32
Everything posted by Zetsaz
A musician's therapist (The $300 Z)
Zetsaz replied to Zetsaz's topic in S30 Series - 240z, 260z, 280z
Small parts updates: Exhaust: Have been upset at how loud the MSA muffler is considering how... not... aggressive my engine is. I ordered a Dynomax Super Turbo since I've heard they're decent quality and not too loud. Here's hoping it's a bit less obnoxious because right now even with the resonator it's still annoyingly loud (for my taste) until you're cruising steady at 3k rpm. Bumpers: I finally got an update that my bumpers are are arriving at the reseller and will ship out as soon as they inspect them. They've been stuck at port for a while now. Shipping industry in general has been very slow, so I'm not blaming it at all on Datsun Garage who have done an excellent job maintaining communication. AC Hoses: Decided to ahead and order the Vintage air hoses and drier. Shipped yesterday. Opted for the extended length. Most of the brackets/tie downs from the factory AC were all on the rubber parts, so I'm hoping it's actually reasonably tidy if I route them the same way. The extended length will allow me to relocate the drier up front or wherever it looks tidiest, since my fuse block that replaced the fusible links is mounted where the original drier was. IAC: Ordered the pigtail I need to wire the Jeep IAC. I've seen some people use a Bosch unit that's round, but I think my block will work for now and I'll still be able to mount it where the original ignition coil was. Thermostat: I've been meaning to do this for ages, but just never got around to it. When I was cleaning up the gaskets and replacing the water pump a few years ago I replaced the thermostat, but the parts store gave me a 160 deg unit. Finally purchased a proper 180 deg unit which will let the engine run better and actually give me heat on cool days. -
Meet the new spindle pin, same as the old spindle pin
Zetsaz replied to JMortensen's topic in Drivetrain
I'd have to go digging for the picture, but I just opted to have a shop pull them for me. Was worth every penny for my peace of mind, but when I picked up my stuff one end of the threads on both of them was crushed down about a 1/8-1/4" if that gives you any idea how much force was required to press them out. -
It's probably just poor color accuracy in the picture. I'd describe it more like a warm white, just like home incandescents which usually look yellowish or a very very light orange . I'm pretty sure the included LEDs are warm white instead of "sunlight" or a more pure white like what I installed in the dash. I could potentially replace them pretty easily, but I kind of like the contrast. I keep forgetting to take a pic while it's light out now that it's back together, but here's another from while I was testing. For now, the controls are mounted on the metal plate I had cut, but I really do want to mount them on a more accurate 3D printed plate I can epoxy or plastic weld to the HVAC panel. Cousin's printer went down after finishing my vent and the school's are still at warehouse since we don't have students back at the high school yet. Also, my turn signal switch fell apart after trying to repair it one more time. My $5 fix has been documented on here before, but I don't like the way it returns (or rather it doesn't), but at least the signals are reliable now until I do a more OE style fix that doesn't stick quite like this or just pony up the money for a really well refurbished unit. -
911s are weird mix of "it shouldn't be this effective" and "let's dump money at engineering to solve this problem" resulting in an amazing car that's better than just about anything out there despite that intuitively you'd think it shouldn't work with the weird weight distribution. My 2 cents, if you're building a Datsun to the extremes that you somehow need the Track attack or suspension that much different from stock, you're better off just racing a Miata or a Porsche. It'll be less money for a better car. You'd have to REALLY love the body style of the S30 to commit to that much of a change. A lot of people here have built amazing custom suspension, so no disrespect to them, but most people I see going to extremes like this on facebook or elsewhere rarely ever drive or even finish their cars. I'd rather be out cruising and having fun in a "just okay" car that looks great, and didn't cost me as much as a 911.
Honestly it's the same even with mine. I'm sure it has some hidden rust, but most of it was sandblasted before paint. There's no rot anywhere that I can see, so I've used internal frame coating anywhere I could reach to hopefully prevent rust problems, but it seems like the smallest bits of exposed metal can spread rust. I'm at a point where I just don't worry about it as much because I just want to enjoy it.
Despite the rust, my first shell was suprisingly complete... But did not have the compressor. I haven't bought one yet. Probably won't get it until spring. The original isn't great anyway, but the winter I've saved for anything inside the car. I don't have a garage and my carport is downhill from the alley so anything I have to work on for more than a few minutes outside the car or on the floor isn't a fun time. I'll check into adapters before I order anything! If not I'll check with a local shop to see if they're willing to modify my lines. -
The VVEL is exactly the issue, unless you have a VQ35DE in which case the later engines also have dual throttle bodies instead of a single one. There's no cheap clever trickery you can do to to just bolt up the engine where a VQ35 was. All the engine electronics have to be swapped over, and your electronics may or may not play well in the new chassis which is where at 350/370z group would come in handy. G35 isn't particularly expensive anymore, I'm not sure all the cost and effort would be worth it. Unless you're swapping the engine into some other fun project like an old Z like ours, you're better off just selling the engine and buying another G35 or 350z. If you have a manual tranmission in the G37 I'm sure the selling price of the engine/trans combo alone would get you most of the way to a decent G35. Google is your friend for kits. Major differences are what I listed above.VVEL and .3L extra displacement are the most notable differences, but it's different and more difficult enough that I can count on one hand how many people are using the vq37 in a swap.
This pictures make me so happy I opted to buy a better shell from someone out of Texas before doing more to the project. I despise rust. Work looks good so far though!
I made a grave mistake.. I forgot that Nissan used used metric fittings for the AC (because why wouldn't they?) and I can't just use the original AC lines for the engine bay unless I can somehow remake just the couple of pieces that connect to the firewall or carefully cut the crimped fittings off (?), sooooo.... Time to order an AC hose kit. It's just money right? Minor progress overall. Drilled holes into the plastic wiring harness block to bolt in the included relays. Only minor hiccup... My placement doesn't allow the wires to for one portion of the controls to reach. Instead of cutting and splicing, I'm going to make a short extension/sub harness, since I figure if anything goes wrong with that one control it'll be easier to narrow it down to an extension I can easily remove than deal with shorts or wiring in a cluttered space. Only have the two dash side hoses, 12v+ source, and switched ignition to connect and I'll be ready to get the dash back in and test! (Oh and technically that blue wire in the third pic for the compressor clutch, and a couple of grounds) -
Haha, true. Sorry to disappoint. As far as I'm concerned, what I have is better than the original ducting, the new fan is far better than the original, and each vent has a dedicated ducting all the way to the core. I don't know about you, but I've rarely if every had the fans cranked up even in modern cars. The Z is plenty small and some light airflow to keep things cool will be all I need. The lizard skin ceramic coating was already more than enough to keep heat at bay most of the summer except when the car wasn't moving at lights.
Looks great! Do you know what rear end gearing you have now? That'll greatly affect your cruising speed. I have an '82 ZX 5 speed in mine with a 3.9 CLSD out of a z31 turbo and I think 3k cruising RPM at about 70mph is actually a perfect spot. If you go too low on these they really just don't have much go. The torque curve on them is great, you won't have issues getting up hillls, but it won't really have the pep you might want. For my exhaust (before adding a resonator) it was also just above where cabin drone went away which made it very comfortable. I had bad cabin drone issues from ~2.3k-2.8k rpm. Your exhaust will obviously affect that a bit, but even now it tends to be the area with the most noise. I think your goals are very reasonable. Triple side drafts are great, but I'm partial to EFI just because I like driving mine as often as possible and not fiddling with carbs. I'm right in the middle of AC, so you can check my thread for what that looks like, but the brackets will be just slightly different for you since the dash mounting points are a bit different. Look up Pancho's garage for a nice install on an earlier model like yours.
This has become my philosophy for MOST of my build. Especially over the past year. Keeping this mindset has gotten me more progress on the car in the past year than in the previous 5 combined (that and spending lots of money haha)
Not just yet. I was debating hacking out some AC hoses for the really short pieces I need on the dash side or just ordering a kit. Most places locally didn't have any hose, so I've just sort of taken a break for the holidays. Will probably commit to a kit or ordering some by the foot by next week and get back at it. I only have like 4 wires to work out and the hose crimping before I can get the dash back in. and focus on controls. -
As jhm said, a lot of the track attack stuff is very much not final versions and has run into some hangups for some people. Ohm is great to work with in my experience but he straightforward about the fact that the included axles for the rear kit have been the biggest pain and setback as a company and the biggest reason some of these kits have long lead times. Hard to find truly reliable machine shops to outsource the work to. Don't bother looking into the Hell Z. It's been a whole year since any update. If you're very sincerely trying to go all out and have that sort of budget, it's the best kit you'll find at near "bolt in" status.
Making slightly more progress on the vintage air today. Struggling to justify buying all new hoses when I'm just trying to get everything to the bulkhead for now, and hopefully (if possible) reusing the original lines on the engine bay side. They already have good clamps right against the frame rails and formed bends in the hardline sections that keep things neater than I could make them. In the meantime, finally committed to just making extremely basic brackets to offset the included defrost vents. Will have to just deal with the fact that the original openings in the cowl piece won't be fully covered and that's okay. These couple pics are from the first test fit which wasn't enough to get them centered on the openings. Made some slightly longer ones on painted them for the final fit. Used two 2" to 2.5" adapters (from Vintage Air, but I ordered through Summit) on the dash to adapt into the stock side vents in the Z. just used a bit of the 2" defrost hose in those sections. The 2" hoses are VERY snug and probably won't slide at all short of a strong intentional tug from me, but I'm thinking I'll use a bit of black duct tape on the 2.5" section on the adapter. Some people have used clamps, but I think it's excessive and will add unnecessary bulk. Also didn't need to reuse the stock diverter pieces since the Vintage air has its own floor vents on the unit. Couple more pics to come! Up next is wiring, and the two AC hoses to the bulkhead and it'll be ready for the dash -
I'm at a 3.9 but I'm NA so it's fine. It's the only thing keeping the old engine fun right now alongside megasquirt making it far more driveable and clean burning than before. I know some people have had good success with CX Racing turbos, but honestly that's literally as cheap as I'd dare go. From a lot of reading, and one friend's personal experience, that's kind of the breakaway line in quality. Any lower and it's not worth your money. CX is barely manageable. If for some reason you REALLY don't want to spend the money on a proper turbo (which I think is the only right way to do it), I would look into what brands some of the cheap LS swap guys are running. Seems like they'd be the most in the know on what holds up for a low cost.
Any turbo from a reputable brand is gonna start at around $900-$1k for anything in modern designs, and more like $1.5k purchase price with your options. $500 is still the land of Chinese manufacturing, though at those costs, you're probably buying something that will likely work well, just not as well proven as a reputable brand. A $500 chinese turbo is probably completely usable for most people, and a HUGE upgrade in quality from the $100-200 offerings on ebay. You can probably find a new T3/T4 hybrid turbo from a reputable seller for around $800 with better specs than yours. Perfectly usable, but probably not much of an upgrade from yours if you're looking for latest tech. Your gear ratios are pretty low at 3.31. Might be sluggish. 280z stock was 3.54, which is actually roughly what the 350z has. If you're making decent power it might work well with the tight gearing of the CD009 but that still seems low to me. Others with more experience can chime in, but a lot of peopel prefer the 3.54. Highest I've seen on a turbo L series for the streat was 3.9 like mine from the "Medusa" Z.
Steve Bonk is your man on the cams. GT3076R is what I've been recommended as far turbos, and will likely never be too small short of a lot of work on your head and frankly excessive goals for an L series if you're still running a zx trans. The expense of a good modern turbo, intercooler, having to upgrade my flywheel/clutch/trans, then the associated mounts, is part of why i've reconsidered a swap. for now my stock block running MS3x is more than fun enough to just cruise around in.
Got my parts from my cousin. No control panel yet since his printer broke recently, but that's a final item anyway. Vent is perfect, assuming I don't run into clearance issues, and matching the original angle will let me flip it to get a smoother hose transition. Couple other oddball parts were supplied too like my distributor cap which is much nicer and has more clearance. Not sure I'll bother smoothing it yet, or even paint it, it's just functional for now. Vent is already drying from paint (cousin was out of black for materials). So far so good! Hoping to make slightly more progress this weekend, since I kind of took a break and haven't moved forward on wiring or anything else. -
This is the closest things I've seen done successfuly similar to what you're asking for. The S130 chassis is dramatically different from the S30. There's no grill that would delete your turn signals like on a 280z because yours on the ZX are integrated into the bumper. I'm not sure why you would want to do that regardless. Check out the rest of Bruce's videos too. He has one of the most tastefully modded ZXs if you're looking for some inspiration.
Looks like they've been looped off? On the bottom of your first image, is that hose heading towards the front of the car cut? I don't see the point if the heater core wasn't removed to drop weight. i'm far less familiar with the ZX unfortunately, but this guide might provide some info.http://xenonzcar.com/s130/auto2manualCC.html If your climate control wasn't working there's a chance the previous owner messed with things, but didn't follow through. There's a hose routing diagram towards the bottom, but it's more involved than just that. I would also get the FSM: http://www.xenonzcar.com/s130/fsm.php Short of stripping down to the bare shell and making everything completely custom for a race car, you'll be using that a lot. The vacuum diagram might help once you get things routed properly, and if it still doesn't work it might be that the climate controls were messed with per the guide above but just not done correctly.
@Neverdone That is a HILARIOUSLY bleak outlook haha. But it's accurate. @Subaruuuuuuuboii - take it from me, no build is a budget build. I paid $300 for the first Z I got. It became mostly a donor for engine and interior parts. I got the shell I'm currently in for $1200+shipping from another state. That's VERY Close to where you're starting with an engine and the car. I'm in my car $15-$17k after paint/suspension/STOCK brake replacement/Megasquirt ECU/upgraded differential/coilovers/body replacement stuff/wheels/tires. That doesn't count all the small hardware I keep having to buy and the engine block is still STOCK If I had ignored paint and body interior stuff completely and just did a high powered engine I'd still be at about $8-10k JUST for shell/engine/brake refresh/suspension/upgraded differential/Megasquirt/wiring, and I've done literally every bit of that myself. That doesn't even include what you'd have to do chopping away at the original car, custom engine and trans mounts, and a custom drive shaft, never mind either all new sensors on the engine, or new gauges that easily add up to $1k on their own. Unless you have big money to do an RB26 and somehow keep AWD, what you're planning is a sidegrade at best and will only make the car worse. Sell the engine or save it for another project, and spend the money cleaning up the car. I'm amazed this thread isn't already in the tool shed since it's not even related to Z cars, but it looks Neverdone and I are the only ones nice enough to explain the complications and real costs.
That actually sounds really convenient for some things! I will gladly dimension parts all day, half the battle for me is not knowing the software well enough. In my case I'm just lucky my cousin is an engineer and has a printer. I'm in no rush so I'll gladly pay him $10 total in materials and shipping in exchange for waiting a week since it's on his schedule. Despite the fancy parts and recent work, this is still a "budget" build after all haha. Would rather save the money for potential swap... with how much I've changed, I find it hard to justify dumping money at the L series. I'll either leave it as is and just clean stuff up and tune it better, or swap. Was pricing things out and a proper L series build to meet my standards for how I'd use it would cost about as much as a swap. Gotta save that money in case it ever happens haha -
That's a lot of money hacking away at a functional car for an engine that's basically a sidegrade. For the money spent, you're better off doing a full rebuild and addressing any weaknesses in your current engine with aftermarket parts and upgrading the turbo. The car would be just as fast if not faster, more usable, and cheaper. I don't know laws in Finland, but Europe in general is quite strict about engine swaps meeting engineering standards. Unless you have a Forester shell with no engine you're intending on using for racing only, it's likely far more expensive than you realize, especially if you intend to keep the AWD. Fully expect any swap to cost $5k USD at an absolute minimum, probably more like $10k.
