25
Everything posted by Leon
I think Nissan's exterior designers must be blind pessimists. Backroom conversation: "You think some sucker will buy this crap?" "Only one way to find out..." I can't imagine how else you can make something so hideous. I went to the SF Auto Show in November. I really wish I never walked into the Nissan booth, because I saw this: Along with the Cube, Juke, and the <insert Nissan car here>. Ugh. Nissan's display made me want to Oedipus my eyes.
Contact "Derek" on this forum, he may still be selling them.
Hope I didn't scare anyone!
I would go with his suggestion. If you want to build the rest system yourself, I bet a muffler shop wouldn't charge much at all to expand a few ends of piping. The shop I used is Exhaust Works in Belmont, owner's name is Todd. He's a really cool guy and gives amazing prices for the kind of work he does.
FYI, I installed the header and had a one-man shop build me the rest of the system for $300. I thought about making it myself but my decision was based on my skills, time and finances. I have limited exhaust building experience, not enough time, and don't mind throwing down $300 for a full exhaust! I can give you the guy's info if you want to go that route.
Anyone ever put a L24 in a 280z before?????
Leon replied to turboHLS30's topic in S30 Series - 240z, 260z, 280z
A stock L28 has more power than a stock L24. Horsepower was rated differently in the two engine plates you looked at. -
I like some rasp, but it's definitely pretty raspy! It's hard to say what would get it out as there are so many combinations of pipe sizes, resonator locations and types, etc. You could go with a proven combo that you like and if you know the specs.
The S4 was on my list, although it was the B6/B7 generation (4.2L V8). Frankly, I would not even touch the bi-turbos. The reliability was disastrous! What pulled me away from the S4 was the portliness (weighs as much as a small yacht ), horrendous gas mileage, and reliability/maintenance/parts cost. They do have a nice interior and a sweet engine. However, it's just not the type of car I'm looking for. It's a luxury sedan with hints of sports car. I must admit that I did drool over them! I've driven the 2008 STI and honestly did not like it. The power delivery is fun but everything else is just, bleh. Although, when my fiancee and I were looking for a car we did check out a 2006 WRX wagon. I really liked that car for what it is. It's very versatile, yet fun. I enjoyed it more than the STI, actually! You're right about the mpg though. I really like the S2k. I've never had a problem with their prices and would much prefer one to the Miata, which feels anemic compared to the Honda. It will get 30mpg if I drive it like I drive my Accord, which gets 31-33 mpg. I think that Honda's engineers did a fantastic job with it and I don't feel the need to modify anything. I like it the way it is! I've always been very wary of other people's projects, even when completed and road-tested. My rule has always been that if I'm going to spend a lot of money on a car, it will not be modified, or very minimally so. If I feel the need, I'll do the modifications myself. I prefer to start with stock, and in the case of the S2k, M Coupe, and probably Z06, I don't think they need a thing! I do really appreciate the advice and thinking outside the box. It's much better to have all your eyes and minds on this, instead of me obsessively blabbering to my fiancee until her ears bleed.
Fairly loud. I have two glasspacks per pipe, and it's almost too loud on the freeway and kind of obnoxious when I get on it. I do like the sound, but I also really like the deeper sound of those twice pipes that you posted. Actually, I can try to stop by tomorrow after work, if I take the Z to work like I plan to. I'll shoot you a PM.
Actually, NOx emissions peak around 16.5:1. At 19:1, NOx levels likely drop down to where they were at ~14:1, or lower, as combustion temps keep dropping. If you can actually run your engine at a consistent 19:1, your NOx emmissions are fine. However, if you're having intermittent incomplete combustion (likely, especially with an older engine at 19:1AFR), then HC will skyrocket from these misfires. This is yet another common fallacy, so bear with me on this one. Burned gas (combustion) temperatures are dropping as the mixture leans out, not increasing. Higher cylinder temperature means higher cylinder pressure, higher cylinder pressure means more torque. Otherwise, if temps were increasing as you went leaner, you'd get best power from an engine by running it lean. This is not the case. The maximum combustion temperature point is slightly below stoichiometric (e.g. rich, about 13:1). This is because the dissociation of certain chemical compounds in the cylinder presents a little bit of extra oxygen, which can be taken advantage of by putting in a bit more fuel. Formation of NOx depends on temperature and the amount of O2 present in the exhaust gasses. The reason NOx is a maximum when the engine is lean (~16:1) is because as the mixture is leaned out, rising O2 concentrations initially offset dropping combustion temps. This is akin to the torque and power relationship. The torque curve has a peak (dictated by the engine's design) at a certain rpm. Power is an equation dependent on torque and rpm (generally speaking: Power = Torque X Speed). Look at engine ratings, the rpm where max power occurs is always higher than peak torque rpm. Why? Because the increase in rpm initially makes up for the loss of torque. Same thing with NOx! Except now you can look at combustion temps as the "torque curve" (maximum dictated by AFR, at ~13:1) and O2 concentration as the "engine rpm" (keeps increasing). NOx is your "power curve". As combustion chamber temperature begins dropping, O2 concentration increases. The initial increase of O2 offsets the decrease in temperature and therefore increases NOx to a maximum when slightly lean. After that, NOx drops back down. Reference: "Internal Combustion Engine Fundamentals" by Heywood
The thought did briefly pop into my head! However, it's a lot of work, for which I have absolutely no time and I'd have to go through a bit of a process to make a swap like that legal in CA. It's a cool car, but I'm essentially looking for a "plug-and-play" (turnthekey-and-play? ) kind of thing.
Anyone up for a Ferrari into S30 swap?
Apparently, the holes in the flywheel for the pressure plate are not tapped deep enough for the stock bolts. If this happens, you must use shorter bolts in order to make sure that the pressure plate is clamped down properly. http://forums.hybridz.org/index.php/topic/57299-ordered-a-105lb-fidanza-flywheel/ http://forums.hybridz.org/index.php/topic/100321-fidanza-flywheel-act-clutch-install-and-pedal-mods/
Bobby, thanks! That's the kind of post I love to see! You are completely right about autoX or track driving not dictating the purchase. I realize that it's probably less than 1% of the driving I do and choosing a car for that 1% would be a bit silly. This car definitely has to be one I can live with day-to-day. After all, I have the Z if I want a harsh ride, virtually no sound insulation, loud exhaust, no heater, no defrost, and no power steering! I really appreciate the mpg numbers, I thought the M Coupe would get better than 26mpg but I'm not surprised. This is the draw of the S2000 and Z06, both are seemingly capable of 30mpg without much trouble. On the topic of the sunroof, I now realize that (in the M Coupe's case) it actually adds a bit of headroom, so that eases the search. Maintenance is the other big thing. The typical ~$15k M Coupe will need a few things, whereas the S2000 should be good to go. The Honda's reliability always pulls me back to the S2k. Plus, I do think the S2000 is very good looking, although it doesn't have the presence of an M Coupe. I will be doing my due diligence to figure out what I really want. More test drives to come, hopefully I'll hop into a Z06 soon!
Use heat to break those flywheel bolts loose, the installer probably used loctite. BTW, from the looks of that flywheel, you bolt in new friction material instead of resurfacing.
And when you do get a spark, make sure you index the VR sensor to 6 teeth from the missing tooth at TDC. Six teeth is 60 degrees (for 6-cylinder), 5 teeth is 50 degrees (for 8-cylinder).
I'll measure things up to be sure everything is properly fastened, and then not worry about it.
Ah, thanks for reminding me! I completely forgot about that!
Well, I took a look at and drove this M Coupe today. These cars are definitely smaller than they look in pictures, similar to the S30 actually. I fit, but not much room for a helmet, save popping the sunroof. Overall, it's really just a smaller, lighter, quicker M3. It's sort of reminiscent of the E30 M3, except with more power (and weight). It has a ton of torque (compared to what I'm used to) and a nice kick at higher rpm. What I didn't like about this particular one is that upon inspection I found that it was hit in the front (new hood, left fender, bumper, headlights) and the front bumper did not align correctly. There were some slightly bent parts up front and some foreign-looking metal piping in front of the radiator. Shock mounts definitely need replacing and likely bushings, among other parts. There was no service history, and the guy was convinced that unmaintained E36 cooling systems are nothing to worry about. The salesman didn't seem like he really wanted to sell the car, even though it's been on the lot for 6 months or so. Apparently, he knows what these go for and everything else there is to know about cars... I'm casually on the lookout for a nice Z06 in the area, other M Coupes and the S2000 is still in very strong consideration. We'll see how much pain Christmas will bring to my wallet!
Bigger tires in the back will increase understeer.
!!! Amazing find, that is just awesome!
5-speeds were offered as options (US) starting in 1977, and standard by 1979.
Windtunnel Testing the Datsun S-30 Z
Leon replied to Mikelly's topic in Windtunnel Test Results and Analysis
You do not want to direct air underneath the car, but rather the opposite. The radiator should vent to the hood. Simply put, you want air pressure to be higher above the car and lower below the car (aka: downforce). -
It's always one or the other, with $ and time! If you have both, you are a lucky man. Lightweight flywheels are a fantastic upgrade, I may have to devote a weekend to get this done. I'll be ordering a new transmission mount (hopefully ridding myself of some high-speed drivetrain vibration), clutch and clutch master (just in case) tonight. I should also take a look at the shifter bushings while in there. If you want the 280Z 5-speed I can sell it to you cheap, I don't feel like storing it once I swap over to my ZX unit.
