Leon
    25
Everything posted by Leon
  1. Matt and TJ give sound advice. Your Z will start and run with that setup, but definitely not perform to its full potential. The only way to get it right is through experimentation, and the better your tools for experimentation the better your results will be. Butt dyno < WBO2 < dynamometer testing I also highly recommend Sidedraft Central to anyone interested in learning more about the DCOE. When I say more I mean more than you thought possible!
  2. That was some of the stupidest crap I've ever seen written about brakes...
  3. I will second that! Almost every fun drive I do ends up involving 35, 84, Alpine, etc. It's absolutely beautiful up there. I very much enjoy packing some food, driving up to 4-corners, and relaxing while checking out the bikes and cars that come through. Good luck with the move and I look forward to meeting you and your Z!
  4. Leon
    RHD Z wanted!
    There are differences between Euro and US S30s. The Euro ones got a different distributor and some had no sidemarker lights (by law, in a country where it was sold). Balance tubes, bumpers were also different. I'm sure there are more, but that's all I've got off the top of my head.
  5. Sure I understand that, but I never made such a contention. You claimed I made assumptions that I never made. I never said anything was easy, nor anything about making more power. If you are referring to the valve interference statement, I was saying that he should check but I doubt that it would be a problem. Reread the statements I made, maybe you'll see them in a different way? I am all for dyno testing and scientific method, and can appreciate your efforts in sharing your knowledge with the community. What I do know and did inform Steve of, is that advancing the cam will shift his powerband down. Therefore, it would be wise to set the cam on the #2 hole (which would put it at zero advance) and then have +/- 4 degrees of adjustment (instead of -4/-8 degrees if set on #1 hole) if/when he decides to test. This has been exactly my point the entire time, I just felt like you were protesting assertions that nobody ever made.
  6. I don't see any disrespect on my part. I'm trying to help Steve, and explaining my process clearly. It doesn't help when you start implying that I said one thing when I said another. Your sarcasm in a previous reply about "HP magic" was all the disrespect I've seen so far. If you have a problem, then PM me. I don't want to clutter a good thread.
  7. To clarify, not I nor Steve mentioned anything about making more power anywhere. Nobody made those assumptions. Changing cam timing shifts the torque curve, period. It's what happens when you delay or advance valve events and is not a mystery. I completely agree that you should check to make sure valves don't hit pistons. What I said is that retarding or advancing this (mild) cam should not cause any problems. This does not mean, "don't check clearances". I also didn't say to not measure power "straight up". I'll just quote myself: Test as many data points as needed. Ultimately, the dyno tells you what to do.
  8. Advancing the cam from where it was will give you more bottom end at the expense of top end breathing. How much of a difference depends on how much it is advanced. I've suggested to have #1 hole be 4 degrees retarded, which will make the #2 hole "straight up" and #3 hole 4 degrees advanced so you have some +/- adjustability with the stock sprocket. Essentially, yes. Too many links between reference marks on the cam and crank upon installation would cause the cam to be retarded. I think the stock sprocket has 40 teeth? So that would be 360 degrees/40 teeth = 9 degrees/tooth. If that's how much you're off by, then there's a good chance you've skipped a tooth. However, be sure to check TDC with the method in BRAAP's first post before worrying about this.
  9. It's not "HP magic", what you achieve by changing cam timing is altering the torque curve, essentially shifting it one way or the other. There is no requirement written in stone that you must time it that way. Best performance for the given requirements is found by using the adjustable sprocket and a dyno and it won't necessarily be what the cam card says. You should make sure that the valves don't hit, but if the cam is fairly mild then it shouldn't be a problem. I suppose you could time it "straight up" but make sure that you do so on the #2 hole if using the stock timing sprocket. That way you'll have 4 degrees of advance/retard if you want to play with your torque curve using the stock sprocket.
  10. The only reason I can think of related to the discrepancy between the card and reality is if you're a tooth off on the chain. I would also verify TDC by using the method outlined in the sticky using a piston stop (I made one at home using a hollowed-out spark plug). I'm not sure why you'd want to set the cam more advanced (open and close earlier) than what the card says. You can do that if what you're trying to do is shift the powerband down. I would set the cam 4 degrees retarded on the #1 cam sprocket hole and go from there since the stock sprocket advances 4 degrees at each hole. You'll have 4 degrees retarded, zero, and 4 degrees advanced to play with if using the stock sprocket. Reference the manual for changing cam timing. DO NOT move the cam or chain when doing this. All you rotate is the sprocket, the cam may need a very slight rotation to seat the dowel in the hole.
  11. I dunno, leftover Thai food is pretty damn good!
  12. I don't need to "draw all the little pictures" personally, I'm just trying to help others understand what's going on here. I agree with the way you look at it, but only for the purposes of analyzing a floating wheel. Sure, it may be good for something like upright design, but what else? Analyzing the suspension when you hit the brakes with the wheels off the ground? Fact of the matter is, the TC rod picks up a majority of the braking forces. There is no way around it. In order to properly design or "tune" a suspension, you must take into consideration the forces that exist at the tire contact patch. Without that, what's the point?
  13. This is why you have to look at the entire car, not just a section. Your example works for stopping a levatating spinning wheel. This brake torque is also sent through the tire and to the road, and this must be taken into consideration. The torque caused by the brake rotor generates a force at the contact patch which is opposite to the direction of travel. This braking force is what slows the car down, and it is what must be reacted by suspension links (EDIT: along with the other torques and moments). Jon brings me to my other point. Weight transfer happens because of a braking force at the tire contact patch. If all you had were torques, then there would be no weight transfer! Brake forces at the wheels have leverage on the car, proportional to CG height. The taller the car's CG, the more leverage the brake forces have on the CG, the more weight transfer you have. I can draw and scan in an FBD when I get home today, if it will make this easier to understand.
  14. Not true at all. Take a look at our exhaust design sticky: Exhaust Tube Sizing Then I don't see why you need approval from others to do so. If you like it, use it.
  15. The 260Z tach is unique to the model. Electronic ignition was first introduced to the US Z line in the 260Z, thus it got a 3-wire tach similar to the 280Z but with a faceplate similar to a 240Z (yellow at 6500, red at 7000). This means that 280Z tachs are interchangeable with the 260Z, but not the 4-wire 240Z tachs. The 260Z tachs seem more prone to fail, so they often get replaced with 280Z ones. I replaced my 260Z tach with a 280Z unit and kept the 280Z faceplate (yellow at 6000), but that can easily be swapped. That being said and as others mentioned, there is not much point in revving a stock or stock-ish engine that high, they don't have much left above 6k.
  16. Wha? Draw a free-body diagram of a car under braking and there will be more than a torque on the wheel. Brake pads generate a torque on the rotor which is directly connected to the tire. This torque produces a force proportional to wheel radius (lever arm). You must look at the car as a whole. The strut picks up vertical loads, meaning the springs compress because of load transfer caused by brake forces at the tires having leverage on the vehicle's CG. The T/C rod picks up longitudinal loads during braking. Moments produced from the braking forces are reacted by the TC rod, control arm and strut top.
  17. To maintain pressure? What "info" is it that you need? If you want to use it, weld it in. This post is somewhat vague, and I'm not sure what info or suggestions you're looking for, but your answer can probably be found on here, google, or youtube.
  18. Leon
    Juke-TR
    Nissan Juke = Joke + Puke
  19. Sorry, I guess I didn't fully understand your plan. Yes, moving the end-link further from the end will increase roll-stiffness. However, I would probably put the effort into adapting an adjustable bar instead of playing with the stock one.
  20. Besides figuring out how you want to do this, may I ask why? Any adjustability added to a stock ARB by drilling holes will decrease roll stiffness from stock levels. Is this the result you're looking for? It would probably be easier and more effective to buy/make an adjustable bar which has a roll stiffness range from below stock to above stock.
