Alright, my wheels came in last night, no tires but here they are mounted.
The fronts are kind of a tight fit, I'm not sure what size tires to run. Theres about a finger width of clearance between the coilover and rim.
The wheels are
17x9 24mm offset
17x10.5 20mm offset
I should be getting these in the mail early next week. I think they'll look good.
17x9 24
17x10 20
Thinking about powdercoating the center hyper black or maybe gunmetal.
The Ford short shifter can only be used on the turbo models which used a t5 transmission. Non turbo is different. I don't know of any available for the zx, but I think I read somewhere that a s30 short shifter could be modded to work.
Be sure to check all your connections, especially the cylinder head temp sensor in the thermostat housing. That cause a lot of problems if the connection is poor or the sensor is just bad.
Try Dave at Arizona Z Car if those don't work out.
http://www.arizonazcar.com/510brakes.html
Had the 12.2 in. rotor/ 4 piston combo on my last set up and it worked perfectly. Fitment was not an issue.
Scroll down to the bottom for a few pics:
http://www.cardomain.com/ride/2281236/5
Yep, thats how I ran my turbo conversion before I actually bolted on the turbo. Flat top f54/p90 head with 82 electronics, ran beautifully. But yea, with the lower compression it will be a little sluggish. If you're in a bind, it'll work.
Hey, what year axles did you end up using? I just installed 88t stub axles and into my control arms but didn't get a chance to snag the right axles. I'm hoping any later turbo z31 will work with my 3.54 r200. Btw, my 17x10.5 wheels are gonna need a small spacer to clear.
