New best time -
R/T 0.162
60' 1.944
330 5.558
1/8 8.481 @ 84.08
1000 10.990
1/4 13.081 @ 108.56
Haha, I bet you're thinking "what's this post doing in the drivetrain forum?"
Two things: I have a steel strap mounted over the nose of my diff, and it is getting noisier and noisier. The diff is beating it up, and now I notice there is about a 1/2" clearance above the diff and it's vibrating under torque application. I am gonna tie in some more steel and reduce that damn gap, I'm sick of taking it apart - although I need to check to see if my new factory diff mount is sheared - I hope I limited the travel enough to save it. So once that is tightened and quiet, I will hammer the 60' a bit more, and 12s will be in the bag...
The ClutchMasters stage 4 clutch is definitely holding the torque, but the release is halfway up the pedal, and I'm used to my Centerforce II release which was close to the floor. So on my powershifting, I was close to hitting the rev limiter. Here is my question: It seems the L28 turbo Z people are using any old pressure plate (Jersey with the 2+2 PP, LJ with the Z32 PP) and the common theme is the ACT modified street disc. I understand this disc is mounted on a sprung hub, and it has 4 or 6 pucks. What could I expect running this disc with the Centerforce II PP? I'm thinking I should get good holding pressure, and the higher friction material of the puck disc should work well - and I get my pedal travel back.
Opinions, questions, comments all welcome.
