19
Everything posted by Gollum
Why did you decide to stay with the Datsun L6 motor?
Gollum replied to logan1's topic in Nissan L6 Forum
I bought my first Z, a 80', thinking that I'd be swapping the motor for a V8 once I didn't have to subject my vehicle to smog inspections. Then the laws changed. So, after owning 4 S130's I NEEDED a car to drive, and I wanted a S30 like you couldn't believe. And find one I did. It happened to already have a L28ET and I got it for a song and dance. So for me, I've been sticking with the L motors for one big reason - it's in there already. This saves me downtime that most people spend on swaps, and I don't have to worry about fabricating anything to make it fit. My first Z was my first car, so my tool collection started small. I simply didn't have the resources to do a swap. I eventually did do a turbo swap in a S130, but I also did the whole swap for pretty cheap. I DO love the sound, and would love to have a 200+hp L28 in a lightweight 240Z. I love the sound of those solid lifters and timing chain. All those little noises are just like pouring joy juice in my ear canal. An ITB L6 is just sex on a platter. All that being said, once I have a welder and some experience with it, down the road my S30 is probably going to get a SR or VG or possible a VQ. My 280Z is going to stay pretty hardcore, but if I happen upon a nice 240Z I might just have to build one that the wife could enjoy. She doesn't even like thinking about riding in my 280Z. My 81' I have really mixed feelings about. One week I want to sell it, the next I want to keep the only slicktop S130 I've ever had. The motor probably won't make it to 300k and is going to get there terribly so if it does. But swapping in a rebuild L6 just seems cruel with that crappy EFI. Maybe I'll swap in a carb'ed motor and roll the dice at the smog dyno. -
Long story so I won't go there, but my engine was running great before I swapped my head (from P90 to P90). The new head is from a 81 so it's got a slightly different cam, but not by a ton. Both heads were solid lifter heads. I'm using the same intake and exhaust manifolds. Same ECU. Same AFM. Same TPS. Same Turbo. Same Exhaust. But, in the shuffle of heads I had to change the coolant temp sensor because the old one didn't want to come out without falling apart on me. Then wiring the engine back up the hacked up TPS wiring finally gave up the ghost, so I got a new plug from a NA model and wired it in (I'm pretty sure it's correct now). But, I can't seem to get it running right. It'll start ok (no cold start system left, I just rev it a few times on a cold morning and then it'll idle), but at all temp levels, it won't keep rev's at very light throttle settings. It gets really rough and wants to die. If I snap the throttle open quickly the motor revs nicely, and under accel the motor runs nice. But at soon as I start to hold a speed it starts it's sputtering. I've noticed that at those low throttle positions if I open the AFM a bit to give it some more fuel the revs pick right up and are stable. But I've loosened the AFM and that didn't help at all. I've actually moved the AFM a lot both directions to figure it out but it's still just not happening. The only thing I can figure, is that maybe the AFM worked on the old head, but is now just way off for the new one for some reason. Or maybe the new coolant temp sensor is the wrong part, but I tired the one from my 81' and it didn't make a difference. Or maybe my fuel was bad, but I've burned through that and filled it up, but this is the first tank so it's a bit mixed. Or maybe my plugs are going bad? I pulled them and put in some older NA plugs to see if there was a difference and there wasn't any. The other thing that I should probably check, is the FPR, but I don't understand how that could make it run lean at high vacuum... Grounding problem somehow? So what am I overlooking guys? I've done my best to change one thing at a time, but the problem seem to be extremely static. The car's drivable, and pulls really good once boost kicks in, but that transitional area just sucks.
Well I feel like a real doofus now. I guess I was a bit quick with my findings before. It seems like the rear right caliper is sticking just enough that the wheel wouldn't spin with light movement of the opposing side. Somehow I didn't realize that was what was going on the time before. This time when I jacked the car up it was pretty obvious, as it brakes were stuck enough that it was hard to get the right wheel to move by moving the left wheel. So I guess I probably have a bad u-joint. Which is probably better than dealing with a diff issue, but at least I had a spare diff lying around. I'll keep future findings updated here.
Well, sometime this weekend I'll pull the diff and axles to see if I can hunt down the problem at any rate. Just finding the real source will be nice.
The play it certainly not in the half shafts at any point. I thought it was u-joint issues too, but I can't seem to find any signs of play or wear in them. I can FEEL it too, that left wheel moves EASILY in that 30 degrees, feeling then past that you feel the other side engage. Where as on the passenger side there's almost none of that free play feeling. Almost immediately you feel that resistance that then starts turning the other wheel. The problem is certainly in the diff from what I can tell. If the stubs from the 280Z R200 will just press in then I guess that WOULD be an easy swap. Anyone have any ideas if the seals would need to be replaced? They look ok, but they also came off a 280ZXT that had 200k+ miles.
No responses guys? Well from the looks of things I'm thinking it's too much work when compared to a simple trip to the junkyard in a few months. Then I can hunt around for a ratio I like that's bolt in-compared to having to open up the diff and tearing it apart. Knowing me, first time I open up a diff to rebuild it I'm going to botch it up pretty good. So I'll wait until someday down the road to practice that art.
Wait, isn't that why I started this thread? It's really a sad reality. Regarding the weight, from the numbers I've seen on ACCURATE scales, almost all of nissan's cars were sand bagging a bit in the weight ratings all through the 80's and even early 90's. My S130 weighs around 2650 with nothing but the spare removed. I don't think my t-top cars were much heavier really, but they were all pre-82. I like that the S130 needs a good 245 or so wide tire just to come close to filling the STOCK flare. There's tons of room in there for meat. I like that the front end is better engineered from an aero perspective. I like that the front suspension seems to do it's job a little bit better. I like that I don't have to convert to disk brakes, but have them from the get go. I like that I have a huge fuel tank that will get me 500 miles if I'm getting really good gas mileage. I like that I can run a taller wheel without screwing up the suspension so much, allowing me to run some of the more modern wheel combos. I like that there's more breathing room between me and my passenger. I like that there's a little more cargo space for car parts. And more than anything else, I like that they're consistently dirt cheap. I just need to get out of this state apparently.
That's a scary bold statement, but you have the track time to have weight to that opinion. But that being said, looking at your ZX is hard to call it just "well layed out". You done more dream mods than most other S130's on this forum put together. All that said, I highly respect you, your car, and that statement you made.
First off, quality post. Thank you. And this line shows why I STILL recommend the L28ET to the right person. If you're willing to take your time, they're still a great budget option. If you want to spend a few months looking around you'll probably come across a good deal. But to keep it budget, you need to be willing to fiddle with it's finiky EFI which can be a chore. It has to be the right person is all. It certainly brings a humble understanding of tuning though. For those that want to buy an engine this week... There ARE other options. I can find VQ's all day long from importers Chevy and Ford engines grow like weeds SR's (despite their issues) are extremely plentiful KA's are nearly free Point being, many people automatically peg themselves into a singular option based on budget. In reality there's lots of options and lots of reasons to go with all of them. When I came to hybridZ, and Z cars in general, back in 03' I had a very limited view of engine options and figured I'd buy a Z and put a 350 chevy in one. Now I think that's the last option I'd ever consider, simply because there are so many wonderful options with these cars.
So, my 280Z has lots of vibration coming from the rear end. Plenty of the common shift clunking, but there's also a steady vibration that starts getting pretty bad at freeway speeds. And when I go over bumps there's loud banging from the rear driveline. I've driven the car in this state for probably a good 20k mi. and it hadn't really gotten worse, but last time I had the car up I couldn't find anything loose or out of place. Front diff mount seemed solid and such. Well a few weeks ago while I was under there I decided to check how much free play there is at the wheels. I know this isn't the most scientific test but I figured it was worth a shot. I was pretty certain the noises were coming from the driver side, not the passenger side. I go to move the wheel and I notice that there's a good 30 degrees OR MORE of free play before you feel the other wheel start to move. I go to the other side and it's like less than 5 degrees of movement, to where it almost feels immediate. So I figure, "Well shoot, I've got a spare R200 sitting around that I know is good, I'll throw that in". But there's the problem. It's a 280ZX turbo diff with the splined press in axles, not the bolt in axles. So here's the big question. Can I convert this R200 over to the bolt in axles using my R200 currently in the car without transferring over the problem? Any help would be appreciated. If the local gurus like John or Jon say just go get another diff, that's fine. I'll just make a run to the local yard sometime soon.
I've seen plenty of piss-poor examples go for $500 missing parts. I was lucky to snag my last longblock for $250 minus turbo, wiring harness, AFM, ECU. It was basically valve cover to oil pan with the exhaust manifold on it. And I had to pull it myself at the guys house! And I'm in the bay area where there's a huge concentration of Z cars. A GOOD condition motor that's 100% complete, ready for a swap, should fetch at least a $800 minimum anywhere in the country, over $1k would still be a fair price in this market right now in other places. I haven't seen a donor car (even non-running) on craigslist for under $2k lately. Edit: Oh, and I never said the OP SHOULD get a KA. I simply said that in certain circumstances it might be just as good of a swap. I'm the one who said to ditch the T5 and go with the KA trans on the L series and stick with it. I just wanted my opinion to be rounded so that people don't come to the conclusion that the L28ET is the be-all end-all budget option.
That was my point to begin with. CONVERTING the motor that the S30 ALREADY HAS, into a turbo motor by finding bits of it here and there will cost you MORE money than converting a KA to a turbo motor. Finding a complete L28ET in GOOD SHAPE has gotten expensive. This leads me to conclude, that for a real budget minded person the KA is on an even playing field with the L28ET, or even has a slight advantage. But, if you already have a L28ET, there's not really any point in switching at that point. Just stick with what you have, since changing motors will most likely end up costing more money in the long run. I personally want to go SR over KA for many reasons other than the whole "X motor has more HP potential for the $ invested". But overall you're right oddmanout, the KA for $500 is a killer motor that with the cost difference can really do some damage to the SR swap. That being said, I'll be spending closer to $1500 on my motor+tranny+wiring harness+ECU and Sensors, but a red top, not black top.
For the most part, I'm with you. At 350whp the L engine is a great option. The big question mark is what it costs to get a hold of one and what it takes to get it to the point of being ready to go. Many of the L28ET's you find have super high mileage with iffy compression test numbers. The YOUNGEST one, unopened from the factory, will be 27 years old now! 5-10 years ago low mile examples could be found, but it's gotten harder. Low mile blocks are much easier to find, but then you have to already have your exhaust manifold, turbo, wiring harness, AFM, ECU, and Dizzy to throw onto another long block. IF you can just go onto craigslist and find a L28ET for $500, or a whole donor car for $750 then sure GET IT!!!! I have a L28ET in my car and I really love it. That being said, the factory ECU SUCKS ARSE!!! I'm getting my shopping list ready to go megasquirt and it's probably going to cost me a touch over $800. If I had a KA I could just get it programmed for $100. That's a bit of cost savings. I'm having a hard time finding it, but once upon a time 1 Fast Z posted his personal numbers for KA head flow, SOHC and DOHC, and compared them to stock P90 and his best P90 port job and the numbers were hard to argue with. The DOHC stock flows insanely well, and the SOHC head flowed better than the P90 as well! Here's the link on his site about the DOHC flow numbers: http://bandmzcars.com/FrankPorted1.html And considering the KA is 2.4 liters stock it's not down much on displacement to the "moderately powered inline 6" you talk about. And yes, the KA will only rev to about 6500, but most turbo L motors under 400hp without head work are making peak power under 6k anyways.... Let's all just face it, both of these motor are great budget options, but neither is "better" or "best". Different strokes for different folks. Personally, though I'm going MS soon, I'll probably be swapping in a SR within a few years here. But that's just me.
That package uses the same spring perches, so no, there shouldn't be a problem at all. If you were going with a totally different strut tube from another car that had a larger diameter spring and perch THEN you'd have to be worried about fitment issues.
This is why a lot of people like Tony D talk about not even rebuilding the L motor, or even looking for motors that have been rebuilt because often more times than not, it hasn't been rebuilt even as well as it would have been done from the factory! I understand though. It's getting harder to find these motors with lower miles, while the KA motors people are finding for $500 and under are in much better overall shape. But both motors, if in good shape, have no reason to be cracked open at 350hp. And the KA swap can be done for CHEAP. Was I the only one watching the thread of the budget KA build? (can't remember the user, but the car was white, ran on ethanol) That was a cheaper build than even the CHEAPEST of the L28ET guys I've seen pushing those HP numbers. And they beat that car like a rag doll at the track over and over again with little to no real engine issues.
Sweet! That's what I was looking for. Thanks a million.
I just read in the other thread that you have the T5 tranny. Dump that POS like a bad date!!! Unless you're going to spend $1k+ on race gears being put in it just isn't worth it. And even the WC T-5 has a crappy case that flexes causing it to break. The "real" solution is to get an aftermarket case with high strength gears which costs $2-3k. Swap in KA transmission, $200 swap TOPS!!! Done! Sell the T-5 to some datsun nut that thinks it's worth something, get $50+ back.
Ok, someone with a running L28ET please help me. Run out to your car and tell me the wiring of the TPS. My motor's TPS wiring was a joke so I got a TPS connector at a junkyard from a NA, which has different colored wiring. So if someone can tell me which color wires go to which positions that'd be wonderful. Only two dang wires and I'm not sure I've got them connected right.
The L28ET is cheap, IF you don't go blowing your wad building them up. Plenty of people have made 400hp on junkyard motors. But people insist on just pouring into them on bottom end rebuilds with forged pistons, headwork including upgraded cams and valve trains, etc. It just adds up quick. But in reality all the parts you actually NEED to make that horsepower is the same weather it's spent on a L28 or KA. Big turbo Large Fuel injectors and pump Good computer to control all of it Then there's the little odds and ends like FMIC, fuel rail, etc. Where the KA really shines is that most of the turbo conversion parts are EASIER and CHEAPER to find than L28ET conversion parts. It makes way more sense to convert even the SOHC KA to turbo than the NA L series. But, as it's been stated. You already have a L28ET, and you've already poured a bit of cash into it. Just stick with it. The KA trans conversion can be done for a heck of a lot less than buying a new transmission, and once you've had the bellhousing modified you don't need to do it over and over again each time you blow a tranny. There are guys with L motors that have gone through 3+ L transmissions in a year. You won't have that many issues with the KA trans, making the $100 or so it takes to get the bell housing modified worth it. Spend money wisely, not just spend as little as possible. That's the key to a quality budget project.
One word: Energizer
Also remember that these clutches are working in a wet oiled environment. Your clutch on the flywheel is a dry environment. The clutch material that contacts the flywheel is not so different than brake pad material, and we all know that grease on your rotors is BAD for braking. Same thing in a diff. You have to take the oil into account. And in this environment, metal on metal for a clutch won't wear the same as it would dry, and will have a very different break away characteristic compared to dry. All that being said, I'm reading this reading up on what my options are for converting to a LSD down the road. Does anyone know what the clutch/spacer pack looks like in the power brute carrier? Some seem to say it's a lot like the Nissan unit in the Z31, but I can't find info on what the break away levels are like from as-ordered and if the same clutches could be used, or how many clutches it has in it.
And that right there is good information that I'd consider reliable. So what can we learn from his setup? That it takes a "whole package" mindset. He's running a fairly high duration cam and he's certainly done his research on timing curves, not just initial or total advance. I think some people also need a bit of a wake up call when it comes to compression ratios. Even 10:1 can be considered "low" in certain circumstances. There are Honda B engines running over 13:1 on pump gas out there, making 300+hp naturally aspirated out of 2 liters, again, on pump gas. Many people just assume a detonation issue is compression related, but it's a much more complex equation than that. Example: Say you're running stock SU carbs, that haven't been rebuilt or touched for a long time. So your engine starts to ping every now and then, depending on gas quality. You check your mixtures and you seem to be running plenty of fuel, maybe even a bit rich. You can chase your tail over and over again but your carbs might be the biggest issue, not the head or block needing to be pulled apart and cleaned. It could very well that you have dirty needles in the carb that aren't allowing as good and even of flow of fuel as they should. This results in poor atomization thus poor fuel distribution of fuel in the chamber, thus ping! Detonation isn't just heat related, and very rarely will you see ping in an engine across every cylinder. Tracking down what caused the ping is the biggest battle, and many times we tend to over look things. Maybe you have a cooling issue, or just simply your radiator cap is going bad so you're not at the psi you should be and running a tad hot. All that being said, just throwing together a high compression setup without doing your research can lead to a setup that just doesn't work. The problem might not be the compression ratio! Just some food for thought. I think for NA application any head will work. For force induction I personally prefer the P heads for the added quench while keeping compression ratios lower. Ping issues will come down to what pistons you run, your cooling system, your head prep work, and your fuel and ignition system and control. To Dan~ What fuel do you run? And what state are you in?
It's actually closer to 8.5:1 I believe. The stock L28ET is in the mid 7's! BRAAP seems to be a lot more conservative on this debate than others, and has plenty of experience and knowledge to back him when he says that these engines are very detonation prone. Thus he doesn't readily recommend higher compression setups (that I've seen). There's actually a very wide spread of what people have seen from different setups, showing that there's just too many factors involved to make a conclusive statement that "X" setup will work perfectly for anyone. Now, if we want to say that X setup in X conditions in X circumstances then we can make an educated guess as a community and be in something of an agreement. All that being said, I think that many would agree to an extent if I were to say that a P79 or P90 with flat tops is perfectly fine at stock-ish power levels, even on the stock EFI and dizzy. Many might also agree if I were to say that the P90 + Flat tops are fine even up to the 300hp level with the stock cam if fuel and ignition tuning is capable. Obviously a more aggressive cam will help this maintain a level of possibility, but it's just a factor. There are guys pushing well over 400hp on the stock L28ET longblock. I personally thing there's almost no cause for concern for us guys with stock heads pushing a measly 7-12psi. If you're having detonation problems at those levels you have something else WRONG. I even run my P90/dish combo on california 87 octane which is like running on urine. If I switched to flat tops I might have to consider putting in premium, but even our premium isn't as great as some states regular. Gas is a big ping factor, so remember that when people start bickering about what combo will or won't work.
Yes, post pictures! And if you're in the bay area, that means you have to come to my next yearly BBQ this summer so some people can see it in person to appreciate it.
Your backspace measurements look correct. These rims were designed to have as close to a 4.5" backspace as possible, as that was the measured safety net that should be a "decent" fit for the largest percentage of us out there in the S30. Personally, I think to avoid having ridiculously huge flares (just the amount of work involved is all, if you want to then go for it) you should go with something with more backspacing. With 4.5" you'll clear stock suspension components. The main limitation in front is the tension rod at full steering lock. If you don't mind rubbing, then compact coilovers should let you run a lot more backspacing, putting more of the wheel in the stock well.
