Leon
    25
Everything posted by Leon
  1. You guys realize that this is going to drive up the prices of 280Zs and ZXs, right?
  2. What I'm saying is that you shouldn't discount an idea, a design, simply because it doesn't have "perfect" 50-50 weight distribution. This is an automotive fallacy, 50-50 isn't necessarily perfect. What's "optimized" for you may not be optimal for someone else and their design intent. Like I said, one single thing (like weight distribution) isn't the bane, nor is is the the sole key of success in vehicle design.
  3. Unless you set it up correctly... People often mistakenly equate weight distribution to the understeer/oversteer propensity of the car. The suspension can be tuned to match the weight distribution, among (many) other things. You can take a 70/30 car and make it have steady state oversteer. Weight distribution/location does affect the rotational inertia of the vehicle. The more centered the mass, the easier it is to change it's velocity. This is good for quickness (anything involving changes of direction) but also has a destabilizing effect (less resistance to turning, i.e. less time to react, harder to correct, more sensitive to inputs, etc.). The other point is that a front heavy, rear-drive car will be at a disadvantage regarding traction on acceleration. There are myriad things that affect vehicle dynamics and you can't chalk up a car's handling to just one of them, e.g. weight distribution. Veering back on topic, looks like the owner has already dropped down to $1250 upon realizing that it's a 1600 and not in the best of shape...
  4. Disclaimer: I'm no MS expert, nor have I even played with it. Sounds like there is some closed-loop feedback coming from the O2 sensor. Turn off O2 feedback and see if that helps.
  5. No problem, be sure to check the sub-forums in the FAQ section!
  6. You mean something like this?
  7. FYI, Here is a follow-up post from CL: FWIW...
  8. Let me know if you're ever in the area! PM me and I'll give you my number so you can save it for when the time comes.
  9. I'd take you up on that if I were anywhere near LA! Glad to hear that you've solved the problem. On to the next one...
  10. I've seen them on a few Zs, pretty sure they were made by American Racing.
  11. http://forums.hybridz.org/index.php/topic/105590-1977-280z-l28-engine-transmission/page__pid__987869#entry987869
  12. Nice! I've been using the EDM at work, looks like a good project! Keep us updated.
  13. Damnit. Did you put in a new gasket once you straightened the flanges? Check both flanges with a straight-edge? You can also try to use some of that copper gasket spray to see if it will help seal up once everything is true.
  14. Also, check your flanges for straightness. I've seen them warped enough to never seal.
  15. Leon
    What ITB
    A cool car and beautiful engineering, but that was a mechanical form of fuel injection.
  16. I'm with John, set them to German torque spec.
  17. There's a 76 on Woodside Road in Redwood city that sells 100 octane. Just sayin!
  18. Use a stethoscope (i.e. a screwdriver with the soft end butted up to your ear and pointy end used to probe around) to find the locus of the noise.
  19. I also quite enjoy Tony's high-revving LSR car!
  20. On the right is a Clifford Research header, the one on the left is a Hooker Super Comp. Both are NLA, along with many other Z headers.
  21. The chain tensioner is hydraulic, so the chain will have some play in it without the presence of oil pressure. Follow the procedure that Tony outlined, to make sure that the knock is not localized to one cylinder.
  22. Leon
    TC24-B1Z
    C'mon Tony, that's cheating!
  23. That's the range that was in my mind as well.
  24. My suggestion is to remove the exhaust manifold and if the stud protrudes enough, clamp down on the stud with your bench vise. You will have a bunch of clamping power, plus you can use whole exhaust manifold as a lever when you try to turn the stud out. Make sure to use heat, and be careful with the mating surface. I've removed a frozen stud from a head using this method, when nothing else worked. However, any time you remove one manifold, you should remove the other. Not only does this make the process easier, but you really should put a new intake/exhaust gasket in if ever the old one is disturbed. Just remove the manifolds, it's an easy job as long as you're careful with the studs. Use penetrant and heat if necessary. Be sure to keep fuel lines away and a fire extinguisher handy if using heat. It's not as bad of a job as it seems.
