36
Everything posted by Zetsaz
280z speaker options- storage compartments, rear hatch, etc
Zetsaz replied to fusion's topic in S30 Series - 240z, 260z, 280z
An enclosure for two 6x9 speakers that replaces the taillight cover panel like the one MSA sells is about the best sounding option without extensive work. Think about a modern coupe or sedan you've been in. It almost always has speakers behind the rear seats pointed up towards the glass. It's a more than good enough situation for the majority of uses. Stock location points the speakers right at each other and doesn't have ideal acoustics. Speakers on the storage compartment is also okay, but realistically, you're pointing them straight up instead of slightly towards you and they're taking up as much or more storage space than a panel that replaces the taillight cover. Those rear speaker adapters aren't a bad option if you don't care that much about loud audio and just want something since they likely won't fit something as big as a 6x9. That said, they're probably a better option than the stock location since they're about as discreet and will probably fit close to the same size speaker, but are at least aimed better. Adding front speakers is the bigger hang-up since space is at a premium. Do you care about front audio, or do you just want some tunes in the car? -
Can confirm. For reference @A to Z, me and @Dat73z have very similar engine builds (as far as the turbo bits go), except I'm EFI with stock L28ET compression and I'm still at full boost by the low 3k rpm range, and some boost not that far off idle. At cruise speeds with my current gearing I'm going into boost the moment I push the gas pedal even in 5th. Around town it's not quite the instantaneous response my G37S had, but it's also lower displacement, lower compression, and doesn't have the modern VVL technology. With better compression I'm sure I'd be close enough to only notice if I was REALLY paying attention to rpm.
The issue with a build like this these days is that for the cost and effort you're really not getting much of a benefit over going with a modern turbo. The effort and cost to source or create a manifold for twins is more than creating a manifold for a twin scroll. that coupled with modern ball bearing turbos that spool faster and are more efficient than old designs means there's not much benefit (or at least not enough for most people to justify the increased cost and complexity) That said, Todaro Racing did a nice twin turbo VQ37 build, and Koshikubi engineering out of japan has a REALLY nice Twin L series being built right now that could provide some inspiration you can find them on instagram @koshikubi_engineering
Looking sweet! My apex subframe is on the way as well. Taking advantage of their sales. Figured I might as well go for it when I'm installing the new T3 steering rack and have to realign everything anyway.
What year is your vehicle? Hard to help without info since some things changed over the years, and may be different across cars with/without AC, and with/without California emissions stuff. You don't need special batter cables, the batter does lead to the fusible links, but not directly. Positive end goes to the starter which goes to the bundle splitting into the fusible links. The fusible links are basically an old version of fuses, but they don't go out in the same way, so sometimes it can be hard to tell unless you measure resistance and continuity across them. Most people upgrade the fusible links. There's an example on my Musician's Therapist thread where you can see how I did it, but also here: https://www.atlanticz.ca/zclub/techtips/fusiblelinks/index.html
A musician's therapist (The $300 Z)
Zetsaz replied to Zetsaz's topic in S30 Series - 240z, 260z, 280z
Holiday sales update: Those of you who know me know I've been very into photography lately. Recently Fujifilm announced their new X-T5, and I was tempted to preorder it as an upgrade to my X-E4 but decided that I didn't need the upgrade features on it for what I do (at least not now). So that money has gone towards black friday sales on some parts I've been craving. -Just ordered an Apex Engineered front crossmember. Already have the T3 steering rack waiting, but on top of the worn out rack, the bump steer and front geometry was not confidence inspiring, the rack will be fixing the bump steer issues as well as improving the front control arm angles, which are pointed up towards the outer ends even at my conservative ride height. -Debating ordering a Protunerz intake for their currently pretty nice discount. Other than the increased flow, I like the angle and clearance it provides to make things easier to work on, but more importantly, the built in provision on the throttle for the GM IAC valve I already have would be nice. Only downside is having to drill into the brand new flange to clear the cylinder head mod. Still thinking it over -
Removed HVAC system. Do I need to block off air inlet?
I replaced my oe system with vintage air and the open hole has been a source of frustration. Can't remember which, but one of the European datsun builders actually 3D printed a replacement that fed into the vintage air system. I can confirm after several thousand miles (including round trip down the entire Pacific coast a couple Aprils ago) that you will have plenty of airflow into the car through that hole. In the mornings when it was cool on my pacific coast drive I had to have the heater on all the time. You don't notice it much as driver, but you get a cool breeze on your feet on the passenger side (or a hot breeze if it's summer). I attempted to just use some heat shield/insulations stuff, but a single drive and the air pressure behind it blew it off. You'll need to cap it off by taking the cowl panel off, or create some kind of plate from the dash side, either way you'll probably be drilling a bit. Only non-intrusive solution would be something like the 3d printed panel feeding into a new fan setup. -
Hmmm... seems my post didn't include full comment. I was going to say the one area of concern would be the door to fender gap. Maybe it's just mine, but something about the hinge design had a tiny leading edge rub on mine at first when it was reassembled even though the gap seemed right. I would double check your clearances there before committing to a number, with enough tolerances to account for future paint.
unmeasured... bit scared to haha
I'm with you on preferring the more subtle look. Painting is fine but I knew that's what I wanted from the beginning and got my Mishimoto intercooler in black.
Gotta have something to do to keep me warm in those Utah winters haha. Honestly have rarely been quite this excited about a new product. So much of "this other part number works" and limited info on rebuilding these. Something new and ready to go out of the box is a welcome treat considering how much I'm a bit burned out on rebuilding stuff. There was another one last night! Again I'm far enough away to not really experience damage, but it was enough to make my bed feel like a hammock for a bit before evacuating my building. Almost felt like I was being rocked to sleep before my sleepy brain finally realized there was something I was supposed to be doing haha -
Yes, I'm referring to the small slotted piece on the top rear that bolts to both the compressor and the main bracket. It's hard to tel if the small piece was used strictly for cost or if the curvature on it is strictly necessary to avoid fouling on the compressor, but I did see the turnbuckle on someone's (maybe on. instagram?)
Some "professional" shops are professional mostly because they have the tools to do it quickly and functionally, not necessarily pretty. There was a guy close to me in Washington that had a really impressive setup with hardlines on his car, but he doesn't offer that to most people in his shop just because it's much more pricey and time consuming. @rossman I have the same AC mount, and I actually recently saw someone who replaced that rear piece with a turnbuckle. Seems like it'd be a good solution for proper tension. I'll probably try to upgrade that bit on mine when I'm home this winter even though my lines aren't done.
A mild update from the faraway land of Mexico: My new T3 steering rack arrived yesterday! Brother sent a picture and took the car out for a quick ride. The stock rack was worn and would have been very difficult to fix up. On top of the slower steering ratio than a 240z I had a sticking point just outside of center that prevented me from tightening it up, so it always felt a bit sloppy, even with brand new steering and suspension components everywhere else. In unrelated news for those who care: yes I was close enough to the earthquake epicenter down here to really feel it, but no real damage to anything where I am. Someone somewhere probably had some glass bottles break. It happened only a few hours after we had a scheduled evacuation drill at my school... long day haha. -
Yeah, no way I'd do it if my commute was longer than a few miles. That's actually part my beef with US cities, everything is soooo spread out. Realistically I could walk a block or two away for my basic grocery necessities even. if I want a snack or a bit there's literally a tiny shop across the street from my apartment building. A Jimny would be so rad. I see them everywhere down here. They're well past the initial run they did to test the market and they're always in low supply at dealers. Are apparently super popular. Yeah, I'm at a fairly nice American school here. As a location (other than the unbeatable natural beauty of the pacific northwest), for my social life, and as a job this is way better for me, but specifically as a music program it's a notable downgrade. I'm teaching middle school with no real team like i used to have and the past few years have killed the program a bit. BUT, that does mean I have some flexibility in how I approach it and I get to start most of the kids totally fresh. -
Mexico is solid! My new wheels are a Marin hybrid bike. Aluminum frame, hydraulic disc brakes, all that fun stuff that I've now kitted out with everything I need to commute on bike. Minimum 2 years I'll be living here. After we'll see. No car right now, we'll see how long that lasts. Will either bring down the hardbody or buy a new Jimny if I stay here for a long time. Z will probably not come down Guadalajara is a pretty well developed city, especially by latin american standards, but a lot of speedbumps would be killers down here, and I trust most drivers in the city here even less to not completely destroy my car in an accident. The upside is i'm saving a ton of money not insuring another car or paying for gas. Will be my summer car every time I visit family. First purchases I have planned for next year are the new T3 steering rack, Z car garage brakes, and if I'm saving a lot more than expected, new flat top pistons to up the off boost performance below boost. -
Pretty sure mine is seeping from the same area, but much more, and it's driving me insane.
Realized sometime during 4th of July weekend that I had a cylinder not firing. Seems like one of my ignition coils was toast, and the plug was fouled as a result. I replaced the coil and plug, did some retuning of the fuel map with autotune and it's running much better! Averaged 19mpg on the way here from WA, which I thought was low. I had assumed it was just the conservative tuning on the megasquirt to run slightly on the rich side coupled with my 3.9 rear end, but it still seemed unusual for a turbo engine. Did a datalog on a drive to SLC with a friend and averaged 23mpg after the fix! That's without trying to baby it. Was over 70 or over 80mph depending on the section of the interstate we were on as well as a few strong pulls to near redline on the on ramps. Pretty sure if I keep the speed down a bit and don't gun it I could get 25 mpg highway 😎 Very satisfied with how things are turning out so far, just need to redo my exhaust hangers and hopefully it'll solve my little rattle. Only a week until I head to mexico though, so it might wait. -
That's looking really good! I like the really simple tab you used for the hanger farthest back. On my old exhaust I had a hanger on the exact spot you're using for the center. My vibration problems seem to be unrelated to the exhaust, however, so I'll have to check if a CV is going bad or something else is fouling. Deleted the front diff crossmember with the z car depot billet control arm clamps and the noise is identical. Can't get the thing to bump no matter how far I make it swing. Next upgrade really needs to be some electric fans like yours.
A few select shots from this year's cruise-in. The car sure has come a long way! Was excited to have my brother join me in his MR2 even though his is still even more of a work in progress than mine and isn't quite as clean. Still a looker. Expecting clamps to delete the front diff crossmember soon which will hopefully solve my exhaust "buzz" problem. It's no longer a rattle but still a bother. Will likely still redo at least one exhaust mount to a more solid style with a rubber or urethane washer on a through hole instead of a rubber hanger to limit movement -
Great to catch you too! Despite my little gripes like the small exhaust rattle and the constant work in progress nature of the thing, it's REALLY satisfying when other people enjoy it. I forget that even with the spots on the paint that aren't perfect it's still definitely a looker. Haven't seen it in bright sun in a long time and it's very fun right now 😁 -
Your "more vibrations" is probably still way less noise than the buzzing I'm hearing currently. I'm sure it'll be great!
I'm here until I move to Mexico! Third week of July I fly down. In the mean time I'm attempting to relax with family while also taking care of figuring out housing down there and submitting the last bits of employment paperwork. -
Made it to Utah and have my car in the Cache County Cruise-in Drove 800 miles yesterday.... Only to find out that my less than stellar mpg was because I've been running on 5 glorious cylinders. Averaged 19mpg, which i thought was low for my setup and turns out i was right. Coil pack failed and fouled a plug. Replaced both today and even without adjusting my fuel map it feels SO much better Hoping to do a bit of road tuning after filling up tonight and seeing how much better I can make this thing feel. The increased smoothness on the engine even lightened up some exhaust tapping that was driving me nuts. Really only hear it on right turns right now which is more reasonable than any time I'm under load. -
I'd love to see some better pictures of how you have that braced. I have some rattling on mine in that area that's driving me nuts. So much so that I'm willing to get rid of the front diff crossmember altogether since I have a top mount. With my resonator in the middle I just don't have great clearance if I drop it too far (and with the angles it has, dropping it too far leans the pipe towards the driver side of that little opening where it's already bumping.
