Tonythefish
Everything posted by Tonythefish
I will have to make a decision soon. I have a r200 open just want it to be a lsd. No cheap option
Have you seen the Invincible extremes super 8.8 setup yet?
So I’m about to pull the plug for a front suspension and then rear but front first. Dose the apex have issues up front ?
Very Nice Jeff!
Ford Super 8.8 irs swap thread. Rear brakes too
Tonythefish replied to Invincibleextremes's topic in Drivetrain
Have you sourced the super 8.8 assembly? Just curious what they get for them and what stock gear ratio are available out there..- 282 replies
- disc brakes
- suspension
(and 7 more)
Tagged with:
Chip , whats your contact info ?
Interested if available.
This is the way I’m leaning. Just trying to makes sure they can handle som horse power. I would also upgrage to cv axles at the same time. Check it out. http://www.kangamotorsports.com/blog/2016/6/18/datsun-240z-limited-slip-differential
To me it looks like the sti lsd with 3:90 gears is the way to go . Well documented and parts available. Not the cheapest way though
Alpha 1 . Needs floors and some frame work . Going to get it today
Got it ! just replied about this. What about a stronger rear. Seams to a lot of old info out there and way to many options..
Thanks for the info ! I have also been trying to figure out how to upgrade the rear.. so you decided on the 8.8 .. do you have a link or kit that your are using ? I have no idea what is needed to do the job . It sounds that one is the strongest and easier to upgrade gears and lsd ..
One more what gear is in your rear ? I’m thinking you need to be near 3:90 to 4:11 with a t56 6speed
Awesome ! So seeing it do the burnout makes me want to get a lsd did you upgrade you rear at all? How much more does the lt1 vette engine have over the other lt1 . Debating if I should cam it up before install
I’m looking to do the same lt1 t56 swap. How is your shifter location? Did you upgrade your rear ?
Just closed the deal on one. Here is a shot of what the car looks like via the hood . Cleaned up nice.. Hope to get all the parts and car soon.
