Leon
    25
Everything posted by Leon
  1. I would say it has to do with the raindrop shape promoting a laminar boundary layer as a fluid flows over it at the front. As the fluid moves down the shape its velocity increases and the flow becomes turbulent, thus more drag. That shape you showed looks like the initial boundary layer will be turbulent from the get go.
  2. In a nutshell, the boundary layer does not separate from the surface as the taper angle of a long raindrop is not large. If you flip that raindrop front-to-back then the boundary layer will detach at the end where there is an abrupt drop-off. Flow separation results in increased drag.
  3. Way too much for a non-running car, IMO. It looks fairly clean, but make sure you check the usual rust spots. The rust on the hatch would make me suspect that there is rust lurking elsewhere. Bring a weak magnet with you to check for bondo. By the way, it has a dash cap so the original dash is likely cracked. If the unibody is rust free, I'd offer no more than $1k but then again I'm in CA (regional prices may vary). You never know what it's going to take to get the car on the road, that's a bargaining chip.
  4. The cylinder head is not a factor in this. It's your piston rings that were stuck!
  5. After I got my sitting Z going the compression went up in all cylinders. Compression was about 90psi in 2-6 and 150 psi in cylinder one before startup. I forgot how much it went up by but every cylinder benefitted. It very well may have been that all your rings were simply stuck in their grooves until you finally fired up and ran it.
  6. If it had been sitting for a while the rings might have gotten stuck and by running it you likely loosened them.
  7. Holy cow, I'm speechless! Such a clean and beautiful Z, that is some great work.
  8. That is part of the compression test procedure! Make sure you're at WOT while cranking. I have my brother press down the pedal, if you don't have a helper use a heavy object on the pedal.
  9. Very nice! Looks like you're doing some excellent work there, the CAD definitely helps on a project of this magnitude. Isn't the compression ratio fairly high on these engines, something like 9.5-10:1. Any special precautions to prevent detonation?
  10. Nice, looks like a good base to start with. The turbo engine looks very clean. Keep us updated for sure, it's going to be a nice ride!
  11. Hell yeah! Mine will also be orange, makes me want to do the paint myself. Love the black/orange combo, I've been planning to do something like that when it's time for paint. I have the same airdam and some black slotted mags. Hopefully it'll come out half as nice as yours. Again, great job.
  12. Fantastic work there! Like others have said, I didn't think a ZX could look this good. Keep up the great work!
  13. I just went through the whole thread, some fantastic inspiration on this site! Here are my projects, a 2/71 and 3/71: The red one is my new-to-me rust free shell (Thanks bucket240z!) and my blue Z which has turned into a parts donor. The blue one isn't terrible in terms of rust though just need a lot more time to get it going. Might use it for a track car in the future. The red one has Eibachs, Illuminas, and I need to install the ES poly bushings. Can't wait to have her back on the road!
  14. Is the car running yet? A vid would be awesome!
  15. IIRC, by working the equation backwards (starting with a given area and unknown radius) two 2.12" pipes would have the same cross sectional area as a single 3". So yes, the 2" and 2.25" are the closest standard pipe sizes.
  16. Two 1.5 inch pipes do not have the same cross sectional area! I believe it was Tony who made a good example that I'll try to paraphrase: draw a 3" circle, and then draw two 1.5" circles inside of it. You can get a visual of the loss of cross sectional area, with the twin 1.5" losing 50% over a 3"! It may feel like to you like it has more torque, but only a dyno will truly show you the difference.
  17. Leon
    11041-e3100
    Little info on the E31??? Search E31 and you will find all you need.
  18. Wow, that is awesome work! I would also go with the acorn nuts, they look very clean. I know you mentioned hammertone paint, but it was unclear as to what you ultimately used. Do you mind telling us what paint you used? It looks great!
  19. +1 for the video, that is one sweet build! Looks very clean and well done, nice job!
  20. Have you guys tried cleaning the connections and tightening the battery cables. This has happened to me multiple times in different cars. All I did was clean the battery cable connections and tighten them the the battery snugly. Good luck!
  21. That's funny, my girlfriend saw the Lambo on the news today and told me about it. I really can't think of how stupid the Lambo driver is. I don't care what happened, a Murcielago should never rear end an SUV!!!
  22. I was driving about 5-6 years ago on 280 in San Francisco and I was in the left lane passing other cars. I see this black Mercedes coming up, cutting off and tailgating every car in his path. I really thought the guy was drunk because he was the most insane driver I had seen on the road at that point. He was missing other cars by inches! Of course he starts tailing me and I would not let this idiot harass me so of course I hit the pedal enough to make the lights come on. The guy swerves onto the left shoulder and then continues to pass me on the right getting very close to my rear bumper. As I look over, he just stares coldly ahead. It was a very close call. I find it works to drive a bit slower than other traffic because I really don't have to worry about all the assholes, they just pass me. I try to keep it at 65-67 on the freeway and this way I save on gas and don't get bothered by anyone. Whenever I have to drive faster I find I'm always more high strung, especially as I do a good number of long drives every year. I started doing this on trips from SF to San Diego, and I found that it really calms me down to stay right and let others pass instead of having to continually pass people because I'm going faster. Yeah, sometimes they tailgate and I usually just try to make eye contact through the rear view. Honestly, I feel like that works a lot of the time. I think I cured my semi-road rage problems by just calming down and driving slower.
  23. We don't even know what carbs you have. If they are Hitachi (SU style) then pumping the pedal will do nothing. The carbs probably need cleaning and adjustment, if you're sure the other systems in the car are okay.
  24. Here's our Doberman (Not on a Datsun, please!) named Bo (friggin' Obama dog stole his name, haha!): Here's Bo with my roommate's crazy Catahoula I guess he was comfortable... We adopted him 12/15/07 from a shelter and he is an amazing dog!
