25
Everything posted by Leon
It should definitely be noticeable. I plan to put in a new clutch and transmission mount in the process. I will also be swapping out my 280Z 5-speed in favor of a 280ZX close-ratio unit I have sitting around. Time to find a chunk of time to do this, I think that is more difficult then actually doing the rest of the work!
Nice looking torque curve, that car must be very fun to drive!
My 560ZX ( Titan VK56DE powered 280ZX S130 ) Build Thread
Leon replied to Jared's topic in Other V8Z Tech Board
This may just be the most awesome 280ZX I've seen, just because of the engine! Great work so far, can't wait to see this beast run! -
I think a flex-pipe is more necessary on a transverse mounted engine, where the exhaust tilts up and down with engine torque. I don't worry about it as much on a longitudinally mounted engine, since soft exhaust mounts should be able to accommodate the slight bit of twist (unless your engine mounts are screwed). Nice job, seems like you're moving along nicely!
Good point JM, but the gearing difference between the cars will not be a "make it or break it" kind of thing. However, for the hell of it I compiled top speeds in second gear for the three finalists! M Coupe (S52) - 61.7 mph S2000 (AP1) - 66.3 mph S2000 (AP2) - 60 mph C5 Z06 - 71.5 mph
I drive like a grandpa on my commutes, meaning 65mph or slower and in the right lane. I get on it only when I need to pass or merge onto the freeway. It helps save gas (100mi round-trip commute), lets me relax and keep my sanity. Plus, I've never had a ticket (knock-knock-knock on wood ). Since I keep my speed down on the freeway, low gearing is not a problem and I actually prefer it. AutoX and spirited weekend drives are another thing altogether!
I believe THIS is what you're looking for.
I believe the Fidanza units are 10.8 pounds. This is compared to a stock flywheel which weighs in at something like 25lb!
As far as hydraulic vs. mechanical lifters, there is no performance difference until you want to run a cam other than stock. AFAIK, the hydraulic head needs a different cam grind than a solid lifter head. If you plan to change cams, convert to mechanical.
Nice, I didn't know you had an S2000, Mike! I have checked out S2ki, and while there is some good info there, I've realized that many S2k owners seem to be morons... I've really enjoyed all E36 cars I've driven. BMW did a great job with every facet it seems, from the driving position, sound of the doors closing to the feel of the buttons. Everything feels very well thought-out. As far as year-round DD, this is not a problem in these parts! Good info on the control arm mounts Jon, thanks! I had a feeling it's exaggerated, it seems people that don't really know what they're doing are the ones that lose control "for no reason". This is why I loved driving the S2000, it's so neutral and easy to toss around. Talk about a fun car! Honestly, I don't mind not having the quickest car on the straight since 99.9% of the driving I do will be at low speeds. I drive like a grandpa on my commutes, so didn't mind the low gearing of the S too much. I actually like it! Now you see why I'm in such a dilemma! All three have great redeeming qualities, and all three will absolutely be fun. I'd love to find an M Coupe in good shape, without a sunroof and reasonably priced. We'll see if that happens! Thanks guys!
Quick update: Scooped this off of ebay! Looks like a clutch job and transmission swap is in my near future!
Mike, I definitely have experienced it in the S2000! Although it did have something to do with the rear tire pressures being unequal, as we later found out. Truthfully, when it happened, my correction felt very easy and natural because of the connective feeling to the car that the S gives that I had nothing but confidence even after that. I didn't have a problem correcting the S, but I didn't over-correct like many seem to. I'm sure it could bite me eventually, but I don't push my own limits, at least not on public roads. Thanks for sharing your experiences, it definitely helps! I will definitely let you guys know when the decision is made!
Nice! Interesting, I have heard snap oversteer and unpredictable about the S2000, but not the M. I'll be on the lookout for a clean Z06, to see if it works for me. I think that 50th anniversary is in Georgia, but I don't think I'm ready to fully commit yet! Thanks, good to know! Limit handling will not be a deal-breaker since this will be a DD and occasional autocrosser. I will not push it on the streets and autox is a safe environment for me to test the limits. I do love the looks of the M Coupe but they are tough to find, especially without the sunroof. A friend of mine did have an E30 M3 for a while, and that car is a blast! I've also driven another friend's E36 M3 and I didn't have trouble with either car's handling. So from my experiences I think the M Coupe will be livable. Then again, I haven't tracked either of them. The thing is, I'd like the car to be what I want out of the box. I'm not looking to modify much, if anything, and the Z06 already does it all. If I go with the Corvette, I'm going "all out". Otherwise, I just don't see me being interested in one. I have my Zs to work on and I just want my DD to be something fun, easy to maintain, and toss-able when I hit an autoX once in a while and don't take the Z. I think all three, the Z06, S2000, and M Coupe come well-outfitted from the factory, with nothing needed to make them "better" in my mind. I know the Honda is a bit twitchy and stiff but I can handle that. In terms of interior space and the S2000 being small, I think I can live with that. When I thought about what I use my Accord for, I realized that 99% of the time I'm either by myself, or driving one other person. The cargo I carry on a daily basis is minimal. For the days when I need a larger vehicle, I have access to my fiancee's new Outback. She has given me the go ahead to get as impractical of a car as I want, while I still can! Anyone have a Caterham 7 or Ariel Atom sitting around?
The 'Vette is definitely a huge performance bargain, although I really need to search hard to try to find one around the $15k range. Yeah, I've heard a lot of negatives on E46 maintenance. It's essentially off my list, as I don't want to deal with expensive repairs (like replacing rod bearings on the S54). I read about a guy who upgraded from an E36 to an E46 and made a convincing argument as to why if he were to do it over, the E46 purchase would never happen. Good plan! I very much agree with the vehicle history. I'm definitely making sure that my considerations come with service records and that the car is generally well taken care of. With the S2000, this is often not the case... Either one, given it's properly maintained, should be pretty reliable I would think. The markup on BMW parts can get silly, but the E36 chassis is not as expensive as the newer ones. I've enjoyed the S2000s I've driven, but I think I really do need to drive the S2000, M Coupe, and Z06 back-to-back to get a true feel for the differences. When I realized that the Z06 puts down 400hp, 0-60 in ~4 seconds, and still gets 30mpg, there was no way it could not be on my list (as terrible as the interior is)! Thanks for the gas mileage numbers, those very much factor into my decision as I drive over 500 miles per week. I'm not near Georgia, but when I make my decision I don't mind flying out to buy the right car! If I get a Corvette, it will be a Z06 though. I haven't seen any in good shape that are much below $20k, but looks like I should keep looking! Nice reviews, you paint the picture well! The E36 seems reliable if the proper preventative maintenance is done, my brother's E36 318is is over 200k. The Z06/E36 feel discrepancy may come from that BMW suspension tuning! I seem to keep coming back to the S2000 because it has "Honda reliability" but with true sports car performance. Thank you all for the great input so far! Looks like I need further investigate the Corvette!
I've been casually looking for a new-to-me daily driver for some time now, doing research and trying to decide on what I want. Essentially, I'm looking for a new daily driver that is fun (can toss around in an occasional autocross and weekend drives), is okay on gas (high 20s, if not 30mpg on highway commutes), is easy on the eyes and within an upper limit of $15k or so. Clearly, this will be a used car. I've been eying the S2000 for years and have had multiple chances to drive both AP1 and AP2 models. I've immensely enjoyed driving them, everything from the suspension, to the transmission, clutch, interior and engine just feels right! I don't mind the powerband, my DD for the last 6 years has been a (Canadian!) '01 Accord Coupe. Yes, my speedo is in kph , I tend to get a lot of "Slow down! Why are you driving so fast!". The Accord gets 30-33 mpg in my long commutes (100mi/day) so gas mileage is of some concern. If I stay out of it, I know the S2000 can get 30mpg. I fit snugly but comfortably in the S, although I don't think I'd fit if I was any bigger (6'2", 190lb). I think they are great looking cars to boot, simple and to the point with nice, clean lines. Plus, there are no headroom concerns for the days I plan to autocross since I could just drop the top. Fitting with a helmet on is tough for me in non-convertibles. For a long time, I was dead-set on the S2000 being my next DD, but recently I thought I should at least cross-shop so I can be absolutely sure of what I want. Anyway, it gives me an excuse to research other cars and go on test drives! I've considered the E36 and E46 M3, C5 Z06 'Vette, and even a Porsche Boxster. The Boxster impressed me, but I'd rather not maintain a Porsche and I'm not a huge fan of the looks. The Z06 has staggering performance for the price (although it is somewhat over budget), but I just don't see myself driving a Corvette and the interior is kind of cheap. This is going to be a daily driver that I enjoy commuting in after all. The M3 is nice and was in strong consideration until I thought, why not an M Coupe! I love the looks of the Coupe and it shares the great M3 drivetrain. Being lighter and stiffer than an M3, I see it as the ultimate M-car. I haven't had a chance to drive, or even sit in one but I've been puddling drool over them recently. My concerns about the M Coupe is that they're older, more expensive to maintain, and some had issues of sheet metal spot welds coming undone at the rear subframe supports. Apparently, it's not too common, but it's something to think about. They are also harder to come by than the others on the list (especially since I want one without a sunroof), and therefore carry a premium on price over an M3. What do you guys think? Anyone with direct experience on driving and maintaining these cars (mainly S2000 or M Coupe) would be awesome! Hope everyone enjoys Thanksgiving!
Weber jets??All who live for their triples please read this
Leon replied to datfreak's topic in Nissan L6 Forum
That's okay, I'm very glad that you took the time to actually use the resource! I've been following Keith's work with a lot of interest, as he seems to be able to make DCOEs run like fuel injection. He does this by gaining a thorough understanding of each function, not hearsay and "formulas" which seem to be the MO in setting up carbs. However, don't give me any credit for his research, I'm just reiterating what I've learned by following his developments! -
Exactly. The venturi effect is not used, nor desired, in exhaust design. A venturi is a restriction. The collector Jon posted takes advantage of the tuning effect caused by a "megaphone" in the exhaust. Take a look at the exhaust sticky, PM me if you have questions after digesting it (and turkey!).
I'm on the upper peninsula (San Bruno) and would be happy to meet up. Gollum's event was great!
I am simply reiterating a small part of what I have learned from Keith Franck's research, as it related to the question of main jet tip-in. He is a retired LBNL engineer who has put in an immense amount of time into actually reverse-engineering the DCOE carburettor to the point of making better idle-jets and emulsion tubes. I have already referred to his Yahoo group, "Sidedraft Central". Read the "White Paper" in the Files section, and maybe then "cast your vote". -
You are isolating the idle/progression circuit by reomving the e-tubes. Taking the mains out of the equation is the whole point. Driving without e-tubes will show you the idle/progression circuit's true contribution. Put the e-tubes back in and see where the main circuit affects the AFR. -
78Z: L28et MS2, EDIS, Holset swap...
Leon replied to Challenger's topic in S30 Series - 240z, 260z, 280z
Not without any input. You must also have the VR sensor wired to the module and correctly oriented to the trigger wheel. Limp-home timing is 10BTDC. Keep up the good work! -
I would do a timing sweep, from 10-20deg BTDC for example. Lean the mixture and find where it's happy at in terms of spark advance. There is no number set in stone, each engine is different.
The leaner you want it to idle, the more you must advance timing. Mixture burn duration increases as the mixture leans out.
No, test it. This involves finding a safe place to drive the car and removing the e-tubes. Drive it gently until your low-speed circuit can't provide enough fuel. This is where the mains should kick in (at cruise conditions). Keep in mind that you will have very little power so find an empty, open area to test. At WOT, the mains must come in much sooner. This is tested by going WOT in high gear at low rpm. If it lugs, the main is working. If it dies, the main is not providing enough fuel. A wideband O2 sensor is necessary. Check out Keith Franck's "White Paper" at Sidedraft Central. -
What Pete posted is exactly correct, according to Nissan. 1) Companion Flange 2) Side Flange 3) see "beermanpete" definition 4) Rear axle shaft + companion flange Source: http://www.carpartsmanual.com/datsunS30/DatsunZIndex/PowerTrain/DifferentialGear/R200/tabid/1727/Default.aspx http://www.carpartsmanual.com/datsunS30/DatsunZIndex/Axle/RearAxleDriveShaft/tabid/1730/Default.aspx As others have mentioned, people tend to interchange terminology with these parts so that is where the confusion comes from. For example: The companion flange at the diff can be called diff flange, pinion flange, etc. The side flange gets referred to as stub axle, stub shaft, diff companion flange, etc. The rear axle shaft gets referred to as stub axle, companion flange, etc. In the end, if the terminology isn't clear, ask which companion flange they're referring to!
