Leon
    25
Everything posted by Leon
  1. Plus, they are 15 minutes from where I work!
  2. I was thinking the exact same thing as John, your timing is way too retarded. Advance your timing to 34 or so degrees with mechanical all in. Low speed cruise and transition will be slightly weak if the vac advance is broken or disconnected. BTW, 2.5" exhaust is definitely not too big. There is no such thing, take a look at the exhaust sticky. I'm running twin 2" pipes on my L24 without a hitch. That is 100% not your issue, unless someone stuffed a banana in your tailpipe.
  3. I guess I'm lucky enough to have a few local places that stock SA helmets. You probably already have, but search around and see if you can find some local places. Racetracks, race-shops and circle-track equipment suppliers tend to stock this kind of stuff. If there are absolutely no places in your area, then I'd go to bike shops and try on M-type helmets. Sizing should be similar within product lines of each manufacturer, i.e. a Shoei M helmet should fit similar to a Shoei SA classified helmet.
  4. The HEI is the cheap and proven solution. ZX modules are much more expensive and both options require some wiring work.
  5. Yep, use KVL loop equations. You'll end up with 6 equations and 6 unknowns. You may be able to parse that down to 3 eq, 3 unk. Matrices would make quick work of the math.
  6. This is how they all come, whether you get them from MSA or elsewhere. Holes are drilled "to fit".
  7. DAMN! There is a local guy here that would do it for less than half that, and do a nice job as well.
  8. Let's take a step back and realize that heat transfer has a very minor effect on combustion efficiency at high engine speeds. There simply is not very much time to transfer an appreciable amount heat to the cylinder walls during the time in which the piston is being actively pushed down by combustion. If you're looking to eek out every tiny bit of hp then so be it. If you cool the piston, there will be more heat transfer. The larger benefit in these "squirters" would lie in keeping the cylinders and piston cool, thus fighting off some detonation and keeping coolant temps at bay.
  9. If I have it right, the hole in the passenger side will be your intake and the hole on the driver's side just admits air into the engine bay? Not a great idea, IMO, but I suppose you can try it. Just watch coolant temps and see if you have a lot of front-end lift at high speed. You'd have to have substantial engine venting to not cause a bunch of lift or at the very least your hood bulging/flying open. I do know Glenn, and of course wouldn't mind stopping by the shop! I assume it's in SJ. I'm not in the South Bay often but PM me and I'll try to stop by sometime.
  10. I haven't played with Mikunis but they're similar to Webers. Those jets all sound way too big. I have an L24 with stock cam, header, electronic ignition, so a very similar setup. I'm running 40DCOE's and from memory: mains are 125, air correctors are 170, idle jets are 45. I still run too rich at idle and cruise. I'd be surprised if you were running lean. The only functional differences I can expect between the carbs would revolve around the progression hole locations, emulsion tube design and idle/pilot jet design, and I bet they're not worlds different. Again, I don't have direct Mikuni experience.
  11. That ring gear is pretty much useless without its matching pinion.
  12. My 260Z tach did this when it died. Replaced with a 280Z unit (ebay, $25) and all has been good since!
  13. I was going to say the same thing, twist the input shaft around while trying to stick it in gear.
  14. Jeebus, why did you cut such huge holes! I'm not sure what you're planning, so I'll let you explain. If you're just going to leave big holes in the sheetmetal there, you're short-circuiting the radiator. Air will go around the rad, not through it. Take a look in the windtunnel sections, people usually try to close up the front, not the other way around. I hope you have big vents somewhere to release all that pressure that you'll be building under the hood. Maybe you have a good plan for it...
  15. No, it came with a manifold vacuum port, nowhere does it say that it's for the distributor. The distributor needs a ported vacuum source, not manifold.
  16. This definitely has been discussed before. However, triples make plenty of vacuum to used the vac advance. The problem is that there is no ported vacuum source to drawn from, so you'd end up getting way too much advance at idle. Vac advance is beneficial, on top of having a properly matched mechanical advance curve. However, in order to make it work right, you need a ported vacuum source and a vacuum log to strengthen and smooth out the signal. By that time, you might as well go crank-trigger. Only cost me $400. Dammit! I got ripped off!
  17. What's a distributor? But in all seriousness, the stock distributor has mechanical advance. It's the advance curve that you're worried about. Search around and you'll find some good discussions on the topic.
  18. Depends on your definition of "fun" I guess. I can have fun with 120whp from a stock L24. Find a running engine on CL and stuff it in. Shouldn't cost you more than a few hundred bucks and will get you on the road and having fun in no time! If you want to build an engine then buy a spare one and build while keeping the Z on the road at the same time.
  19. Could have something to do with dropping in a V8...
  20. The soft brake lines to the calipers and wheel cylinders have to be removed when replacing springs. The system must be bled properly afterwards. Sounds like the shop is at fault again, if the car came in with good brakes and left with spongy ones.
  21. Very nice! Get her tuned, cleaned up and log some miles!
  22. Yes, ignition module is the first thing I'd be looking at, as I mentioned. Wire in an HEI module (hell, they're cheap!) and see what happens.
