Everything posted by award280
That was my suspicion as well, but just wanted someone else to blame when it all goes wrong....er I mean I just wanted a second opinion. Thanks much.
Alright gang. Stupid question amnesty time, but I want to be sure before I eat a cam up. I have a "C" stamped cam on a N42 head. It looks like the cam has the holes for the internal oiling. I just want to verify that I do not need to run a spray bar. From the info I can find around here, it's difficult to tell how the N42s and 260 cams were lubricated. Thanks guys.
Twin cam head for the L6 from Derek at Datsunworks
award280 replied to Derek's topic in Nissan L6 Forum
I'm sure you could find a way to bolt it on. Heck, anything can be a bolt on. Whether or not it works or not is the question. I'm going to bolt on a frozen turkey for the extra torques. -
Dash lights, tail lights, reverse lights are out.
award280 replied to Dannyweaver95's topic in S130 Series - 280ZX
I've had this happen several times. All the power for the head lights goes through the combination switch (headlight switch). As soon as you start getting any resistance in the switch, it starts to heat up. I had one actually get pretty crispy. I'm surprised I never smelled the thing starting to melt. Replace the switch, keep it nice and corrosion free, and look into using relays for your headlights. -
I'm wondering if something similar can't be done using Arduinos.
I bet dollars to donuts that the combo switch is fried. I've been through 3 of them. Each time they would go out, no gauge or tail lights. You are pulling all the juice for the headlights through that switch. Add some relays and it will help alleviate the problem.
Don't forget to get the oil pump drive spindle as well. It's different on the turbo. You can modify the NA one, but its just easier to get the correct one.
A little history on the Z. My dad bought it for my mom in hopes of keeping her from buying a Mitsu 3000gt. I inherited it in 1996. In June of 2005, with 271,000 miles on the clock, I decided it was time for a refresh. A refresh turned into a rebuild, and I got bogged down by a severe case of the "while I'm at it" syndrome. After several starts and stops, a new house, and a new baby, I've put my nose to the grind stone and it is time to get the thing on the road. A few pics through out the years: The engine at tear down: The ZX in our old shop: Engine bay primed, painted and rebuilt engine dropped in: Engine is the original block with new flat top pistons, ARP rod and head bolts, N42 head. Going to run a Z31 computer with Nistune. A few of the new parts that are going into the Z: An unforeseen problem of taking more than 5 years to do a project.
I had the same problem twice. Each time it was my combination switch. (the headlight, turn signal switch) All the power for the headlights is going through that switch and it fries easily. Check that and I'm sure that you will find a charred connector.
Check out the Factory Five forums. Several of those guy are using the system in their Cobras.
Yeah, I've been checking those out. Thanks guys.
I just got a '03 VW GTI for my DD. I'm trying to find a nice "hybridZ"-esque forums to get info from. More "This is how you do this." and less "Yo, we be ballin' in the veedubs." If anyone can point me in the right direction, I'd appreciate it. My searches are turning up with nothing. I guess I'm just spoiled.
Check out this thread on the info for using the Z31 ECU on a L6. http://forums.hybridz.org/showthread.php?t=91250
I've been trying to find a post I saw here a long time ago. Much searching, but to no avail. Anyway, what I'm looking for was a CPU that took the inputs from your switches, then output out to whatever devices they were supposed to control. You could set different parameters such as light dimming delay ect.... If anyone has any info, throw it up. Thanks
Thanks guys. I've had a lot of PO issues to deal with on this truck. And no wonder I couldn't ID this carb. It's more of a hybrid than my Z is.
Hey gang. I need some help figuring out what Holley I have here. I've gotten the all the numbers that are stamped on the thing and the closest I could find was a 580 that was sold on the 66-67 Corvettes. But when I got the rebuild kit for that carb, it turned out it wasn't for a matching carb. If any of you guys could point me in the right direction so I can finally get this thing tuned. If I slowly accelerate, it is fine, but it I get on it, it falls on its face. I'm not sure if I'm running lean or rich or whatever. Anyway, before I digress any further.... If any of you guys could tell me which adjustment screw is for the idle and which one is for the power circuit.
I have a '94 Acura Vigor. 2.5L inline 5 with the dual runners and the butterfly valve. I have also been trying to think of a way to incorporate this into a custom Z intake mani.
Some buddies and I got together and rented an old warehouse space. We have enough room for multiple cars and tools. It's worked out really nice.
I actually finished this today. You have to take the roll pin out of the collar to get it to come off the base of the distributor. Then take a drill, and drill the splines out of the bottom side of the collar. Then the end of the spindle needs a bit of "machining." If you just look at the NA spindle and the Tubo dizzy, it should make sense. Sorry I dont have any pics to show. I do know that there is are some pics on one of the Z31 ECU swap threads.
Awesome. Just Awesome.
Great work man. It is an inspiration. Now if I can just get inspired enough to get my own project done hehe.
I looked into buying a Tib a few years ago. From the research I did, it looked like Hyundai was making a big push in their quality control dept. JD Powers had them ranked up there with Honda and Toyota in new car quality. I think they looked at how many cars had to come back for work within the first 100 days after purchase. As for middle and long term quality, I'm not sure.
I hit a racoon a few years back in my '83. The thing was about the size of a small pony. Dented the hell out of the lower rad support and completely killed the front valance. By the way, I'm still looking for a decent front valance hehe.
Do a search for Nistune. There is also a good thread about it at Z31performance.com
