68
89mm pistons FOR A L28..From wot motor?
JMortensen replied to datfreak's topic in 6 Cylinder Z Forums
L28 = 79mm stroke and 130.2mm rod = 1.648 LD28 = 83mm stroke and (L24) 133mm rod = 1.602 So the L28 has the better rod ratio. Personally I'd rather have a stroker than the L28 I have, but the L28 does have the marginally better ratio. -
You haven't mentioned balancing the carbs. I assume you did that along with all your other stuff...
Crank case ventilation and pressurized engine ?
JMortensen replied to Nismo280zEd's topic in 6 Cylinder Z Forums
I found another theory as to why you'd get more power with neg crankcase pressure. It has less to do with resistance to the internals spinning inside a pressurized crankcase and more to do with the rings. Apparently according to the article I was reading the more pressure differential there is on either side of the piston rings, the better they seal. So basically the rings seal better with vacuum in the crankcase. -
I don't think getting parts for a 2.3 is very hard. They are the motor to have in 4 banger dirt track cars. I've seen claims of 275 hp normally aspirated thru a Holley 390, and I actually believe them. A lot of rednecks have been working on that engine for a long time...
You could just bend the shifter.
Yeah, summit, jegs, etc have them Just a can with a couple hose fittings on them and a little filter on top. -
Where to section struts?
JMortensen replied to PUSHER's topic in Brakes, Wheels, Suspension and Chassis
That's an awful waste of time IMO. You're proposing disassembling the struts and cutting them down and rewelding them, then reassemble and drive around for 2 months, then take it all apart again, grind off the spring perch and weld a new perch on? Seems like a huge hassle. Basically you're doing the job twice at that point. If you want it lowered for 2 months I suggest you do it the easy way, take the center nut off the struts, jack the car up, pull the springs out, cut a couple coils off and reassemble. That wouldn't take nearly as much work and it would be a temporary fix. -
My stupid day.. and some interesting ironys...
JMortensen replied to datsunlover's topic in Non Tech Board
Disconnect the front of the rod from the control arm. Take out any shims that may have been installed to increase caster on one side or the other. They should go on easy IIRC. Then hook the front of the rod back up, and set the car down. Tighten everything with the weight of the vehicle on the suspension. -
Somewhere close to 35 total should be about right for max power. Maybe a few more degrees, maybe a few less, but right in that area. This should help: http://home.att.net/~jason510/dizzy_specs.htm
If you plug the vents you're guaranteed an oil leak. Either take the hoses and run them to a catch can which is vented to atmosphere or do as you said and plug them into the intake. Problem with triples is that if you plug the PCV into one runner, then that runner will burn air/fuel, and whatever oily crap comes out of the PCV. You can split it into 6 lines with its own little manifold, and run one to each cylinder (I think Dan Baldwin did this). Catch can is the easiest. -
I think it's a little shallower than that, I just sectioned some and I think I cut them at about 1 1/2" and was below that part of the tube. Maybe more like 1". EDIT--It's thinner at the top where the threads are, then it gets thicker below (just went and looked). -
That's the best reasoning I've heard so far. -
Has anyone seen damage to a strut tube in the area heated when sectioning? I haven't. Nor have I seen anyone break the weld itself where a strut was sectioned. Also, the strut tube is welded from the factory at the bottom, the brake line brackets are welded, and the original spring perches are welded onto the strut tube. It's not as though we're welding something that wasn't welded on from the factory. I would think that sectioning them as high as possible would be a way to avoid a catastrophic failure later on, if that was a big concern. Even if the strut broke at the weld, the higher the weld was on the strut housing the less likely it would be that the strut insert could get bounced or jostled out of the bottom part of the strut tube. I think GC says cut them right at the bottom. If for some reason a strut tube were to break at the weld, I could very easily see the strut disconnecting from the spindle in this case (big accident ensues). This statement doesn't make sense to me. The original spring perch was welded on, so why ignore it? Seems like the thing to do if one were that concerned would be to include the original weld in the area being sectioned, so that the original "heat affected" area would also be removed. Again, I think all of this is overdone, and I always have seen them sectioned right at the top, about 1 1/2" below the thread. The reason given to me for doing it there is so that if you need to grind on the inside for some reason it is easily accessible, but there could arguably be a safety benefit to sectioning right at the top. The strut tubes are under a considerable strain, and I have heard of them getting bent in off road excursions, but I've never heard of one failing in such a dramatic way that it would warrant retapping the threads vs cutting and welding. Basically I think you guys are making a mountain out of a mole hill on this one, but I do admit that it may just be that I'm ignorant of problems that have come about from sectioning... -
http://photos.yahoo.com/sss510six If you click on the button right below the search terms that says find all of the search terms then you won't find 20,000 matches (for future reference). I couldn't find the post that had this link by searching for L28 and T56, but I did find it with L28 and 6 speed FWIW. You'll see that it takes a bit more than a bell housing...
What would be the advantage of this? It would probably be heavier than a stamped steel stock arm. It would be more flexy (due to the bushing) than a chromoly arm. Is it just for show? Chromoly with rod ends is going to be as racey as it gets, I think, so you'd be taking a step backwards with regards to ultimate performance. As to your front brakes you got me curious if there was a 7 hole 13" rotor from Coleman or someplace like that, so I did a little checking. I did find some through Coleman, part #d30-137-1300-87 (1 3/8" rotor) or d30-125-1300-87 (1.25" rotor). I am assuming that your current setup uses a 8 hole on 7" bolt circle rotor like the JSK stuff I've got. http://www.colemanracing.com Jon
Need info on High torque starter source
JMortensen replied to jkube's topic in Ignition and Electrical
280ZX -
This is the most useless thread jack I've ever seen on hybridz. If driftn wants to talk about pipe dreams like titanium engines I think he should start his own "Totally Unrealistic Ideas" thread. At least I can ignore that one without thinking there might be some relevant Z06 beating info on it.
exhaust valve size...is smaller more efficient?
JMortensen replied to a topic in 6 Cylinder Z Forums
There is a general rule of thumb that the exhaust should flow 75% of what the intake flows on a bench. You can get that number by porting the head correctly. I would think that porting the head would be cheaper than installing different valves until you hit the magic number, but if you wanted it exact you would need to find a shop with a flow bench. The other benefit is that you can make the whole head flow much better and still hit the 75%. I know the 75% is for NA, not sure if that goes out the window when forced induction comes into play. -
vacuum line from booster to where?? *pics*
JMortensen replied to a topic in Brakes, Wheels, Suspension and Chassis
I thought that valve was a PCV valve, and the check valve was the one that is usually in the hose clamped to the firewall... Kinda like a little hockey puck looking thing about 2" in diameter. I don't have anything like that valve he's holding on my triples, but my booster holds vacuum because I have the disk thingy. -
That's funny. Part of the reason why I wanted to up the breakaway was so that it would run cooler. The theory I'd read was that the clutches only generate heat when they slip, so the more worn the LSD gets the hotter it will run. If they're too tight to slip than no gears inside the diff move but the ring and pinion. Interesting that you would have higher temps with the higher breakaway. Not sure what to make of that.
If you read the second page he talks about hitting bumps while going straight flexing the towers in, but under cornering load, flexing out. I'm sure our Z's are worse than most cars, and are probably really bad when you've got heavy springs in. It's really not a big deal which is right, as long as it gets fixed. I just thought it was interesting, and like I said before, suprised me a lot when I learned why and how.
Just a little backup for my point, this was the only site I could find that had any reasoning as to what the chassis does under load: http://e30m3performance.com/myths/Strutbar_Theory/strut_bar_theory.htm
That's what I always thought until I read a magazine article that used a dial indicator with a tell tale function to measure the movement. The strut towers actually move OUT on the loaded side of the car, and in on the other side (at least on the 944 that was the test car). Surprised the crap outta me too.
I don't think rod ends have any downsides as long as the strut bars control in more than one direction. The MSA bars with just a single bar could allow the left or right side to raise in relation to the other, but if you've got it triangulated I think that solves that problem or at least reduces it. Personally I like not having to disassemble a bunch of stuff to do a valve adjustment. The way mine are set up I can take off one bolt on the bar that goes across and "flip" it over and out of the way. Not sure how much work has to go into removal of the PDK setup to pull the valve cover, maybe that center bar comes off easily too, but when you look at something like the TEP setup it looks like a bit more work... I can also say that I'm sure the PDK setup does a better job than what I've rigged together, but when testing mine I went around a corner where the front always got loose prior to the installation, and it DID NOT get loose with my bars in place. In fact I got two wheels in the dirt. On the INSIDE of the corner. Big big difference. I used to think that strut bars were a ricey thing like a polished cold air intake, but I was WRONG. Way wrong. I'm happy with the performance increase that mine give, and it was a great confidence booster for me because that was the very first thing I ever fabbed on a car from scratch (or as close to scratch as I'll ever get--not going to melt the ore to make the metal for the parts).
Wasn't that the Comdex convention from 1996 or something. This one is OLD. You can find some sites where people added onto the list, I've seen some that were 50 points long.
