http://www.engineswaptech.com/forums/1/1257/ShowThread.aspx
This is copied from Engineswaptech.com the best source ive found for VQ swaps.
heres some pictures of the preliminary trial.
before you guys say anything about the seatbelt... it was the best way to lift the motor without damaging the composite valvecovers
the tranny tunnel needs some sensuous massaging and the cross member needs a cut and paste. then an engine cross member, custom tranny and engine mounts, subframe connectors, custom tranny cross member then exhaust and wiring.
more pics for you guys!!
it will be a bear to load all of them.
The manifolds are still towards the front. The built in oil cooler is out of the question. With some firewall massaging the stock plenum should work. (sans hoodlatch of course) The motor needs to shift to the passengerside about an inch. The transmission tunnel could have been left intact if i felt like drilling out every spot weld that held the stock tranny mount brace in place. Its easier to just cut the tunnel and weld a new piece of sheet metal in for me The water temp sensor should have just BARELY enough room to fit. Shifter location wont be bad at all aswell.
