Leon
    25
Everything posted by Leon
  1. The ratio is stamped into the ring gear. i.e. 39:11 for a 3.54 (39/11). EDIT: Jon beat me to it!
  2. It doesn't matter. The dyno records engine speed and roller speed, therefore all intermediate ratios are accounted for. I assume they just input tire size to account for roller-to-wheel speed differences.
  3. Exactly! I was happy today to finally have some time to work on the Z. The stock brackets bolt on to the "Nismo" seats with minimal effort! All I had to do was remove the stock brackets (not as easy as it could be) and press out the seat-to-bracket bolts in my bench vice. Then, the stock brackets needed a new hole drilled in them to match the hole spacing on the new seats. Unfortunately, the seats do sit me a bit higher up than stock. I had to remove my roll-bar in order to fit comfortably. I do fit, but a helmet makes things very uncomfortable. I'll finish installing the seats and see if I like them. If not, then I can always switch back. I'll try to upload the pics tomorrow.
  4. The weld itself is strong, but a welded joint is a stress riser. If failure occurs, it will be at the weld, not the weld itself, as Stepan already mentioned.
  5. FWIW, If you can't get the Pertronix, just toss the points back in so that the car is drivable while you wait for your parts. Good luck!
  6. Check forum classifieds, they pop up a lot around here. It depends on your location, I bought my 3.9 off of Craigslist for next to nothing. Junk yards are a good idea as well.
  7. Get some purdy new ones: http://www.mmsacc-stainless.com/html/Datsun.htm
  8. What's the difference between installing coilovers, and dropping the car 1, 2, or even 4 inches? Installation is the same. Your decision on strut tube sectioning should be based on how much you plan to lower the car. As detailed in the archives, the struts should be sectioned if you plan to lower the car more than 1.5-2 inches. Otherwise, just get a Ground Control kit, shave the perches, and go. I don't understand your reasoning behind getting inserts with a "2in shorter extended length"? I recommend re-reading some of those threads until you have a solid grasp of what's involved, and the reasons behind performing certain tasks.
  9. Correct. The slave mounts to the transmission, with its rod pushing against the shift fork.
  10. It's not a problem, especially if the lines are small. Place the log where you see fit, as long as it's in the proximity of the intake, you'll be fine.
  11. Sorry for the tangent, but I have Megajolt and will be finishing the install soon. Since the Cannon manifold has a built-in balance tube, I should be able to get away with using one of the already tapped ports to run a line to a vacuum canister and then to the MAP sensor. If your manifold has a balance tube already, it shouldn't be necessary to add a vacuum log. For those without a balance tube, the solutions in this thread are solid. Just tap all runners and tie them into a log. If the log gives a poor signal, then implement a vacuum chamber.
  12. He was asking 400, so I think I got a decent deal. Maybe this weekend will give me some time to see whether they bolt to the stock rails and how they fit in the car. I've really been splurging on Z-stuff recently, and I'm feeling a bit financially irresponsible. There is a 4.375 R200 CLSD in my future! I made a promise to myself to not spend any more money on the Z until next year...
  13. This is all detailed in the FSM. There is no need to remove the dash to get the gauges out.
  14. I agree, the '06-'07 nose grew on me as well. Upon first glance it was ugly but it appeals to me more than all other years now. I'd have plenty of fun with a WRX or STI but they're just not the car I'm looking for right now. In case I have to get a more practical car down the road, the '06-'07 WRX wagon will be at the top!
  15. It all makes sense now. The Mazda5 is a quirky little car, very practical and utilitarian! Maybe not the most efficient choice, but I guess you need a tank when it comes to commuting in NC!
  16. I agree, very clear and concise. Well done!
  17. Wow, nice! I agree on the years as well, it's the most polished evolution of the WRX, IMO. Why'd you sell?
  18. Thanks! Ended up paying $280. Thanks man! Supposedly, they bolt up to stock rails. I've yet to try, but I'll definitely give a report on how they fit compared to my stock seats. The thing is though, I'm not really sure on where these seats came from. The guy I got it from said that they are replica seats, possibly from "East Bear" but I really don't have an idea what they are yet. I'll be researching to see if I can find the seats' origin.
  19. Got another little Christmas present for myself today! Looks like I need a new camera, they look better in person.
  20. I haven't driven an '07 and older STI but the '06 WRX shifter and clutch felt better than the '08 STI, among other things. I think the weight and transmission would be my biggest complaints about the '08. I've liked the WRX wagons for a long time, and if I were forced to get something practical I think an '06-'07 would be at the top of my list. I can haul almost anything, fit the dogs, go skiing, and still have fun on the twisties! As far as putting in engine in the back, it would be much easier than what I'm used to doing: My brother and I usually pull 'em out by hand.
  21. No problem, hope it gave a boost to your motivation! You'll have to drive it sometime!
  22. I agree, I'd keep the stock tank for a street car. Putting in a fuel cell is a PITA, at least when doing it "right", and I'm sure a good quality one is pretty expensive. Like I said, just put in new fuel evap lines when you do the tank and you'll be good to go, along with a working stock fuel filler to boot!
