HowlerMonkey
Posts posted by HowlerMonkey
  1. This looks promising.
    It seems the crank angle sensor is only there for diagnostics and not the general running of the vehicle.
    It also seems it does use the flywheel/flexplate teeth of which the count is 120 teeth.
    The L28 also has 120 teeth!!
    This means it shouldn't be too hard to implement this using ecus from any late single cam vg30 or vg33 (at least up to year 2002) and get the benefit of all the sweet diagnostics capabilities as well sequential fuel injection and the aforementioned ability to update the run time calibration file from the data link connector.
    Of course, you will need to run dropping resistors since the ecus expect high impedence injectors.
    I'm still working on the M30 sequential ecu with this engine but I may abandon that and go this route sooner than later.
  2. Since he's getting the 2 or 3 second prime, I would assume he's using the L28et engine management system.
    If so, the ecu sends a negative out to a fuel pump relay on the blue with red stripe wire which you can find on a six way connector.
    After the prime/starter running/ the ecu won't send out the negative to energize the fuel pump relay until it sees a good crank angle sensor/distributor signal.
    The positive output from the fuel pump relay goes out also to the warm-up regulator on the green wire of the same relay.
    Depending on the year, some 280zx turbos use a fuel pump speed controller which is on the body harness rather than the efi harness.
    I believe it acts on the negative side providing a couple of levels of grounding resistence.
    You can probably go around it and might have already done so if the negative to your fuel pump is grounded to the body.
  3. On 280zx, I always use the front crossmember and the rear diff.........unless I have a flat tire on the side of the road.
    Since the 50 buck jack that most people buy doesn't fit under the front, I usually drive the car onto two small 2x4 blocks.
    If I have to jack on the pinch welds (stock points) I am careful to use a wooden block turned 45 degrees and don't lift it high enough to cause the jack to try to pull which will could cause the dreaded fold over of the jack points.
    I worked at the Z shop of miami so long ago that my bay had no lift.
    I had to jack up every car and put it on jack stands to work on it.
    After that experience, everything now is a cakewalk.
  4. I prefer good gameplay and realistic physics to graphics candy anyway.
    That's why the Wii grabbed so much market share on units with superior graphics horsepower.
    That said, it's hard to beat Grand Prix II or Grand Prix Legends (viper racing is the same as GPL) for realistic driving but there are newer games in GTLand GTR which have better graphics and sweet multiplayer options.
    If you like good gameplay and airplanes, I recommend Warbirds Freehost which is ...........well..........free because some russian developers got ahold of the code and are now hosting arenas full of people itching to shoot you down in a WWII plane.
    It's run on an older version but that's the only price you pay since it is free.
    If you think you will take off in a mustang and own, you are sadly mistaken as the mustang is only the top performer at super high altitudes and speeds and you just don't find many opponents who want to spend 15 minutes to climb that high.
    Come on over and receive some pepperidge if you dare.
    You do need a stick to fly and I recommend a "twisty stick" because the twisting is for rudder action.
    A good entry level stick was the top gun fox pro but it seems to have been discontinued but.......the more generic thrustmaster "usb joystick" looks much like it and probably costs less.
    It takes a bit of installation mojo and learning curve but I'm still playing it 10 years later while Grand Theft Auto and all the other Xbox games sit collecting dust.
  5. Clearly, I need something better than the cheapy harbor freight auto darkening helmet.
    On using it, I have found out a few things.
    It works as advertised but it goes so unbelievably dark that I can hardly see my work.
    This is at the lightest setting while full on dark would probably protect one from a nuke detonated only blocks away.
    Does anybody have experience with a different brand that has a better range of "darkening" that is actually useful?
    One more thing.........don't use an auto darkening helmet outside at night.
    I stuck my first "night arc" with this helmet and got a big strobe effect before the auto darkening clamped down.
    I then tested this by pointing a light at the solar cell to keep it live and got no strobe effect.
    I believe this is because it is powered by a solar cell so...........if you don't have ambient light powering the unit, you get a delay in darkening since the unit is not actually "live" in the dark...........apparently the circuitry doesn't include a capacitor/condensor or battery like device to keep it live in the lull between arcs.
    Just a heads up that will save your vision if you weld in a dark area that might not have enough ambient light to keep the unit responsive.
    I'm sure taking it apart and using a battery rather than the solar option would stop this but I'm done with this helmet anyway because of the "too dark" experience.
  6. I test fitted a merlin 9.4 liter (572) and it went right in.
    It seems the ford modular engine is damn wide and you might have trouble fitting it.
    I've seen the caddy 500/501 in a 910 maxima and I really love that pic of the 472 but your choice may depend on availability of parts since that pic above probably has most every performance part made for the caddy engine in one place.
  7. It depends on what S130 the R200 came out of.
    The non turbo S130 should have the one on the left as well as the S12 200sx turbo R200.
    The one in the center is found on s130 turbos.
    The one on the right fits Z31 and infiniti M30 and possibly the S13.
    I measured the R180 flange that is the size of the one on the left and it does not bolt onto the R200.........the bolt is the same size and thread but the splined part of the shaft is larger.
  8. If you're running a catalytic convertor, zero muffler has a nice low rumble without any harshness.
    I'm going with two chambered mufflers side by side because of restriction because I like my cars very quiet.
    Someone here (djz) is doing it but hasn't finished it yet but has pics of two side by side.
  9. I walk the junkyards most every weekend for this kind of stuff but that pic up above sounds like the best solution.
    I do know that the early toyota camry (84 84) with distributor in middle of the head comes with a intake tube that worked on my 1984 L24e maxima but I didn't use the turbo airflow meter.
    I'm going tomorrow for one that goes from the turbo inlet to the MAF on a L28 in infiniti M30 car.
  10. All this work is great, but i think either Howlermonkey is missing the point of Unclejesse's post, or he understands and i am just missing it: the '02 villager 'distributor' wheel, from the picture, LOOKS very similar to the '82/'83 ZX 'distributor' wheel. If they are not identical marking wise, are they able to be swapped out mechanically? still doesn't sort out the crank angle sensor, but it does provide an easy method of getting the cam sensor sorted out.
    Sure the 280zx distributor optical wheel is different than the 300zx wheel but the 300zx wheel is the same as the quest wheel..........I've compared both and have run a z31 system on the L28 as early as 1989.
    It's just a matter of time before I find a quest/villager/pathfinder/qx4/frontier that is apart so I can see the tone wheel...............that and a real job so I can stop rolling up my change.
    In my 3 cars, I have found 160.00 worth of change in the last week.
    If nissan/infiniti hires me either as a tech or service writer, then this will move really quickly.
  11. The quest ecu is sequential, it requires no extra coils, it is fully OBD2 compliant, it runs with a single coil, it expects the same distributor waveform as delivered by any VG30 or VG33 single cam engine from 1984 to 2002, and you can flash it with a new bin file through the OBD2 port.
    The only "work" needed to run this is putting in three 02 sensors and supplying it the crank angle waveform it expects.
    To do this, all I need to do is actually see the tone wheel so I can duplicate the signal it creates and the rest is easy though some fancy placement of the 02 sensors in a single log manifold might be needed to satisfy the "two bank" scheme.
  12. The ES and the RX were front drive but some RX are all wheel drive and the RX400h (which I drove as a company car when I worked for lexus) was a really unusual setup with an electric motor in the rear of the car.
    They were not a whole lot bigger than a differential and one in the front and one in the rear of a little car like a toyota FX (steep hatchback) would be a lot of fun.
    I'm just waiting to find two of those rear motors for sale.......someday.
