HowlerMonkey
Posts posted by HowlerMonkey
Wow!!
I'll bet you were listening to every sound and scanning gauges like crazy on the way out there.
Did you do this without a "safety net"?
Sounds like one of the left over heads off of Bob Lentz GT2 car of possibly Greg Master's car that was purchased with something like 3 electromotive engines back in 1990.
I remember the engines sitting upstairs at datsun dynamics but I'm not sure what happened to them as Greg's dad flat out liquidated it with zero thinking and a lot of good stuff never made it to the hands of those who could do something with it.
The two pieces kind of slip into each other once they are lined up.
If you take it apart and get it lined up, you still might have to push them together since I seem to remember then almost snapping together.
If you are sure it is rich, I would check the sensor near spark plug #5 for corrosion on the connector.
If this sensor does not have good connection of is unplugged, the car will run extremely rich.
It might just be that the regulator being stuck or clogged but it seems you are all over that.
That can be checked by pulling off the return line and seeing if you have flow out.
Most spanners are too thick to let you get enough bite on the bolts.
I have wrenches I ground thin specifically for driveshafts.
Equal length will help off boost response and.........make more power at low rpms which has the side effect of causing the engine to output more exhaust velocity which has the side effect of reducing boost lag.
Driveability makes driving more fun and much less like a chore.
It's probably not water in the tps itself since just most have cracks in the connector's boot.
If water completes the circuit there, your ecu will think the throttle is at idle position at all times and do exactly what yours is doing.
If you do try to waterproof the boot, don't use certain types of silicone since many of the darker colors (ultra black and toyota FIPG black) will conduct electricity and you will have the same problems.
It's all about the unibody as to the amount of hard work required.
I would check around where the tension rods mount and make sure the core support and where the frame rails meet the firewall are OK.
If you find the unibody ok, then finding a car that is complete but with a bad unibody comes pretty cheap and could net you everything you need.
Made a lot of money on the stanzas that did that in the early 90s.
I actually had a battery that worked great and suddenly, when I came back out of a video store, it did the click thingy like it had a bad terminal.
I got out and found the terminal hot so I removed it and cleaned it to make good contact.
Same issue so I held the key turned to see if the load would give me indication of where the trouble was by smoking.
Terminal was hot again.
It turned out the terminal had broken through almost all the way inside the battery case and I was lucky to not have it blow up.
Bizarre.
If everything else in the fuel system is OK, you should be able to run 12psi with no troubles.
I've seen N/A engines break the skirts from being revved when cold.
I also had a car that had a thermostat stuck open in the winter on the highway and I broke the skirts on all six pistons with no ring damage.
Unplug the kickdown switch and don't have the straps pulling straight backwards.
Better to have the straps pulling almost straight down and let the car run up on the rollers a bit rather than having it cinched down.
I'll be running a 1000+hp car on the dyno today and strap angle as well as where you strap the car is very important.
I've seen someone use ultra black rtv on the rubber boots over the tps harness and it caused the car to think the throttle was at idle all of the time because it conducts electricity.
Restricted exhaust maybe.
Or........you have a sensor issue.
I mean the one you are talking about.
The metal line that goes to the tranny..........it goes there for a reason.
How were the piston skirts?
I bought an engine from someone here and found 5 and 6 had broken skirts.
I had another engine.........a N/A f54 that a hurricane had filled with the cylinders with inches of water to the point that a crust of rust formed where the water level was the highest that I had to poke through just to see the piston tops.
I knew that the rod bearings were new and that the rods had seen zero abuse so I used a 3 foot prybar and a big hammer to hammer them out putting dents into the pin bosses as I hammered them past the rusty bores.
I figured I would only keep the rods and bearings.
Once they came out, I looked and found no broken ring lands and decided to soak the piston/rod assemblies in carb cleaner which cleaned everything up and I spun the rings around until the grooves were spotless.
I honed the turbo block that had the broken piston skirts and installed the n/a flattops and the engine is perfect.......no burning oil and perfect compression.
I put it into my M30 infiniti and drive it every day.
That hardline goes directly to the vacuum modulator.
If plugging the barb did no good, then there isn't a hole rubbed in the metal line or a bad diaphragm in the modulator.
A bad modulator will usually foul out spark plug number six and the car will smoke badly at idle or decel.
If you didn't get oil pressure after cranking it a bit, your pump may have lost prime and won't pull from the pan.......or the pump is bad.
When priming a car, I usually pull the oil pressure sender and see if oil comes out when cranking.
If it doesn't in a pretty short time then it is most likely that no amount of cranking will get you flow.
There are two ways to "prime" the pump.
One is to remove it and turn it while filling one side with oil until you end up with both holes filled.
Also....put a bit of oil down where the shaft goes in.
Another way is to take off the filter (put back on the pressure sender) and stuff a hose connected to a funnel into the galley that extends forward from hole that feeds the filter (not the center hole).
That's the one toward the front of the car of the center hole and if you look at it carefully, you can see how you would be able to stuff a soft clear hose of 1/2 inch outside diameter into it enough to get a good seal and have the other end attached to a funnel.
Put a bit of oil into the funnel and hand crank the engine backwards (or have someone else lie on the ground and crank it from below) while you watch the oil.
You should immediately see a column of oil being sucked down into the galley which leads from the pump output (remember cranking backwards makes the pump draw through that same galley).
Once you've run about half a quart into it that way, you should be able to spin on the filter, crank the engine and get pressure right away.
If not then your pump is bad like mine was.......or you have a leak between the pickup and pump or between pump and front cover drawing air rather than oil.
After this method failed in a recent engine build, I tried another pump that had been laying around for 10 years, did the same prime routine and got immediate pressure.
One other possibility if the boots are open.
A piece of gravel sitting on the rack "gear" grooves can bind when the pinion gear meets it.
If you turn on the A/C, at least one fan should come on.
If you disconnect the coolant temp sensor, all fans should come on with key on.
If you have access to a scan tool (not a code reader), then you can go to active test menu and command fans on.
If you don't get fan operation with commanding fans on, then check whether fan relay is receiving the negative to trigger it.
Another thing is that many chryslers command fan on only at a pretty significant temperature...........like about 230 degrees or so.........more than enough to boil water in a cooling system that doesn't build pressure.
If your system does not build pressure from a leak or you are running it with the cap open, you may well could see it boiling.
Since the alternator ground should be just a ring terminal bolted to the body of the alternator, then it should be the same as engine ground.
I believe the ground lift referenced at the other site has to do with grounding between body and engine.
I always keep a set of jumper cables handy and clamp one to a bolt on the body and one to the engine and check if symptoms change or go away.
While being a diagnostic specialist, I found at least 4 per week with a bad body ground out of 15 or so calls per day average.
Battery tipping over and touching positive terminal to the body or an a/c line will also do that.
I repaired about 10 ecus a day for standard motor products and there were a lot of tipped batteries that burnt the zener diodes.
Did anybody put some sort of "stop leak" in the system?
I remember GM had a bunch of front drive cars like the citation that would lock up the power steering from debris sticking in a valve.
Modified l28et manifold
in Nissan L6 Forum
Posted
I'm normally one to disagree with it but only on road race cars where I have plenty of A/B comparison experience.
Off boost response in road race environment is pretty much a non-issue since most engines never come down in rpms outside of where they make good power.
Another down side to longer runners is more piping that will be getting red/white hot under long pulls which means more surface area with which to radiate heat under the hood. (really only an issue when under boost and you're moving anyway so airflow helps).
