36
Everything posted by Zetsaz
I would start by specifically not redoing literally everything. Videos online make people think this is like legos and things can get put together quickly. There are almost always hangups. Other than the engine rebuild, I would recommend seeing which stock parts absolutely need replacing and start with just that. Get the engine finished and drive as much as you can and see what sticks out that might actually be worth upgrading to you. There's nothing worse than tearing a car down then not getting to drive for several years because you can't keep up with everything you took off. Unless you have the budget to just dump at everything T3 sells and brand new interior parts all at once, it's just not worth trying to rebuild everything all at once.
A musician's therapist (The $300 Z)
Zetsaz replied to Zetsaz's topic in S30 Series - 240z, 260z, 280z
First project now that I'm home is getting the new ignition coils in. Just had to swap out the stalks along with the new spring provided by Duffy. Taped the harness I got in two spots just to keep it a little tighter. I'm not the biggest fan of wiring that branches off in only one section, much prefer it to T off in multiple spots as it goes down the line, but I know that's a lot more time consuming. Regardless I'm actually really happy with the little subharness I got. A few pics included here show the shorter stalks, taped up, finished fitment and the before and after. Already got the dwell times adjusted. Updated my megasquirt firmware for the first time in 4 years, and did some very mild adjustments. Feels like it's running much smoother than before - maybe that's full placebo effect happening, but even if the actual performance difference is negligible, I'm WAY happier with how much tidier and more serviceable this is than the previous setup. Second mini project was just 30 seconds of adjusting the dampers on my coilovers. I softened them up after reading a post. I think I was overdampened for my spring rates, especially at the front and small but abrupt dips and other holes felt like they were pounding the whole car. Feels much smoother now. I think I'll be doing a lot of small projects again while I'm here, but I think within the next year I want to completely upgrade all my wiring, move to a nexus R3, switch to electric fans and reroute the hot side intercooler piping, and color match the engine bay to the exterior while the engine is out to rebuild with flat top pistons. In the meantime I'll cleanup major spots that need some attention and tidy up anthing from the transmission back that's causing little rattles or discomfort. -
I ground down that same section of the diff. Don't think it should cause you any issues
Heading back home in just a couple days for easter and passover weeks. I... mostly... certain I have all the parts I need for the ignition upgrade and some new seals. As far as planning goes ITM flat tops are back in stock momentarily so I immediately snagged some from Rock Auto. MXN to USD exchange rate is very in my favor right now, the total shipped was about $240. Full $70 or so cheaper than just the list price from other vendors like Z Car Depot and waaaay cheaper than what some people are asking for on ebay or in facebook groups. Unfortunately swapping the pistons will probably require a full rebuild. Debating if I pull the engine my second week around and just go at it for a couple of 12+ hour days to get it done and back in or if I wait until summer. The other option is pulling the block before I leave and just dropping it off at a decent shop then just have a family member pick up the engine whenever they finish it so it's ready to drop in when I get back this summer. We'll see... I was excited to just get at it until I remembered I'd also need to pull the timing cover and all that entails, it'll be better to just rebuild when everything is ready to go. -
Most of this looks pretty great, but that mounting on the camber plate to the strut tower isn't exactly confidence inspiring. Is there no way to swap out the top of the coils to fit better?
- 91 replies
- suspension
- 240z
- (and 5 more)
Good stuff to know! Once I get spark fixed with my new coils I might toy with the trim for the first 3 at idle and see if it helps even more. Idle/cold starts/warm up enrichment always feel like a mess to me
I will take you up on that! Small update: Slowly purchasing little things here and there again. I'm not happy with my LS coils slowly going out and even less happy with my bracket. Granted the placement is better than most i've seen. I REALLY don't like how high up on the valve cover the Protunerz one is. Mine normally goes where one of the heater hoses is, but I'm retaining stock function and moved it. Between those problems and having to buy new coils soon I chose to upgrade to Nissan coils. Got the bracket from @DuffyMahoney and ordered the Hitachi coils from RockAuto. In a few weeks I'll hopefully get a chance to work on it again. -
I did something very similar a few years ago, but I had the tabs to bolt it in in the same location as the original, and I kept the same angle on the rear inlet as the stock piece. It flows okay as well, but it tends to flow mostly out the center. I had some help with this design since I'm a complete novice with 3D modeling software, but if I could do it again, I would add some kind of center diverter to prevent the air from just flowing into the center and actually directing it slightly to the side to each vent.
Are you sure you didn't have a Jeep stepper? Looks almost identical but the pattern isn't the same. I had both on hand and realized the bolts don't line up on a Jeep stepper despite being a nearly identical part.
I think he might have short injectors on there. The protunerz page specifically says not to use those. He's testing the clearance with the injectors instead of the supplied brackets which would have clued him in to why it's too close to the thermostat. Not to knock on the guy, I'm sure he got it figured out, but definitely seems like typical videos people post hoping to get some internet clout instead of spending their time actually working things out. A lot of folks on youtube and other social media tend to post these long videos before even asking the supplier about their issue, instead of posting the result then mentioning the problems they ran into and how they were solved.
What was painful to watch about the videos? I feel like this intake is not that much different from installing a different oem one. Only thing you have to change is where some vacuum is going to. Well, I guess other than the cable throttle needing to be installed.
Didn't do a whole lot while I was home for Christmas like I was hoping. Since the weather was so unusually warm and no much snow (and consequently not much salt on the roads) I couldn't pass up the opportunity to take the car out for some cruising. Here are just a few of the updates Found the mats I thought were missing! DID replaced the horn retaining ring, but not sure how I feel about how tight it is. Don't want to glue the horn pad to it just yet in case something chips. Already has some small bits if it flake off when removing the original ring, but at least now it doesn't fall every time I hit a bump. Installed only a small handful of shims. Realized most of them are still good. I think if I visit this spring the big work will be finally fixing the seals on the hatch and adjusting it properly. Right now it tends to pull back on the seal. Ugly and makes it inconvenient to use since I have to tuck it back. Also broke my IAC valve running it through test mode in tunerstudio somehow... woops haha. Blew the end off. Put it back together but now it won't go in or out. Also bought a proper reproduction windshield washer bottle Biggest mishap... found out one side of the bumper hasn't been hanging on to the brackets at all. Probably broke early on. It's just a few tacks holding it on Gonna fix with epoxy when I get back. -
A Excellent Video on A Complete Body Restoration of a 240Z car
Zetsaz replied to toolman's topic in Body Kits & Paint
Even my "rust free" 280z had the floors replaced at some point (poorly, I might add). I'll agree with you here, it's so worth it to find a body that needs as little work as possible. His example in the videos is FAR better than most and still required some patching to get it to a high standard. Very impressed with his videos and the work on the hood though. It's almost motivating me to replace my floors properly, now with properly reproduced seat supports that weren't available when I made mine out of square tubing... slightly less tempting now that it's painted though haha. -
They seem pretty reliable. Honestly I don't trust any of the current suppliers for carbon parts.
Thought this was pretty intense and honestly really well done. https://www.motortrend.com/events/datsun-240z-tesla-restomod-ev-sema-2023/
Wide body would be slightly better if the rear arches were higher. They seem to sit very low. Considering the rest of the work I think they just kept them even with the front, but with that hump in the rear it looks a bit awkward. Same thing happens with ZG flares honestly. Lots of people place them too low. Pretty impressive otherwise. Only the second functional awd I can remember seeing. Both with american v8s
Makes me wish I hadn't tossed my originals. I don't like the way the rear one mounts on the 280z, but I honestly don't have much of a need of stiffer sway bars. At best I do a bit of canyon driving and I'm probably too scared to slide off the road and ruin all my time (and money) to really push the limits. As far as the transmission mount goes that looks correct. Like @madkaw said it definitely flexes a lot. When I first installed my 71c transmission it had enough flex for one of the bolts to put a nice gash on the side of my shiny new T3 trans crossmember. I still have the original and it's honestly not bad with the new Kameari engine mounts since now there's not much side to side movement and the trans mount really mostly needs to be fore/aft isolation. If you're not trying to go solid mount or find a stiff poly alternative you could do what I did for the engine mounts and buy a Kameari mount. Supposedly 1.5x harder than OEM but still rubber. I might be doing that when I pull the trans to fix my rear main leak. I'm honestly very happy with the compromise between OEM and poly on my engine mounts
Is that an ST front sway bar? Doesn't look like you have spacers on it. Do you have any issues with it fowling against the frame rails on the outside? Mine seems to rub and it looks like if I hit a particularly rough bump I'd probably just slightly bend the pinch on the outside. Right about where it curves to the rear it just touches.
Honestly wish I'd stopped by during my pacific coast cruise, but that was around peak covid time so I was just camping out of the Z on the way to my brother's in LA. How are the KWs vs something like BCs? What did you have before? My only complaint just by looking at them is that you can't set preload independently and change ride height with a threaded body like the BCs, but I honestly don't know enough about suspension dynamics to say if that's that much of a difference at the end of the day. I think for an old car I'm actually not too noisy, but on bumps the pillow ball at the top coupled with the camber tops being metal right onto the metal of the car adds more noise than most things. I've almost been tempted to create at least a little poly "shim" between the coilovers and the strut towers so it's at least not metal directly onto metal.
Am I reading this correctly? Despite being on adapters and worn out OEM seats you were able to get about 2in of extra head clearance?
That's my thought. General feedback I've gotten from people who actually drive their cars a lot is that the T3 or really anything by Wilwood is mostly just fine. I'm at a point where I'm okay spending a bit more for great instead of still paying a lot and potentially ending up dissatisfied. You're gonna be really happy with the T3 steering rack though. Best thing I've done so far for driveability.
Assorted small purchases over the past month or two as we slowly prepare for winter work: OEM Rear main seals - might not manage these over the winter but they'll at least be available. OEM oil pan gasket Horn pad retaining ring (see recent post for details, mine's been cracked and the horn button falls between legs on hard bumps) Differential axle clip - realized my right side is missing. Not sure if it stuck to the half shaft and I didn't notice unlike the other one which stayed in the diff, but needed new one. Pinion Seal for diff - splattering fluid all over my nice stainless exhaust and gunking up the underside of the tunnel Skillard shim kit - includes door latch striker shims, inspection cover shims (actually necessary for me), door hing shims, rear hatch shims (super grateful for these because the actual oem ones seem integrated and I've just had the hinges right over the gaskets). Skillard rear speaker brackets - kept trying to find an original to copy, but for the prices people were selling it wasn't worth it. Glad skillard made good aluminum reproductions for both sides. Still debating on which receiver to use and whether or not to bother creating a 3D printed bracket for a single or double din to replace the original. Skillard door handle backers - I very very carefully pull down and out every single time I use my door handles to get in because the small amounts of flex are enough to get the top of the handle to rub the paint when I'm opening the door. I need to open up the back to slightly bend and fix the passenger side lock rod anyway, so i figured I'd get these along with the batch of new parts. No oil cap gasket yet. Still debating if I buy the cheap seal, or use this as an excuse to get some more bling for the engine bay with an all new oil cap. At some point I need to powder coat the valve cover soon. -
Daaaaaaaaaamn, the KW bits look good! Getting your ZCG brakes is just motiving me to finally pay up for the upgrade.
I'm with Dave here. Don't use silicone on threads. The white thread sealant I've been using has been great. I use the liquid one and make sure it's slightly tacky before threading like the instructions say. I really think it's just that npt to an adapter not being tightened enough. The problem was it was only leaking once it got really hot on the long drives once the coolant gets really hot and thinner, so I hadn't noticed it on my shorter test drives.
