Leon
    25
Everything posted by Leon
  1. I think I bought my two cans (440 rd. each) for $130-140 last year.
  2. Damn, quite a collection! I only have one currently, a Russian M91 manufactured in '42. I love the surplus ammo, although the corrosive stuff seems to make my bolt stick after a while. Although, I do have enough rounds to fend off a zombie invasion! Ever go to the Los Altos range? It's a nice range and an awesome drive getting to it.
  3. Take a look at a wiring diagram, or how about the FSM? That button would be the emergency switch, which bypasses the starter interlock when pressed with ignition on. It has absolutely nothing to do with emissions.
  4. Higher octane fuel does not have a higher energy content, that is a common misconception. Higher octane has a higher resistance to ignition, thus it is used with engines running higher compression ratios (or boost) which generate more heat in the cylinder. Minimum octane required changes with many factors, including ambient temp, pressure, and compression ratio, among other things. Use gasoline with an octane rating high enough for MBT timing. The thing is, spark timing is a very important factor in engine operation, with compression ratio being a more minor one. A bump from 7.5 to 8.5:1 compression may net 2-3% gains, but drop spark timing a few degrees from MBT and you're way down on torque production. Now, NA L-engines have been turbocharged in the past with good results. As long as the tune is correct, there should not be a problem. My 2 cents.
  5. Well there's your problem. Swap left-to-right and you'll be good to go.
  6. Are all of your bleeders at the top of your calipers?
  7. No, the front struts of the early 260Z are slightly longer and have a lower spring perch than the 240Z. The rear struts of the 240Z and early 260Z are the same. I think the late 260Z has the same tubes as a 280Z.
  8. Actually, he is 100% right. This has nothing to do with Hooke's Law. Cutting a coil spring will increase its spring rate, k, since it changes the spring's properties. Whether it's a linear or progressive spring doesn't matter. Decreasing the amount of coils increases the spring rate, as show by the spring constant equation: http://engineersedge.com/spring_comp_calc_k.htm
  9. If both have balance tube, there shouldn't be much of a difference. What you refer to vacuum is simply pressure below atmospheric. Pascal says that pressure is equally distributed across all surfaces in a confined space, so no, there will not be 3 times less pressure if you have three separate taps. Running six individual lines to each intake tract may be slightly more accurate (more viscous damping, meaning cleaner signal) but for all intents and purposes both setups should be similar in their results. You can also use a small chamber with a restrictor at the inlet, if you want a cleaner signal. What are you trying to achieve, working vac advance?
  10. A surge tank does not necessarily need to be mounted in the engine bay...
  11. Damn, you aren't kidding about the popping! Sounds pretty nice though, I like the tone.
  12. A little discussion we had recently: http://forums.hybridz.org/index.php/topic/101932-compound-and-twin-charging-discussion/
  13. All of that can be alleviated by lightening the flywheel and putting on a better exhaust. If that's not enough, stick an early cam in it and get a few more rpm at the top end.
  14. A smaller wheel+tire combo will go quicker, stop quicker, and have less unsprung weight thus improving traction.
  15. My complete programmable ignition system cost about $400, and there are ways to do it cheaper. I didn't have the time to fabricate the sensor mount and press on a trigger wheel so I went to the easier solution. I got Derek's EDIS mount kit (~$170), Megajolt Light Jr. (~$170), and an EDIS 6 set (module, sensor, 2nd gen coil pack, plug wires) from ebay (~$60). It is possible to economize on the EDIS mounting by making your own sensor bracket and pressing on a generic 36-1 trigger wheel which brings those costs down to materials and your labor. If you have time to go junkyard shopping the EDIS may be cheaper as well, so you can have a fully programmable system for maybe $250 or so. That's damn good for what you get if you ask me!
  16. The cross-sectional area will increase by about 1.5 times and your exhaust temps might drop a tiny bit, but very unlikely that it will be noticeable. AFR and ignition timing affect EGT more than anything else. With that said, we will absolutely need a video once you get it back! I'd love to hear it under load, and how it differs from mine.
  17. I noticed that low rpm running was much improved (practically no bog and overall smoother running) with static advance at about 15 degrees, however my 260Z distributor has a terrible timing curve for my application (26 degrees of mechanical) so I have to keep it at 10 degrees static. I have a spare E12-80 ZX dizzy, but instead of spending precious time playing with distributors and still ending up with a compromise I opted for a programmable EDIS setup! I installed Derek's trigger wheel and sensor mount yesterday and will be getting the EDIS and Megajolt controller wired in soon, hopefully. Using Megajolt lets me keep the triples yet provides a relatively economical way to have a fully programmable, powerful ignition system. Load sensing (vacuum) advance will be provided via the built in MAP sensor. I know that I am missing out on a lot of "power under the curve" with my current dizzy. Once I'm done, I can punch buttons on a laptop while having a snack, instead of taking apart distributors and messing with all that crap. Hell, Megajolt lets me make temperature correction curves and allows two timing maps, switched with a flick of a finger! Try doing that with a distributor...
  18. It's the Turbonator part II: turbo exhaust augmentor!
  19. I don't know where you got it, but I got it from the FSM and that's what I run. This is not an oil viscosity issue.
  20. Wow, sad way to end it. Sorry to hear about the house and the Z. Back when I was a kid, I would build cars out of Lego all the time. I'd spend hours getting them right. Sometimes I'd screw up and break the lego-car just before or after I finished it, and get really upset and frustrated. But my mom always told me "the next one you make will be better than the last." I vehemently disagreed and thought to myself that it was as good as it was going to get, but of course she was right! Hopefully you get another Z to play with, and best of luck to you and Rick. The next will be better than the last!
  21. The difference between you're current setup and the MSA twice pipes is glasspack location. The dB may not change much, but you might get more drone at cruising speeds. For a long time I envisioned getting the MSA twice pipes, but as close as I got to the getting them, I never pulled the trigger mostly because the rear valence must be cut for the tips to fit the stock location. I had the exhaust builder install twin 2" pipes with slash-cut vertically-stacked tips at the back (Ã la 432), 4 total glasspacks, and 2 O2 bungs all for $300! I definitely could not beat that value, anywhere. One-man shop with 40 years of experience gets the job done right and done quick. Hell, I gave him a $20 tip at the end!
  22. This may help, for the suspension portion. This sticky, for the brakes.
  23. I love the sound, it's actually hard for me to keep it below 3500rpm just because I want to hear that sweet roar! I have two glasspacks in each pipe, so it's relatively docile on the freeway and around town, but good luck hearing anything else as soon as I open it up. The MSA twice pipes have one (perforated) glasspack per pipe. Loud probably won't begin to describe it! Oh, and post a video up after you get them installed!
