DuffyMahoney
    14
Everything posted by DuffyMahoney
  1. I am trying to get better spring engagement on my R35 Coil stalks. Here is v5. I hope it works!
  2. Since my throttles are taper bore. There isn't a velocity stack that looks classic and is the correct size, so I had these drawn up and cnc cut. Sadly I screwed up a measurement, so they have to get cut again. These are 65mm length stacks, which I think make them look better with the shorter throttle bodies. Thoughts? 865c1107babc421bb8381e64ca3a31b8.MOV
  3. Also I got my taper bore pro EFI hardware 45mm throttle bodies! They are cnc cut and very pretty, the have the most shallow injector angle I could find, and I love the bearings, 8mm shafts and butterfly angle. Sadly they were damaged in shipping, so back to waiting.
  4. I am working on the stalks now, 3D printing and test fitting how the stock springs will work. The goal is cheaper and rigid like the stalk coils, I plan to make and sell a few of the brackets.
  5. Also working on a new coil bracket, this one has a built in angle for the boots not to be bent so much. It was cut on a 5axis cnc.
  6. I got the idea for the angle here. This is a Fet v2 or v3. The issue with those intakes is the middle carb/ throttle is higher. So you can't run a solid fuel rail. Also this version of the FET has 30mm runners at the head. So lots of porting is needed.
  7. Well I ended up selling my SKs. I am going EFI hardware pro throttles and a vintage FET V1 intake. The FET has about a perfect injector angle and should spray fuel directly down the middle of the runners. The only real issue is they have huge ports at the head, so I will be welding them up and matching to my head.
  8. Fet V1 for the win! Still waiting on mine
  9. I would first look and engine and trans mounts. Maybe something is out of wack? That is an earlier version, did you get it 2nd hand or did you have it for a long time?
  10. One atmospheric, then one post that is balanced between all runners. Which I will already have.
  11. Rainy Sunday z project! Finally got my cable mount installed for my new cable driven ITB setup. This is a lokar cable to a stock 240z pedal with the ball end removed. Then I made a tiny bushing. Everything is snug and works as it should. IMG_5385.mov
  12. How about 6 gigantic throttle bodies:) EFI hardware does progressive stock and even does a lower angle on their butterflies to help with the same issue.
  13. Well my balance bar design is done. Basically i made decorative bolt on injector blanks for my vintage SK throttles. Should work awesome. The goal was to mimic what SK had in the 80s, these are my take on the original block off plates and vac plates. Next off to get cnc’d
  14. Prepping the engine bay for Larry's new injectors at the head intake.
  15. I can't remember why, but people don't like that dual idler. It has come up a few times.
  16. Any early tach works perfectly with coil on plug. Sense pulses, works with zero modification.
  17. That is TBD. One idea is cutting up the LS3 throttle body. A few shops have done that with good success. It's just not a ton of room on a L series for it. The kincer one is very nice, but 2300 dollars for a 40 dollar motor and a nice housing seems far fetched to me.
  18. ITB DBW update. Installed, feels and looks like stock! I had the stock pedal pad copied, then laser cut. Then welded onto the 350z pedal rod. I also had the pad bent to match my stock pedal and also clocked to match. After that I got it all powder coated to match. Should work great! I can tell it’s not attached to linkage, but it still feels somewhat stock. I like how I can’t really tell it’s not stock without looking hard. IMG_3890.MOV
  19. Laser cut, welded, powder coated and ready to install! Clocking and bend is about perfect from stock. Stoked
  20. Should work out nicely. Getting a plate laser cut tomorrow. Then some welds and then powder coated.
