HowlerMonkey
  1. The VG33ER is already set up for boost.
  2. Don't buy the left hand bits from harbor freight. The ones I recently bought all dulled even at 120rpms with cutting oil.
  3. R200 from 280zx non-turbo..........or R200 from 280zx turbo and find a flange from the two cars mentioned in the post above. If you're going through all the trouble, you should probably not settle for the u-joint type r200 axles and get the R200 c/v type axles. The 280zx n/a R200s will have the greatest variety of available ratios as most 280zx turbos have 3.54.
  4. If the ring is pitted, you might have the same pitting on the pinion bearing. If the car makes a whooshing/hissing noise, then it's the pinion bearing.
  5. You will need the r200 and the axle shafts....and possibly the companion flanges on stub axles if they are different bolt pattern. Also......I believe the R180 uses the smaller M8 bolts on a round flange meaning you will need to get a differential flange that matches the round flange with 8mm bolts. I believe the source for the flange you would need to match any driveshaft that mounts to a r180 would be from a 280zx non-turbo or a 200sx turbo.
  6. If you're going to the 300zx coil, you might want to use the power transistor which is usually attached to it and wire in the condensor/resistor unit (usually located elsewhere on the harness) that you find on vg30 cars. The condensor/resistor unit has both the resisitor and condensor in a single unit that plugs into a single 4 conductor connector. It looks like a connector with a nothing more than a blank plug inserted but does have both. It's easy, to get both the condensor/reisistor unit and the harness plug from the junkyard for about 3 bucks.
  7. The time to get M30 parts is now. In a couple years, only collectors will have them. I went with a L28 to get turbo sweetness without the troubles that car has fitting a turbo to the VG30. It seems the distance from steering rack to firewall is a lot less than the Z31 causes some turbo clearance issues that are near impossible to get around with the stock manifolding. Satan does have a manifold for one that relocates the turbo.
  8. I think satan had some ideas on fitting a turbo using a cross-under pipe setup like that.
  9. I like that fuel rail. I should make two of them to use with the dual feed injectors which should alleviate any vapor lock problems.
  10. How many pairs of socks have metal splinters in them?
  11. Sweet manifold.......good to see that it won't fall victim to causing venturi effect on number one cylinder..........clever design. I expect to see one shaped roughly like a woman's boot at some point.
  12. I found that the warmup regulator and the idle air control were both stuck open on mine and that someone had adjusted down the throttle plate to compensate. I replaced that metal spider of hoses between the parts one hose that goes between idle air control and warmup regulator and another one that goes from the one way valve on the manifold to the barb on the turbo pressure tube. After that, I replaced that crappy screw stop and locknut on the throttle body (idle) with a longer bolt and a nut of a larger outside diameter than the bolt head. I also cleaned the throttle body which I found amazingly gummed up. Everything is fine now and I've moved on to the M30 ecu so I now have a standalone 1981 setup complete in a box I keep in the trunk and a fuel pump jumper wire for an emergency engine management system. I still have egr control and a/c idle up working.
  13. I walk the junkyards measuring anything that looks like it might work. Some cars come with a metal coupler between pipes which is always handy as well to get a non standard swap done.
  14. Here is a pic of what happened in 1 mile of driving with crispy clutch frictions. You can see the galling that started when the low/reverse clutch lost the friction material and ended up metal to metal. The car still moved fine (until filter clogs) and I encountered no slippage. Had the chunks not blocked the filter causing a no-drive condition, this tranny would have died the horrible death that most 3n71b/4n71b die when driven afte they start slipping. If I didn't know that most every single 3n71b and 4n71b in the junkyards had been burnt to the point of needing most every component replaced, I might have been inclined to rebuild these things for profit since they are cake to work on.
  15. Straight six turbo goes in like it belongs there.......it was incredibly easy and I still have a mechanical fan. I just don't see nissan, who has a history or using the same unibody for muliple car lines, go and make a unique unibody for the m30 when the dimensions required to make this rare car are the same as the skyline.
  16. It is because you somehow got the bulb in 180 degrees of what it should be. It is possible if you push hard enough. This will sometimes blow the fuse but it will also backfeed the parking/dash lights with power that is supposed to go to the brake light filament.
  17. One controls the idle and one controls the egr valve.
  18. I am probably mistaken on the module....don't remember what came on the 280z. Was thinking it was a E12-80 equipped distributor but probably isn't.
  19. Mitchell on demand and Alldata should have waveform detail in the diagnostic proceedure for a VSS code.
  20. The infiniti M30 shares the same unibody as the R31 and, to some extent the R32. Just buy one of them for a grand and bolt in the skyline drivetrain, suspension, and brakes. Anyone who drives a skyline in the U.S. will end up having to replace his badges on a monthly basis because of vandals.
  21. Tomorrow, Obama will unveil a "dramatic" plan on automotive emissions that may very well impact us here. I will be especially interested in whether they offer exemptions for older classic cars and what the definiton of "classic" will be. Hopefully, they will use the tailpipe test as the tell all rather than just disqualify a car because of it's year of manufacture since I will be running my l28et on an OBDII ecu soon.
  22. The important sensor is the one who's harness gets in your way when replacing spark plugs. It's the one that tells the engine management system the coolant/head temperature. The connectors on these are similar to the injector connectors and are known to corrode (turn blue/green) very badly. If it's disconnected, you will get unbelievably rich running but corrosion can add to resistance which could cause the ecu to think the car is colder than it is and add fuel accordingly.
  23. The re-animator of this thread did add new information that may benefit someone using the search function so all is cool.
  24. Clogged strainer............but what parts of the tranny are clogging it may be the bigger concern. Usually a clogged strainer will allow you to turn off the car once it loses drive, and immediately restart and have drive........for a very short time.
