Stainless Steel Mounts Tig Welded
New engine insulators with washer, split ring, and lock nut
Complete here, everything you see is what you get. (240Z Style transmission mount)
Packaged almost ready to go...
Clearance on both sides I believe is sufficient
Clutch slave has no problem here
Two lock nuts for the transmission (you must use the stock transmission insulator)
Ground clearance on a lowered Z seems good to me. The car has full urethane bushings and Tokico 1" springs to give you an idea.
Front crossmember clearance with RB20DET (200ZR) pan is good
US Driver side looking back towards the rear
US Passenger side looking back towards the rear
I've got one set available right now. All hardware is grade 10.9 and the mounts are made from stainless steel.
If you are planning to run a RB20DET/RB25DE trans, I can also make a transmission bracket for that.
$400 USD Dollars + shipping (I figured this would be a reasonable price with all the nuts, bolts, hardware and new engine insulators since McKinney sold his mounts with nothing for $650).
Contents of the kit...
(1) RB Mount Left
(1) RB Mount Right
(1) 240Z Style Transmission Mount (RB25DET/RB25DE your choice) [260/280 styles coming soon hopefully]
(2) New Engine Insulators
And all the needed nuts and bolts grade 10.9 for this swap (to mount in the motor and transmission).
