup, so they sent some engineers over with a few notebooks, and the subaru was born. AFAIK they were always front engined, and i think all but maybe the EARLIEST were water cooled, but they were pushrod only until the mid 80s, they made one 1800 OHC 4 cylinder that was a direct link between the final 1800 OHV motor, and they also made a six cylinder variant of that OHC 1800. Then, at the end of the 80s, the EJ22 was born and that is all they have made since.. only NOW have they finally developed an engine that wasn't an EJ or a 6 cyl variant of the EJ.. blah blah, im telling you stuff I think is interesting because I was a little short worded last night. Good luck with your alternator swap, I'll shut up now. -
	Brian: The 1/4" difference in primary diameter yields these cross sectional areas: 2.074 in^2 vs. 2.761in^2. Thats about a 25% difference in cross sectional area, obviously flow capacity wouldn't increase quite THAT much but its fairly significant nonetheless. How much of the difference made in 1/4 mile times do you think likely due to the layout difference as opposed to this higher flow capacity? For reference, the primary sizes converted to metric are about 41.275 and 47.625 mm respectively.. I don't know what size exhaust valves you are using, and I am not trying to point you out as wrong by any means, just emphasizing the difference in primary size on your header change. Edit: I read that back through and even with my statement there at the end it still sounds like I am saying "!!!BUT NO!!! your exhaust was bigger and THATS why so you are teh n00b!!!!1!!" and that is NOT my intention. When I asked "how much difference..." I meant that question legitimately, not sarcastically..
				Second opinion regarding article about pre-ignition
Daeron replied to wondersparrow's topic in Nissan L6 Forum
I am just now reading this article, and its actually rather good. I've read at least a half a dozen different articles/groups of articles like this, and all of them are useful because each is a review and re-statement of essentially the same stuff..... --edit VERY good article... interesting illustration here: --end edit ...but whats blew MY mind (and inspired me to comment here) was the fact that I started saying to myself that the guy chose a poor font. It looked, at first, as if the "r" and the "n" kept running together and looking like an "m." Hence, instead of b u r n r a t e it appeared he was writing b u m r a t e which is two totally different things. So, just for S's and G's, I went to highlight one instance of the term "burn" to investigate. somehow, I picked one that was a typo and actually was (and I cut-and-paste) "bum rate" I'm going to sleep now. The world has treated me badly today, and that was the final straw -
	Thats the right attitude to take, without a doubt.. I just kinda felt... old I guess... when I saw the "new" pump. Sucks being a throwback; I'm not supposed to feel like an antique four weeks before my 28th birthday!
	hrmmmmmmm... Well, far be it from me to comment any more on how you fit it in there. Just make it happen and I will smile when I see the end result ONE OTHER point I will bring up... Subaru XT6s had Full Power steering. Now, that system required some liquid gold steering fluid which is now at LEAST as expensive by volume as R12.. but it required no steering column shaft. Any chance of finding a full power steering setup, or is that right out in your book?? (I can CERTAINLY agree with anyone who would write that possibility off without a second thought... I hesitate to even bring it up...)
you intake valve is open when the piston is at BDC. When detonation occurs with the piston at this position, you get a backfire out of the intake. KABOOM! -
				Orginal 1977 280z Droopy mirrors
Daeron replied to garyneedsz's topic in S30 Series - 240z, 260z, 280z
that doesn't sound stock, so there is no telling, really.. but there is oftentimes a screw hat somehow bottoms out at a pivot point. Look for a screw or a hidden screw somewhere on the back side of the mirror. If that fails, try pulling one off of the door to see if there is a screw on the under side of the foot. A picture of the mirror would be more valuable than a pagelong description of it here -
	that orange one is tits, go for it. Something about an orange 72... they're damn good cars, you won't regret it. I was afraid when you were talking about the rust, but the pictures don't look so horrible. Try and talk him down to 1900-2K on it, work the shabby paint, those pinstripe things on the side dont look like theyre in the BEST of shape so exagerrate that and say youd really need to have them either replaced or pulled and that means paint... make the car sound like crap and see if he'll take 1900.. but I like that car for that price.
	wow, that pump is as big a disappointment, as the car was a happy surprise. I haven't seen a "new" mechanical fuel pump in about 15 years, come to think of it. That thing looks sad... weird.
	whoooooaaaaa man, my heart, shes a thumpin...... d0000d.. D00000000D!!!!1!!!!1!! thank you so much for making this happen. I mean, I have heard VQ exhaust before, and I knew, intellectually, that I would see my S30 girl talking with that voice soon enough.. but now I SEEN it. Thanks. oh yah, and the unchained melody was a nice touch
	sweet, maybe she's not such a ding after all!!!
?? Except for the Justy, the XT-6, the SVX, and whatever 'ute they have with a six now, ALL of subaru's engines have been flat-fours.... its the ancillary equipment, switches, carbs, dizzys, efi hardware, lots of junk thats very very similar. I was even told once that there is a fair chance that some of our L-series cylinder heads were cast by fuji heavy under contract... and that was in response to a question of *mine* regarding the similarities between soobie heads and the datsun heads.. In any case, the point stands that subaru and nissan have alot more in common than any other pairing of japanese companies. -
	Well, Kevin, if you are looking at possibly SECTIONING the CAR to do this, I MUST suggest finding a different chassis to do it to... or, go back a couple steps, and look aat making the engine a stressed member of the chassis. Ever see the steering setup on a later model Honda Civic? The rack sits just in front of the firewall, about on a level with hydraulics on our Z, and the steering knuckles are welded to the TOPS of the vertical suspension members rather than the bottom. Yes, its a total redesign of the vehicle.. but... Sectioning chassis number 935 to fit the motor?? HybridZ, woo hoo, I'm with you.. Most of the time.. but actually cutting the car in half to weld back together around the motor of your choice? I'd think more on the lines of other ways of re engineering... I mean, its your project, and however you proceed will be awesome.. I wasn't wincing at butchering the chassis when you were talking of cutting tunnel and firewall, I just found my limits when I read "section the car behind the wheel wells...."
	OH MY GOD I just found this thread I had no bloody idear chevy made this motor, and now I am in love!!! ....And I had to stop reading and reply immediately to this because my guess is those wings are there to counter vortices generated at the extremes, just like in justin's plenum that got oh-so-much computer testing time and open critique and development with so many heads involved here. thoughts?? Edit: I have to confess.. I see this engine and get strange thoughts involving the chassis from say, a circa 1990 volvo 700 series.... or maybe even a bimmer!! Hmmmmm.. Seriously, I had NO idea this engine existed, and inline sixes just make me randy. (sorry, but its true.)
	No offense, my friend, but I believe it is your sister herself, who is the small ding.... THAT is definitely NOT a small ding. Don't forget that the 77-78 280 doors are wholly different, I couldn't tell what year your car was.
				Real ball bearing chinese turbo! $255.00 Would You buy it?
Daeron replied to RB26powered74zcar's topic in Nissan L6 Forum
It LOOKS like it was taken apart and re assembled on a bench by the seller. That alone, even knowing NOTHING about the seller, is a confidence-enhancer in my book. Remember the OTC quaife knockoff someone reconned and turned into a viable unit???? I say it can't hurt to get one if you take it apart, inspect tolerances and craftsmanship, and then put it in your car. In other words, treat it like a junkyard/NOS/mystery replacement unit rather than a $1200 brand new part from garrett.... -
	yes, it is, and there are threads to be found. Try getting less specific in your search terms, search N47 manifold and then scan through those thread titles. Look at any thread with more than 10 or 15 responses, even if the title isn't a direct hit.
oh yah, same thing through and through, just internally regulated. Actually, it (the soobie/hitachi alternator) resembles the externally regulated unit from my 75 in every way but clock positioning.. if there are any differences between MY datsun/hitachi unit, and the one in your ZX, then the soobie unit in question would look more llike mine than yours. The maxima unit (90 amp bugger that I have in my soobie now, and many others have in their Z's already) is nothing like it in appearance, but mounts the exact same. it IS slightly larger, but my soobie is far more restricted in space than any L6 Z I have seen, and it fit in there no problem.. just had to change the pulley to a V-belt type. Subaru/Fuji Heavy and Nissan did alot of parts swapping. There are many eerie similarities between my EA-82 subaru and my old datsuns, and I suspect the similarities only get more common if you delve further back into subaru history. -
	I don't know. Why don't you explore their website? I know my favorite way to source bearings on the cheap, and make sure I get quality parts. I thought I would share it.
I *should* have an informed answer to give you explaining all the vagueness about the wires, but unfortunately my understanding is too tenuous yet. How about I just say, I replaced the 60 amp internally regulated alternator on my 87 subaru (looks identical to the 280ZX unit, slightly different clock position) with the maxima alternator you are talking about, and all I did was splice terminals onto the cutoff ends of the maxima harness that plugged into my car's T plug. And, Yes, fatty to fatty, skinny to skinny. I just feel guilty that I haven't expanded my own understanding to include this stuff yet. BTW, if you do this and fry somethin, it ain't my fault, heh.. but yes, you should be right. -
				Is there a bolt on the bottom of the bellhousing?
Daeron replied to Mycarispurty's topic in Nissan L6 Forum
Yeah, you need to slide the motor forwards off of the transmission slightly before you lift it up very much. Lower the engine fully, lift it back up just a *little* bit off of the mounts, and get a crowbar to wedge the engine and trans apart. Don't force it TOO hard, and honestly.. its probably better to try the clutch first (Like Rags said above.) Thats actually a very good point Rags; thanks!
