Leon
    25
Everything posted by Leon
  1. Rated flow goes up with decreasing pressure. Ask for the pump curve.
  2. "Quicker reacting" is inherently less stable than "slower reacting". There is no way around it, it's physics. Whether that is good or bad is up to the end user. I wouldn't want a very low PMOI car on a huge oval but I would in an autoX. Road courses are a combo of the two. Weight distribution has nothing to do with this. BTW, your post is confusing, I can barely follow what you're saying.
  3. You want to do an engine swap but can't figure out how to swap transmissions?
  4. FWIW, a 60/40 car can be made to oversteer and a 40/60 understeer. It's all about setup. A properly setup racecar will be neutral or near-neutral steer, no matter what the weight distribution is. PMOI is a different subject, and very much affects how the quickly the car reacts and thus, how it feels. Putting the weight closer to the CG will make it react quicker to inputs which is inherently destabilizing.
  5. JM, interesting ideas, I like where you're going. I really like the innovation and out-of-the-box thinking. Setting limitations based on physics (and not specs) is a fantastic idea! Some people on the other forum just don't get it...
  6. You're on the right track! I consider a working wideband critical, unless you can set up the carbs on a dyno. Even though you're running Mikunis, I'd still read through Keith Franck's "White Tuning Paper" on Sidedraft Central. Webers and Mikunis work on the same exact principles, just the jet sizes might be a little different because of geometric variations between the two types of carburetors. Before we continue, we need a video... I'll entice you, here's my twice pipe, triple carb Z (including short-shifting and a leaky intake/exhaust gasket!):
  7. Use a heat gun, it'll break down any adhesive that was used to glue that thing on there.
  8. I'd definitely get a matching set. The 151s are a newer design, and feature air bypass screws for each barrel. While that is not a big deal, I believe the idle mixture screws have a different pitch. Thus you'd have widely varying idle screw settings on the two types of carb. Not good. Find an 18 or two 151s.
  9. The acronym FWHP is typically used to describe "front-wheel horsepower". BHP, or "brake horsepower", is the term used to describe power measured at the flywheel. It is called so, because of the use of a brake to measure power at the engine's flywheel on an engine dyno. Semantics... Again, the L28E was rated at something like 140-170 BHP, depending on what standard is being used to quantify that power.
  10. Main jet controls operation where your foot is heavy on the gas or you're above a certain rpm. That certain rpm is determined by your air jet. The smaller the air jet (bleed), the sooner your mains "come on" (higher vacuum signal).
  11. The L28e made exactly 0 fwhp. Now if you're talking bhp, then It was rated around 140-170 bhp, depending on what standard you're talking about.
  12. I have a brand-new, never used Holley Red. Also have brand-new, matching AN lines, fittings and filter. Was planning on using it but changed my mind. PM if interested.
  13. That's the coupling and is held in by a pin. You have to knock out the pin in order to remove it. New ones are available from Nissan, probably in the updated metal style (the plastic ones were clearly not as durable). Looks like the part number is 22119-W0400. I broke mine while rebuilding my ZX dizzy.
  14. Okay, I understand. However, air horn placement/intake length/design has an effect at least a magnitude greater than 5hp at that power level.
  15. D'oh! No hole for the float bowl vent!
  16. Good to know, thanks for the feedback!
  17. Mark, It comes down to what you're looking for. My suggestion would be to use straight runners up to the air horn, with the diameter matched to the intake port. Make the runners as straight as possible. I haven't done design work with multi-runner plenums, so can't help much there. Air horns are not trivial, especially if you're making your own intake. Air horn geometry has a noticeable effect on powerband, with a longer (less-tapered) air horn having a weaker effect but spread over a larger RPM band, and a shorter (larger taper) air horn having a stronger resonance effect but over a smaller RPM range. Where you put the horn also matters. The powerband shifts to higher rpm as the horn is placed closer to the intake valve. What this means is that if you really want to optimize your setup, you'll have to do some trial-and-error. Calculations will get you close, but nothing is conclusive without actual testing. If you want to test different lengths and horn placements, you could either build a few iterations of intakes or an adjustable-length intake. For an adjustable-length intake, it can be something like having the runner that is bolted to the head house a removable joint which lets you slip-on different lengths of intake pipes with different combos of air horns. Not sure if you want to go through all the effort, just a thought in case you do.
  18. Mark, FWIW, taper and maintaining air velocity are used for wet intake runners (carburation or PFI) in order to keep the fuel atomized. You may be better off having a larger, straight runner with a tapered air horn at the end. It all depends on how you're injecting the fuel, but any way you look at it, higher air velocity and decreasing runner diameter equals more pumping losses. I've made some detailed posts about intake design, if you're interested: http://forums.hybridz.org/index.php/topic/105783-ideal-intake-runner-taper/
  19. Good to hear, I'm actually looking for a seat that will drop me lower than stock. I'm 6'2" and don't really fit with a helmet on, even with worn-out stock seats. Any more pics or info on the seat rails? Thanks for the insight!
  20. Damn, that is frickin sweet!
  21. Simply beautiful! Do those seats sit you lower than stock? I suppose the answer depends on what seat rails you use...
  22. Leon
    Clutch problem
    Sounds like a hydraulic problem. Properly adjust the rod going to the clutch master and then bleed the system.
  23. I wouldn't do anymore spinning until you have some lubricant in there. Acetone works but use it outdoors. Personally, if I were to clean the inside of a transmission case, I'd just use rubbing alcohol from a spray bottle.
  24. Damn Robert, you got that swap done quick! Shows you how much preparedness really matters.
