baby_Carlton
    9
Everything posted by baby_Carlton
  1. Hi guys, thank you all for the input. caperix, I liked your idea so I after searching the interwebs, I found a 1/2" drive thru socket wrench with the appropriate sockets and extension. I was not able to loosen the nut unfortunately due to the risk of stripping the top of the Koni shock (which I ended up doing badly on one side). I ended up popping off the nuts by drilling holes on opposite sides of the nut and using a chisel/hammer combination to break the nut off. One strut insulator came off anticlimactically just barely jumping 6 inches after the nut was broken. The other insulator flew off and left a small scratch in my cabinet door. This was a scary process and would recommend people to avoid doing this at all costs. If I were to do this again (with more patience), I would follow 1969honda's advice and use a nut splitter. Lesson of the day: Don't over impact your nuts kids. 🥜 Here's photos of the car as it sat after swapping to a lower spring: Update: Marugen flares from Japan-land Currently taking notes on all the flare FAQs and Forums I've found for this project. Now waiting on hardware to ship and for my balls to grow big enough to cut into my car. ⚽🏀
  2. Hi All, I did a very not-so-smart thing and over torqued the shock nut (top nut going into the insulator) when installing my Koni Yellow shocks into the rear strut tubes. Does anybody know how to free this nut without damaging the shock? In the pictures it is clear how far down the nut is based on the number of threads showing. I believe the nut has gone so far down that it is past the normal shock threads and is "threading" into the non-threaded part of the shock. It is impossible to fit a wrench around the smaller hex end just below the adjustment knob of the shock while also using a larger wrench to loosen the shock nut due to the height of the insulator surrounding it (and yes, despite the pictures being taking when installed, I have taken the strut assembly off the car). I am tempted to use a thick mouse pad to wrap around the shock tube itself and hold it still with vice grips while I loosen the nut but I'm anxious to do so. If anyone has any recommendations or has dealt with this before I would greatly appreciate your help. Thanks, Liam
  3. Have a S30 Series 1 Chassis, decent engine makes 150bhp with an L28 mated to a Type-II 5-speed, great suspension and brakes. PM if interested.
  4. I love the RS8 Watanabes, especially when they're custom barreled to some double digit width. Also thank you! I've seen a few S30s with the Formula TRs on instagram, I think the wheels look great. It would definitely be interesting to see them on more JDM cars.
  5. Yes my wheels fit over the hubs fine though I should've purchased my wheels with more offset so they wouldn't poke as much. Running Fifteen52 Formula TR 225/50R16x8 +0 with non-rolled fenders, should have ordered at least +10.
  6. I'm currently running AZC front brakes and 5 lug hubs and T3 rear brakes with the Ebrake. I think both are equally great quality though I've had issues getting the e-brake function to work on the T3 rear kit.
  7. While there's a topic open about Fiber Glass Mafia, I'm curious if anyone's used their "Mafia" Fender Flare Set. Link: http://www.fiberglassmafia.com/store/p34/S30MafiaFlares Look a little different than your standard ZG flares, a hybrid between Pandem/Rocket Bunny and ZGs in my opinion. I like how the rear fender flares don't mount to the door unlike the Pandem/RB kit.
  8. Have a 1971 Series 1 with complete brakes, suspension and wiring. Going to do chassis chassis reinforcements (Subframe connectors) soon, PM me if you're interested.
  9. Hi, I talked to Dave a couple years ago about doing this exactly and he said that his coilover system would not fit with T3 camber plates. -Liam
  10. Yes I found that I get around a 1/10 of the adjustment out of the camber plates vs adjustable control arms. I think I wait to use the KMAC plates if I ever do a coilover conversion.
  11. Hi all, I'm wondering if anyone knows how to make KMAC camber plates work with OE struts (non-coilover conversion) for 240z's. I've searched around the forums for a while and tried to find some guides or information that could help me make these plates work with my current setup. I briefly talked to John C. a while ago about making them work as he had previous experience with them on a customer's car but other than that I haven't been able to find much. I had a shoulder bushing made to make the KMAC plates work with my struts but after experimenting with them I found that they raised my Z by about an 1-1/2". I'm curious if anyone has been able to fit them without the major raise in ride height. My current strut setup is Tokico Blue lowering springs, Koni 8610-1437 single adjustable shocks and OEM strut insulators. Any information or help would be greatly appreciated. Thank you Liam Edit: changed topic heading
  12. I would give KYB a go if you're looking for something a little softer than Illuminas. Koni Reds and Tokico HP strutsa are also a pretty good street shock from what I've heard. I'm sure there's some members here that have written about their experiences about using them. The strut sectioning FAQ is a pretty good place to find some options if you haven't looked there already. I actually have some spare Illuminas for a 240z if you want to try them. I moved to Koni 1437 shocks all around and just have my Illuminas laying around. -Liam Edit: Added Tokico HP
  13. I too am curious about what experienced people have to say on this. I'm starting on my chassis and I'm debating on getting a new roller to build and properly cage or sticking with my current chassis. From my research and experience, if you want to fully rebuild your car (especially with 800+hp in mind), building from a stripped roller is cheaper and easier than using an existing built car.
  14. Camber adjustment at the top of the strut will give you only about 1/10th the amount of angle you could get by using an adjustable lower control arm.
  15. I have a complete kit of the Silvermine rear disc brake conversion kit somewhere in my garage, if you're interested I can find it and send you some pictures. The kit: http://www.silverminemotors.com/datsun/datsun-240z/brake-upgrades/240z-260z-280z-rear-brake-upgrade-disk-conversion-kit -Liam
  16. Hi all, I'm looking to buy a 240z roller or chassis with minimal rust and a straight chassis. Paint not required. Located in California but I am willing to travel across states for a good chassis. Thanks, Liam
  17. Hi all, Windshield is pretty old so I'm looking to get some new glass. If anyone has any 240z windshields in good condition or new reproduction let me know. I can pick up locally for those located in the Bay Area, CA. Thanks, Liam
  18. Hi, if you still haven't sold the headlight covers I would like to buy them. Thank you Liam
  19. Koni 8610-1436 or MR2 Illumina rears are very short. I've used 8610-1437 (slightly longer than 1436's), Tokico HPs and basically all the illuminas people fit on Z's except MR2 rears because they were on back order for about 5 months. Summit should have everything you are looking for with fairly accurate measurements. You will definitely have to section the struts. Good luck. -Liam
  20. 16x8 with your current tires is most likely the widest you're going to be able to feasibly use without modifying your fenders or using the perfect offset. Just be happy with your wheel size and if you're going for a certain stretch then size down your tires. I used to run 205/45R16 BFG Sport Comp 2s but 215s or 205/50s should be good also.
  21. Depends on whether or not you're running 2.5" OD coilovers or the OEM struts. Currently running 225/50R16 on 16x8 wheels +0 offset with OEM struts, cut springs and koni inserts. The fit is very tight. Do some searching and you'll be able to find some information about tire/wheel sizes on this forum. Here are some good places to start: http://forums.hybridz.org/topic/58528-wheel-show-post-your-pics-of-you-wheels/ http://forums.hybridz.org/topic/69623-the-strut-thread-koni-illumina-tokico-carrera-bilstein-ground-control/
  22. Going to a 205/65R15 tire vs a 205/60R15 tire will hardly add much cushioning. I feel like the money for a new set of slightly softer tires could spent more effectively else where such as on some nice shocks or control arm bushings. As for the springs: I've run Stagg springs and I wasn't a fan, when I tested them on my spring rate tester they tested much stiffer than advertised and they added A LOT of ride height.
  23. Hey Jason if you ever want to sell those Tokico 5022 springs let me know! I've been looking for some for a while.
  24. Why not an Ford EcoBoost 2.3L Turbo from a Mustang/Focus/Mazda? (I believe these are called SkyActive in Mazdas) I feel the EcoBoost has a bigger future than the EcoTec.
  25. Question for you aongch since I think we have the same diff and LSD unit combo. Do you get gear noise with Quaife ATB? If so how much?
