Leon
    25
Everything posted by Leon
  1. I use two screwdrivers on either side of the flange, so that I'm not binding the shaft. Pops right out.
  2. Springs are switched, they put the front in the back and vice versa. To double check, look at the part numbers on your springs. The fronts should end with a "1" and the backs with a "2".
  3. Good work Ross! Are those Panasports I spy?
  4. I believe you can wire in an HEI module in case your factory module fails. The diagram should be around here somewhere.
  5. Thanks! You're car is very nice example, and it was nice meeting you. I didn't hear about the drive, but I'll be working on projects tomorrow. Might take the S up to Skyline if I get a chance, though. :D
  6. Not a problem. Like I said, if your reason for building it is "just because" then no one is stopping you. Do what makes you happy. Let's just keep false premises to a minimum, it's how myths are spread. Thanks for taking in the information with a level head instead of getting defensive and combative, as most seem to get.
  7. 1. Check wheel balance, make sure all fasteners on rotating components are properly torqued. 2. Look up the "EFI Bible", check out Tech Tips section of atlanticz.ca 3. Brackets, answered above 4. Search, "shifter bushing" 5. Dave Irwin rebuilds them 6. FSM, download free at xenons30.com
  8. We are not purporting that we know best. We are providing you with facts supported by empirical evidence. Others like to go on so-called "theory," and use it to make all sorts of proclamations. In other words, bench racing. Look at the evidence and judge for yourself.
  9. I've been considering Dunlop Z1 Star Specs and Hankook Ventus R-S3, which is cheaper than the Z1SS. They're probably not as grippy as the ones you mentioned, but those are the tires I'm considering for street/autoX/light track duty.
  10. Part of the reason for my recent trend of little Z-work:
  11. Brady, I'm embarrassed it's taking me so long! All that's left is mouting the box and running the wires. I need to find where I put those nice wires and shielded cables that I bought and make a relay bracket. Then fix the laptop and we're ready to go! In regard to Weber driveability, I've spoken to Keith Franck (from Sidedraft Central) and will be coming by his house in the near future to test out his new custom e-tubes and idle jets (yay for being local!). Those, along with Megajolt should make this thing run as well as a triple-carb'd engine possibly can! Damn, you have me motivated now! I need to get at least some of this stuff done, THIS weekend.
  12. I'm talking about the picture that shows what center and offset mean: pipe inlet and outlet locations.
  13. You mean the L20B? That's a 4-cylinder engine, the pan would be too short.
  14. It pained me that I didn't have the space for it! It sold for $8k!!! I was sad... Thanks Ross! I agree on the Panasports, I love the look. They seem to look great on a lot of classics. When in doubt, Panasport. Thanks to Brian for those, BTW! I'm looking forward as well! Keep up the work and you'll be done before you know it.
  15. Exactly! It has very little to do with r/s ratios and strokes. It's about the weight of your reciprocating parts. The rev limit definitely has something to do with stroke length, r/s ratio has a relatively minor effect. The prevailing logic...
  16. The photo in the link shows it pretty well. I believe people typically use a center-in, offset-out setup on the S30.
  17. Of course it has to happen right before a long road trip, but hey, at least it didn't happen during! Sounds electrical and possibly heat-related. Ignition module, possibly. Are you using a ZX distributor?
  18. There is no best. What are you confused about?
  19. Good info, Dan. I was always curious as to the actual weight differences between the two.
  20. Here are a couple of threads to wade through, if not just for the videos: http://forums.hybridz.org/index.php/topic/87781-400hp-na-32l-how-is-this-happening/ http://forums.hybridz.org/index.php/topic/90037-japanese-na-l6-400hp-how-they-do-it-pictures-ive-found-etc-not-56k-safe/
  21. There are no discernible differences here. This is the problem with anecdotal evidence, the people that post this don't fully understand the situation. The reason people think L28s rev slower or lower is because of the cam. Put a hotter cam in and rev it to 8000rpm. Forged pistons are needed for ventures above ~7200rpm. If you want to go that far, the L28 rotating assembly can be lightened and balanced just as well. You'll have the response you want with more power and torque. This is the point, the difference in how it "feels" is minimal if not completely negligible. The only difference between the two engines would be that you'd have a conversation piece where you get to say that you built an engine using X crank, Y rods, and Z pistons. That'll about be the only difference, and if you're happy with that then build it. In the spirit of Hybrid Z, build whatever you want and whatever makes you happy. However, let's be logical about this and not ignore facts. An L28 can easily give you the "feel" that you're after, likely with less expense, less time, and better performance. You can find plenty of threads with high-revving, fast-response time L28s.
  22. In all honesty, and this is the stuff discussed in other threads, the characteristics of the engine will not be noticeably different from a well-done L28. Again, I'm not telling you what to do or what you're doing is wrong. All a destroked engine achieves is having a slightly higher rev limit. The L28, with a lightweight flywheel and clutch combo will respond very quickly to inputs and rev plenty high. You speak of the characteristics of this engine compared to an L28 but you don't mention what those characteristics are. What are those characteristics that you're trying to achieve?
