53
Everything posted by Derek
I have these as well as the Spal central locking system and couldn't be happier. Smooth quiet and fast. Derek
Fuel lines....will they work for fuel injection?
Derek replied to jacob80's topic in Nissan L6 Forum
It's been a while since I did mine but there's a large diameter (3/4" i think) nipple on the top od the tank. I ran a 3/4" fuel hose from that through the car and into the filler neck. Derek -
Did they vent the tank to the filler neck? If not this may be a problem. Derek -
It's kind of hard to roll the amperage up and not move the torch. I ended up splicing a momentary contact button in. This way I would use the button for on-off and the rheostat for trimming the amperage. I mostly welded aluminum so button welding was my method of choice anyway. derek
Got this beauty back from the foundry today The internals came out exactly like I wanted. Now if I just had some free time for machining. Derek
Well I'm above you! I'm not sure if that's a good thing though!!! Derek
Hi Pete The two manifold balance tubes are connected in the middle with a hose. So I should be ok adding vacuum from one side of the manifold. Thanks Derek
Ok I went back and re-read every single post on this build. One thing that jumped out at me was that I may be screwing up with the way I'm introducing idle control vacuum. As it's designed right now I'm just dumping it into the balance tube at the end of #6 runner. I'm starting to think this may be a mistake as this will cause #6 to run lean. Would a better solution be to run 6 individual lines to each runner to introduce the vacuum. I haven't machined the log yet so this would not be a big problem to do Any thoughts on this Thanks Derek
Josh you crack me up! It will be interesting to see the graph after I post a video of it running. Derek
How does one get the girlfriend in the loud "scary" Z car...?
Derek replied to josh817's topic in Non Tech Board
Josh I'm 49 and have had my Z since 1980 or 81. In that time I've had 5 or 6 girlfriends and one wife. The wife loves riding in the Z and there's never a question as to what car we're taking when we run errands together. And that's why she's the wife and the others were girlfriends! Derek -
Hi Phar Well it really looks the same as in post #226 except the butterflies are in and there's springs on the bottom of the shafts. Install is going to take longer than projected. The only way to do the heat shield is remove the header from my car and mount it on to my mock up head with the manifold. Then I can accurately fabricate the heat shield. Also I'm not going to put much time in cleaning the engine compartment as I have to pull the head eventually so I'll just wait for that. I have a major list of things I need to do on the car at the same time so the cars going to be off the road for a few weeks. And work and reality just got in the way. I pretty much chewed up all my allotted time and then some! I need to kick out a few patterns and then I can get back on it. Probably going to be the third week of January before I can install the manifold. Sigh....... At least with the throttle springs on I can periodically walk by, snap the throttles and go "woomba woomba". Hey it's all I got right now! Good info an good advice! Fortunately it will be cool here for a few more months so I won't have to deal with it right away. Seriously my SU's are such crap none of these problems are going to be any worse than I'm dealing with right now. Derek
A central distribution block in between the manifolds would be cool but being as the lines are done I'll be sticking with what I have! I'll be using a fuel pressure regulator at the distribution block with a return line to the tank. Well I made some good progress today. All of the butterflies are installed, The return springs are installed, and the linkage is adjusted and installed. So technically speaking the MANIFOLD IS DONE!!! I think. I still have to put in the vacuum stuff but unfortunately my parts didn't arrive yesterday. But all of the main machine work and assembly is completed. I'm also about halfway through the surge tank. I'll finish it up in the morning and then jump on the vacuum log when it arrives in the afternoon. We're almost there! Derek
Well I got the fuel lines done. Man That was tedious! The clips I ordered are nice but they have a molded strain relief into the plug and they will hit the fuel lines. I ordered another set that just has wires. Soon as I get them I can make the injector clamps. The foundry cast the vacuum log today hopefully I'll get it on Friday. Still to do: Machine fuel distribution block. Machine vacuum log Machine injector hold downs Machine and fit butterflies. Figure out return springs Work out PCV valve Make surge tank Yea I'll be done in January....January 2010!!!
My mom lives in Jupiter and I'll be driving the car down to Fort Lauderdale as soon as it's running well. I'm sure I can figure a way for you West palm guys to get up close and personal with my manifold....Ok maybe not that close and not that personal.... I wouldn't go that far! But I have burned up a fair amount of gray matter on this thing.
Here's a little teaser! I'm still using the too tall caps for the mock up so the lines will drop down about .25" or so. There is a .75" gap between the lines and the valve cover. I test each flare at 125 psi before I do the bend. I hope this works in the summer as it get's pretty darn hot . Derek
Hi Phar I have a real concern that the gas may boil but the look of it is so cool that I had to try it. If this doesn't work then I'll run short stainless lines to a fuel rail and have more of a traditional style delivery system. I tried flipping the air filters around and it just doesn't do anything for me. I personally like the way it looks and the air filters will be an option. I domed them to get the most surface area I could. This is one of those "see how it works in application" deals! Derek
Here's some really good spray glue at a good price http://www.glueplace.com/1081-spray-trim-adhe.html
Anyone have any experience with these? http://www.expressfuelpumps.com/autoteq-adjustable-fuel-pressure-regulator-universal-p-3802.html Thanks Derek
I would get 2 rolls of this http://www.raamaudio.com/cgi-bin/index.cgi?p=pr Derek
I need to buy one! like everyone I'm looking for something nice but cheap. Must be silver in color. Can anyone recommend a brand. Thanks Derek
Yes i have a low pressure lift pump. All right then everything in the top. That makes it a lot easier. Thanks Derek
Hi Pete It's an external tank. mounted in the rear. My only thought on dumping everything in the top was at extended idle situations won't there be the potential for the fuel to get kind of warm since there won't be a lot of replenishment from the main tank. Thanks Derek
Last week I made a set of press dies to form the air filter screens. The dies came out great but I wasn't at all happy with the results. Since I don't have any parts I decided to work on my technique and see if I could come up with a workable solution. Needless to say I'm very happy. They look exactly like I had envisioned and you can't ask for anything more than that. At this point I think I'm going to retain them with an oring stretched across the front of the screens. Now I need to make a set of dies to form the inner basket to support the foam. I sure am glad converted that lathe to CNC! Derek
Ok since nothing showed up UPS on Friday I"m kind of at a standstill on the manifold. I figure I'll get started on the surge tank next. I've got some 4" ID 4 1/2" OD aluminum pipe in stock. The plan is to make a surge tank that will house an Walbro in-tank pump. I'll weld in a flange that's drilled and tapped and grooved for an o-ring. The top plate will house the fittings as well as the insulated lugs for the fuel pump wires. Should I put the bung for the inlet on the side towards the bottom so that cool fuel from the tank is supplied to the motor? Derek
Actually I temporarily removed the block heater when I installed the EDIS and have missed it ever since. The car is harder to start, runs poorly, and get's terrible mileage since I only drive 3 miles to the shop. I haven't put it back in yet because I was waiting to finish the EFI install but it WILL be going back in! Derek
