Mudge
Everything posted by Mudge
  1. Must depend on who you talk to there, most of the people that go there seem to by and large say they have bad attitudes and overcharge.
  2. Some more testing, which leaves me puzzled. Pin 5 I thought, only shorts to ground to trigger a firing event, however I find that with key ON it is a constant short to ground??? With key OFF I show about 1200 ohms to ground at the intake manifold.
  3. Without bending with a mandrel or hydraulic bender setup, you would compromise strength by hacking up the tubing and welding angles into it, you can legally do it in some race organizations but you must run larger tubing, tubing size depends on the weight of the vehicle.
  4. Troubleshooting as to why no spark on my 82 ZXT --> 73 240Z car. I've tested diz pulses, I've turned it by hand to do this, and heard injector activity, yet still no spark. So I tested my old 240 coil and my ZXT coil, resistance figures are lower for the 82 coil so I think its workable, and I have seen spark once from the output, but only when shutting the car off. Neg to output 8.6k ohm Neg to pos 1.5 ohm Coil transistor lead to lead is 4.14k ohm, but I dont know if there is a method of testing that? To coil transistor negative I have pin 5 (YW), and to coil transistor + I have the old wire, as well as IGN (BW I believe but have to check my notes). I do see voltage at the coil when IGN is in RUN and START. One thing I'm curious about is pin 16, this goes to LR on the fuel relay, and to "coil +", I'm not sure if this is neccessary or not, I am not using the stock fuel modulator or relay, however they are all left in place. I can't find any diagram which actually shows this LR going to the coil however, I've only seen it in text, so I dont know if its even important. The fuel relay gets its power elsewhere, so I am thinking its a signal to power the fuel relay only, and then goes back to pin 16 to tell the ECU what exactly? Or perhaps this is simply how the ECU actuates the fuel relay if the inhibitors are active or not, dont know.
  5. Custom Art Carr boxed frame, $5000 or so. Front/rear suspension are C4.
  6. This has been around the Net a While, but It's worth a laugh 1. The emissions test guy starts laughing as soon as you pull onto the rollers. 2. You can't drive your car in the rain. 3. Your 'significant other' is afraid to drive your car. 4. You are afraid to drive your car. 5. You spend more on tires than on food. 6. You spend more on car insurance than on house payments. 7. You look in a state police car and see a picture of your car taped to the dash. 8. You throw your underwear in the garbage rather than the hamper. 9. You have to go to the track to buy gas. 10. Your mechanic names the new wing of his shop after you. 11. Jacques Villeneuve and Michael Schumacher wave you by. 12. You can make the Kessel Run in less than 12 parsecs. 13. You're tempted to wear your fire suit just to drive to the office. 14. Red signal lights shift to green as you're approaching then shift back to red as you're receding. 15. You arrive somewhere before you left. 16. You get pulled over for doing 155 in a 35 but the cops will let you go if "they can look under the hood." 17. You remove the $2000 stereo system to save 6 lb. of weight. 18. You are not allowed to run in the Silver State Challenge. 19. You get an anonymous phone call asking if you are interested in being in the Cannonball Run. 20. Your face looks like you are riding a NASA centrifuge when you drive the car. 22. You need parachute braking. 23. Your 'significant other' won't even ride in the car. 24. There is no possible way to "sneak out" of your neighborhood at 6 am. 25. Your pets scramble for their hiding spots as soon as the garage door is opened. (Pets, and all the neighbors...) 26. Family photos throughout the house are replaced with life-sized posters of your car. 27. Fuel is delivered to your home: in 55 gallon drums! 28. You carry earplugs in your car.(doesn't everybody???) 29. The only spot on the car which receives any regular cleaning is the windshield. (what else is there to clean???) 30. You find out that side mirrors don't hold up at speeds exceeding 145 mph. 31. Young children cling to their mommies in fear when you round the corner. 32. Birds fall out of their nests from the rumble of your 5" dual exhaust. 33. All the major Tire makers are sending you free slicks in hopes of endorsment deal. 34. The UPS guy took to taking Steroids so he could keep up with your shipments. 35. The Fed Ex guy had a nervous breakdown. 36. All the wildlife within a 800ft radius around your house got the HELLOUT. 37. The nearest Geological Seismic Surveying Station Operator knows your address by heart. 38. A booming voice greets potential passengers with, "That's right ....you paid for the whole seat but you'll only need the EDGE. 39. The earth slows in rotation when you hook up on your new slicks and head east. 40. You have to screw your slicks to the wheels. 41. Your exhaust pipes are larger in diameter than your driveline. 42. Your fuel pump flows enough to water a golf course. 43. Your compression's high enough you could run diesel fuel. 44. The sparks from your wheelie bars start grass fires on the side of the road. 45. Your engine idles at 2800 rpm. 46. You measure the fuel you use in "gallons per mile."
  7. http://www.fastassdatsun.com is thier new site, I dont know if they are updating the old one.
  8. Scotty broke his, with way under 1000 HP, but it was an automatic rear which is smaller than the C4 manual.
  9. The injectors would work fine, they are the same. You have the ECU and wiring for the 82 though? So sounds like you are set to me, I'm sure someone will chime in with anything I may have missed though. Put in the 82 diz and I think your set.
  10. Yeah, time has not been kind to my injector clips either, all of them are broken to one extent or another. One of the injectors that came today has a green top and different PN so I have to check to make sure they didn't ship me one standard injector, the rubber line was longer too, argh.
  11. Especially without the aid of gas, you need a really clean spool of wire to work with. Go buy a new spool, they are ~$10 depending what gauge/length you buy, I'd probably go for something under 30 as you dont need a thick gauge with exaust stuff anywho.
  12. Runs the same, do you know if its hitting closed loop after a few minutes?
  13. I still wonder about that coil, but it would not explain the not-starting stuff. Is the alt charging the battery? If not, then it could explain the problem after running for awhile, both low voltage output and resistance in the battery wires perhaps if they are getting hot. I got my injectors friday but haven't started on the car yet today.
  14. Good question Greg, I would think/hope that its color coded, maybe I can find something in my Chiltons about it.
  15. Depends how picky you are, tube frame from Jegs for a 240Z is about $599 I think? I saw a drag ready car on eBay for about $2500 with a Jegs tube frame. Just remember though the car made around 130 HP stock, it wasn't made for 1000HP, a local guy with an SBC 327 and a cam twisted the crap out of his body, and he had a roll bar, still after awhile the doors would not shut.
  16. "The carburator is the only device known to man to deliver an incorrect air/fuel ratio at all RPMs." Not my own quote, dont know where it came from.
  17. Works great for me, maybe your browser is updated as its a secure page. Try http://www.jagsthatrun.com and just give em a call.
  18. That is 100% Camaro, they are around 3200 pounds or less depending on options when stock, first gens have been one of my favorite all time cars for as long as I can remember! I had a 69 Firebird years ago, until I nuked the engine. As far as "uber 240Z" goes, http://www.fastassdatsun.com is probably my fave, he is a board member too. How do you think a 700HP turbo/300 shot nitrous would do with the sponsors? Its not quite the same, but you could at least get rid of some of that "useless" power for the track stuff, or you could always turn down the boost I suppose, which will help big time with heat too. What tracks are you looking to hit, or pretty much all of them? Who are you going to run with?
  19. Oh brother, when the water starts exceeding 2 feet, its time to turn back lady
  20. Good to see you back. No its not my car, he just joined the same track group that I'm in, I sure would love to have a machine like that though. I would not doubt he is in the 2500-2900 pound range, but without knowing how much fiberglass/CF he has on the car who knows, I'll ask when I get the chance! I see what you mean about the big #/sponsor thing, as for going sideways yes it can be fun, I love having horsepower but that is something I feel is a PROBLEM for me because it complicates things on the track without the experience and overall setup to handle it/put it to the ground. I also again find it more fun to be able to floor it and feel like I'm driving at the limit, instead of the gas pedal being so touchy feely, with AWD and the right driver though, I'm sure it will be a beast. How much sponsorship do you think you will really get? Are you a speed shop outfit? If not then I can say from looking at local racers, sponsorship is not only very light, but what is out there is based on winning, not really numbers. I think its the import guys who sometimes look at numbers all day, and most of the time they are only show or drag cars. It sounds like quite a project, and it would be sorta neat to see it be done, but not being a shop guy I always look at bang for the buck as opposed to getting that last 3% performance with 8x the cost, although in true racing, sometimes thats whats needed to be at the top. There are enough high HP cars out there like Supras and such though, that I think personally what would be amazingly impressive is torque everywhere, not just a narrow top end like many high HP Supras are stuck with (huge single turbos). If you could drive to and from the track, that would likewise be a statement!
  21. No crap, sign me up for one of those! I'd go for a 68 though I should get to see this guy on the track too, he just joined NCRC a few days ago
  22. I find that hard to believe, not that it could't be true, I'll bank on a near 100 pound crankshaft. Keep in mind the aluminum block LS1, its nowhere near half the weight of an LT1 (of course thats not all iron either, intake/heads are alum if you get an Fbody/Vette LT1). LS1 is around 60# lighter, plus this thing is going to move the weight distro very forward. I still look at the Jag V12 240Z, I believe it was around 3200 pounds? That weighs more than a hardtop C5. How DO they do it
  23. My brand spankin new NAPA injectors arrived today, I'll report back how the weekend goes http://www.sherco-auto.com $99 for all 6, Napa is like $74 each!
  24. Dont buy drilled rotors, they offer no benefit other than selling more rotors for the companies that make them because they will usually last 1/3-1/4 the time of a normal rotor, cryo treating them may help, but they offer no performance benefit other than bling bling looks. There is a way to use a vented rotor with the setup, but there is a specific caliper to buy, and unfortunately I dont know the denominations for that. Keeping the solid rotor though, is a waste of upgrade effort IMO. For a street car it wont matter hardly at all, but if repeated stopping is your game, get a vented setup. I road race the car and find frankly, that steel lines + some good fluid are going to keep me happy for quite some time, my 195/60 300 treadwear tires cannot stand up to my brakes, so steel lines IMO will make any stock setup just fine until you get some big stickies, which is something I will upgrade in a few months. In stock form, rear brakes are overly powerfull without a biasing valve. The reason I'd upgrade them is mainly ease of maintenance with a caliper setup vs drums, easier brake inspection and lighter weight as well.
