25
Everything posted by Leon
It is awesome! MONGO was the first I've seen to do a bellcrank setup in an S30, and I just noticed that Mark Rolston has his own iteration as well.
Is cold start enrichment on? It could be screwing with your pulsewidths as the coolant warms up. From looking at your datalog, your temp reading looks pretty messy. Looks like your PW correlates with the temp reading, since you have a temp spike and the leaning follows along. I would turn off cold start enrichment and tune from there.
I dunno, you'll have to post a vid!
These "tuners" have no clue what they're doing or talking about. You have a fully programmable fuel management system, there is nothing stopping you, nor anyone else, from competently tuning it besides some knowledge and research. SDS has manuals for this stuff, it's not magic. Here are the links from their website. This means that either you need to study up and tune it yourself, or find a shop that knows what they're doing. Since you have a distributor, there is nothing stopping you from retarding the timing enough so it doesn't ping and tuning the fuel map to get your fueling right. Worry about ignition after you've dialed in you fuel.
You'll be fine, if you time the cam correctly. The PO did not understand the importance this concept.
Intermittent issues tend to be electrical/ignition failures. Since you have a ZX distributor, I'd suspect the module first. Any spares on-hand?
We're not talking about ignition, but about the fuel map. I don't know whether or not your SDS controls the ignition on your car. Frankly, the information in this thread is vague and porous, there are a lot of holes to be filled. What kind of ignition system are you using? Distributor? Crank trigger? The fuel map should be tuned first, followed by ignition.
Agreed. My carbs have a better AFR traceline than that. Sounds like your "tuner" is not very competent.
Yeah. I got a 5-pack from ebay for roughly the same price.
My 260Z had the "click but no start" issue. I simply wired in a 30A relay with the starter spade wire now going into the relay, acting as the signal wire. Ran a new wire to the starter from the relay, connected power and ground wires to the relay and no problems since. Wiring is fundamentally the same, no matter what kind of relay you use (small "Bosch" style, or big Ford solenoid, etc). Now I have a switch, that triggers a relay, which triggers another relay, and activates the starter.
I'd prefer the more typical setup of a 6-2 header with 1-2-3 and 4-5-6 sharing collectors. That way, you're equally alternating between each collector, dictated by firing order, and each cylinder is scavenged essentially equally. A 6-1 works in this regard as well. Your header, with 1-5, 3-6, and 2-4 being shared in three collectors, will have more unequal cylinder scavenging. Starting from the top, cylinder 1 fires and the subsequent exhaust gasses should scavenge (drop pressure in) the cylinder 5 tube since they are joined together. Then 3 fires and scavenges 6. Same with 2 scavenging 4. As you can see, only 3 out of 6 cylinders get the scavenging benefit, since cylinders 1, 2, and 3 don't get a pulse in their collector shortly before firing. However, this is theoretical stuff. I don't have any data as to suggest by how much performance will differ using your header versus a good 6-2 (or 6-1) design. Care to run a comparison dyno test for us?
Low brake pedal issue on 240Z
Leon replied to tommott77's topic in Brakes, Wheels, Suspension and Chassis
I'm with beerman, sounds like the typical reaction disk issue. Is there no brake pressure until it grabs all of a sudden, half-way through its travel? Check the booster for the reaction disk. -
Best answer ever.
No problem! I've been working on a resonance tuning spreadsheet based on Heywood's book, all I need to do at this point id take accurate measurements of my actual setup to see if the numbers come out right. I think the Cannon manifold is as long as it gets, as far as triple carb manifolds go. Long air horns will give you more low- and mid-range but make sure you don't shroud them.
I wish they were fictional losses! Yes, I understand the relationship of velocity to momentum. My point is that people tend to focus completely on velocity, not realizing that frictional losses are present, not to mention that they increase with the square of velocity. I mentioned this in the exact line that you quoted. Here's how it works, in a nutshell. The engine is essentially a pump with the air (and fuel) as the working fluid. When talking about frictional and velocity effects, we must speak in the same units of measure (e.g. don't compare momentum to pressure). A good way to go about this is using Bernoulli's energy equation. Pressure losses depend on V2, with the rest of the numbers being constants (pipe length, diameter, friction factor). Dynamic pressure, i.e. the pressure contribution from velocity, is also dependent on V2, with the constant being density. In fact, frictional losses is what our engine (pump) must fight against. These are the so-called pumping losses, and they're responsible for preventing 100% VE at all engine speeds. Clearly, the effect is greater at higher engine speeds, and actually overshadows the ram effect even at high speed. Heywood's "Internal Combustion Engine Fundamentals" has a fantastic graphic showing this, Figure 6-9. The air filter, throttle valve and intake valve are the big losses, but don't disregard the friction in the runners. Plus, the throttle valve size is dependent on runner diameter! There is also an interdepenence of resonance tuning and pipe length, and thus friction. To take the biggest advantage of resonance, you'd have to tune to the first harmonic, giving you in the range of 5 foot long intake runners. This clearly increases frictional losses, especially if there are bends in the 5 foot long intake pipe. Friction is always a consideration and is not to be tossed aside as if its contribution is "magnitudes" less than dynamic pressure. This is simply not true. In fact, this is the biggest design challenge to an engine designer. Fuel and spark are easy, but getting as much air into the cylinder as possible is what's difficult. Another key point you must realize is that resonance tuning is not the same thing as "ram" (intake inertia) tuning! The principles on which these phenomena operate are entirely different. Resonance tuning uses pressure waves (as I discussed in some detail), and ram tuning utilizes momentum/dynamic pressure. What you are talking about (ram tuning) depends on air mass, and how much of it rests in the intake runner waiting for the intake valve to open. In my highway analogy, ram tuning depends on the amount of cars and resonance tuning depends on how long the line is. Summing this up, resonance tuning drives runner length and ram tuning drives runner volume. It is imperative to have a solid understanding of this. One last caveat on resonance vs. ram tuning is that ram tuning only has an effect at high rpm, where there is enough air velocity. This means that in order to take advantage of ram tuning, valve duration must be increased, which then hinders low-speed opertion. Resonance tuning can be tailored to any valve timing/duration without that compromise. In regard to your taper questions, I'll answer in the same format that you used: I've basically answered this earlier. That is not true, a taper does not and cannot "fight" frictional losses. Not really, a straight runner would prevent flow separation as well. Somewhat, yes. This is one of the compromises of a "wet" intake runner. A direct-injected or port-injected engine design does not have to worry about fuel in the runners, thus you can go bigger (and more creative: think BMW's variable-runner systems of the past, a prime example of using resonance tuning!) without having the side-effect of more wetted runner area (larger Tau layer). Having to keep fuel atomized presents a compromise only when speaking about TBI or carbureted engines. As far as theory goes... As mentioned, a wave gets reflected at a discontinuity (diameter change). A straight, open pipe has one discontinuity, which is located at its exit. Now, if we add a step in the pipe such that the diameter changes to a bigger pipe before exiting, we have 2 discontinuities. The pressure wave will still travel the length of the pipe, but now there are two reflections at two distinct lengths (at step and at end). However, these reflected waves will now be smaller in amplitude. This decreases the magnitude of the resonance effect, but now stretches it out to 2 distinct engine speeds. Look at the taper as an infinite series of steps. At each point, the diameter is getting bigger in infinitely small steps. The wave travels the length of the pipe, but gets reflected at each point along the taper. The longer your taper (more steps) the more you decrease the amplitude, but broaden the range. As with anything, it's a trade-off! Your overall goals determine whether you value amplitude (peakier torque curve) or range (wider, but less pronounced torque curve) more. Yes, 7 degrees of taper is close to maximum before you get flow separation in the intake, thanks for mentioning that. The overall goal of a properly designed intake is to minimize losses while extracting as much performance as possible. Resonance tuning and ram tuning both aim to achieve this, while working against flow reversion, charge heating, and friction. References: (1) Internal Combustion Engine Fundamentals by Heywood (2) Introduction to Fluid Mechanics by Fox, McDonald and Pritchard
Dangit, Bill! I'm in the area tomorrow, and you're going skiing? Glad to hear you guys found the issue, I'm looking forward to seeing your Z sometime!
I have Eibachs on my 260Z and get some kickback if I hit a bump mid-corner when driving spiritedly. However, the early 260Z gets a slightly bigger front drop with the Eibachs (unique front strut housing). You won't notice a thing in everyday driving.
SU swap, now hits wall at 5k in gear
Leon replied to PurePontiacKid's topic in Trouble Shooting / General Engine
Then, the next thing to do would be to verify float level using clear tubing attached to the bowl outlet as a gauge. -
The water pump intake is also right above the alternator, check that as well.
Some shiny wheels, or some sweet poly bushings, or, or an air dam! Then strip the car and have it sit on jackstands, indefinitely. In all seriousness, my point is don't get caught up in appearances or "performance" parts. Figure out what it needs the most and get it done.
My bet is on the nozzles sticking in the down position, allowing too much fuel past the needle. Remove the nozzles, clean them up and they should be okay, unless something is seriously wrong. -
Bingo... -
Your post adds some info that I purposefully left out of my post in the other thread I linked above. Otherwise, I'd start to approach dissertation status. I didn't go into harmonics, and yes, the third harmonic is the one we usually go for without having bosuzoku intake pipes. Our posts make for a good match, a nice combo of theory and application!
Maybe the long post I just made in another ITB thread will help! It probably would've gone here anyway, if I saw this post first. http://forums.hybridz.org/index.php/topic/105783-ideal-intake-runner-taper/page__view__findpost__p__989770 I guess I might as well copy/paste some of it over here... So, why taper the runners? It's all about resonance tuning. Well what the hell is resonance tuning, you may ask! When your intake valve opens, the mixture begins to flow into the cylinder. This propogates an expansion wave up the intake tract. Think of it this way: the intake runner is a 4-lane highway, the valve is a traffic signal, and the cylinder is a mall parking lot after the signal. The cars on the highway waiting for the light represent the air-fuel molecules. When the traffic signal turns green (valve opens), cars begin to flow into the parking lot (cylinder). Looking down at the highway (intake runner) with a bird's-eye view, you can see the front-most cars moving first and creating a gap between themselves and the cars behind them. Keep looking down and you'll see that this gap travels down the line of cars on the highway until it reaches the last car and the last car begins to move. This is your expansion wave propogating up your intake tract! Wave dynamics state that if a wave travels through a pipe and hits a discontinuity (a change in diameter, like the end of a pipe) then it is reflected back down that pipe with the opposite effect (negative to positive - an expansion wave gets reflected/inverted as a compression wave). Let's get back to our traffic analogy where we left off, imagine that the reflection happens when the wave hits the last car in line on the highway and it begins to move. The line of cars has now expanded after the light turned green, so the last car in line will work to compress it. So, the last car in line gasses it and rams the car in front! They now go down the line, ramming each car in front of them until they've compressed themselves into a big hunk of metal upon reaching the parking lot (cylinder). This is the compression wave reflecting down the runner and squeezing back into your cylinder! This compression wave increases intake pressure, which fills more of the cylinder (an increase in "volumetric efficiency"), which is what ultimately increases engine torque. Silly analogies aside, those are the fundamentals. Back to our intake and cylinder, we can see that it takes time for the expansion wave to travel up the intake, reflect, and travel back down as a compression wave. In order for our intake to be "tuned", the compression wave must reach the valve just before it closes so that we can squeeze in that last extra bit of air-fuel mixture without reversion of the mixture back into the intake. You can see now, the connection of intake tuning to valve timing and intake length. The longer the intake runner, the longer it takes for the compression wave to travel back to the valve. This means that when you increase runner length, your tuned rpm drops to a slower engine speed, where the wave has enough time to get back to the valve. If you change your valve timing, e.g. closig the intake valve later, then you raise your tuned rpm to a higher engine speed since the wave now has extra time to get back to the valve before closing. What does this have to do with intake taper? Think back to the expansion wave hitting a discontinuity in the pipe. A discontinuity causes an inverted reflection of the wave. If your intake is straight from air filter to valve, you get one big, fat reflection but only at one discrete engine rpm. At other engine speeds, the timing of the reflection will be off. This gives your torque curve a pronounced peak but no benefit from intake tuning off that peak. What a taper in the pipe does, is introduce a bunch of tiny, little discontinuities along its length. Meaning, as the wave travels through the taper, the diameter is continuously changing. This allows some of the wave to be reflected back down the intake, while the rest of it keeps moving out. What you have now is a series of smaller reflections but at a broader range of engine speeds. This results in a less peaky but more flat and robust torque curve. From what we've discussed here, it can be seen that a short, agressive taper will make the reflection stronger but last for a shorter span of rpm. The opposite goes for a shallower, longer taper (broader tuned range, but with a smaller bump in performance). Taper location also plays a role, once you think about it. Since the wave takes time to travel up and down the intake runner, the further you space the taper away from the valve, the longer it will take for the expansion wave to reach the discontinuity. This allows you to "activate" your taper at different rpm. If you start the taper further out from the valve, then you delay relfection, which then shifts your torque curve down. At higher rpm, the compression wave simply won't have the time to reach the valve before it closes. In conclusion, there is no ideal intake taper! You must figure out your design intent (peaky or flat torque curve; low, mid or high end torque) from which ideal runner size can be found. Sorry for the long post, but I felt compelled to give a more thorough answer. Hopefully, you can get some benefit out of it!
That is plain wrong and frankly, terrible advice. Why retain a restriction? A restriction is just that, something that hinders flow. So many people develop a vexing fixation on velocity, but I just don't get it. Why? Frictional losses increase proportionally with the square of velocity! This is bad. Rather, look at pressure. The more pressurized the intake, the better your cylinder is filled (higher volumetric efficiency), which boosts the amount of torque your engine can make, therefore we want to maximize intake pressure. Now, velocity does affect pressure (dynamic pressure), but with the side-effect of increasing frictional losses (pressure drops) in the intake. As you can see, there is a fine balance between the two where optimization is needed. Trial and error can determine the balance, but that involves making many iterations of intakes varying runner diameter and testing to see which one best matches your goals. However, changing runner diameter also changes your tuned rpm, so you're playing with multiple intertwined variables here. Let's forget about the restriction nonsense, and focus on intake design and taper. Your idea on tapering down to the head is better than putting a restrictor into the intake. The head port is still a restriction (not a good thing!) but there are compromises there that we cannot avoid (packaging). So, why taper the runners? It's all about resonance tuning. Well what the hell is resonance tuning, you may ask! When your intake valve opens, the mixture begins to flow into the cylinder. This propogates an expansion wave up the intake tract. Think of it this way: the intake runner is a 4-lane highway, the valve is a traffic signal, and the cylinder is a mall parking lot after the signal. The cars on the highway waiting for the light represent the air-fuel molecules. When the traffic signal turns green (valve opens), cars begin to flow into the parking lot (cylinder). Looking down at the highway (intake runner) with a bird's-eye view, you can see the front-most cars moving first and creating a gap between themselves and the cars behind them. Keep looking down and you'll see that this gap travels down the line of cars on the highway until it reaches the last car and the last car begins to move. This is your expansion wave propogating up your intake tract! Wave dynamics state that if a wave travels through a pipe and hits a discontinuity (a change in diameter, like the end of a pipe) then it is reflected back down that pipe with the opposite effect (negative to positive - an expansion wave gets reflected/inverted as a compression wave). Let's get back to our traffic analogy where we left off, imagine that the reflection happens when the wave hits the last car in line on the highway and it begins to move. The line of cars has now expanded after the light turned green, so the last car in line will work to compress it. So, the last car in line gasses it and rams the car in front! They now go down the line, ramming each car in front of them until they've compressed themselves into a big hunk of metal upon reaching the parking lot (cylinder). This is the compression wave reflecting down the runner and squeezing back into your cylinder! This compression wave increases intake pressure, which fills more of the cylinder (an increase in "volumetric efficiency"), which is what ultimately increases engine torque. Silly analogies aside, those are the fundamentals. Back to our intake and cylinder, we can see that it takes time for the expansion wave to travel up the intake, reflect, and travel back down as a compression wave. In order for our intake to be "tuned", the compression wave must reach the valve just before it closes so that we can squeeze in that last extra bit of air-fuel mixture without reversion of the mixture back into the intake. You can see now, the connection of intake tuning to valve timing and intake length. The longer the intake runner, the longer it takes for the compression wave to travel back to the valve. This means that when you increase runner length, your tuned rpm drops to a slower engine speed, where the wave has enough time to get back to the valve. If you change your valve timing, e.g. closig the intake valve later, then you raise your tuned rpm to a higher engine speed since the wave now has extra time to get back to the valve before closing. What does this have to do with intake taper? Think back to the expansion wave hitting a discontinuity in the pipe. A discontinuity causes an inverted reflection of the wave. If your intake is straight from air filter to valve, you get one big, fat reflection but only at one discrete engine rpm. At other engine speeds, the timing of the reflection will be off. This gives your torque curve a pronounced peak but no benefit from intake tuning off that peak. What a taper in the pipe does, is introduce a bunch of tiny, little discontinuities along its length. Meaning, as the wave travels through the taper, the diameter is continuously changing. This allows some of the wave to be reflected back down the intake, while the rest of it keeps moving out. What you have now is a series of smaller reflections but at a broader range of engine speeds. This results in a less peaky but more flat and robust torque curve. From what we've discussed here, it can be seen that a short, agressive taper will make the reflection stronger but last for a shorter span of rpm. The opposite goes for a shallower, longer taper (broader tuned range, but with a smaller bump in performance). Taper location also plays a role, once you think about it. Since the wave takes time to travel up and down the intake runner, the further you space the taper away from the valve, the longer it will take for the expansion wave to reach the discontinuity. This allows you to "activate" your taper at different rpm. If you start the taper further out from the valve, then you delay relfection, which then shifts your torque curve down. At higher rpm, the compression wave simply won't have the time to reach the valve before it closes. In conclusion, there is no ideal intake taper! You must figure out your design intent (peaky or flat torque curve; low, mid or high end torque) from which ideal runner size can be found. Sorry for the long post, but I felt compelled to give a more thorough answer. Hopefully, you can get some benefit out of it!
