19
Everything posted by Gollum
little confused. any help would be awesome
Gollum replied to 82 turbo z's topic in S130 Series - 280ZX
I don't have MS, but I've read through the threads on it more than just a few times. That kit is the entire ECU, but that's probably not all that you'll want to have on hand when you do the swap. The big other key item would be a wideband of some sort, like the LC1 and compatible controller. Without a wideband you'll have no reliable way to tune the ECU. You could probably load a map from someone with a similar setup, but you'd want to get to a dyno ASAP, and if you make ANY changes you'd be heading back to a dyno. I've talked to several professional grade shops that don't care about dyno tuning for street cars and consider it "an unneeded luxury" or "something to make the customer's happy". This is because with a good wideband you'll get a better tune on the street, and be able to compensate for a wider range of factors that simply don't happen on a dyno. Dyno tuning is for you to use if you don't want to learn how to tune the car yourself, but if that's the case then there's better options than megasquirt. MS is truly for the person that WANTS to tune their car themselves. All that to say "you'll want a wideband". The MS FAQ/Sticky covers how to use the factory distributor, which is fine if you're not pushing the limits of the stock internals. But if you're going to reach those 400+ numbers, then you'll probably want to run a 36-1 timing wheel on the crank triggering coil packs. This will give you much more accurate timing, and a much wider range of control too. And personally, I think if you have ethanol near where you live I'd just run ethanol instead of meth. E85 with an intercooler has no need for extra cooling imo. The nice thing about running E85 is that you don't run into some issues that you might have when spraying meth aside from gasoline. If you have a meth tank and for any reason you run out, or you get a clog in the system, or if your pump fails or just drops a bit of pressure then you run the risk of blowing your motor. Where as if you're running E85 you'll immediately notice most fuel supply issues. You also have less parts possible to fail in this setup. The other upside is that you can tune with it, and without it, and switch back and forth if you need to (just make sure there's less than a gallon of fuel left in the tank first!). This would also be more soft effective than meth, as you're not buying as many parts to get it up and running, and E85 is much cheaper per gallon than meth, and gasoline too! In a rough tuned 350+whp STI running E85, the cost is effectively THE SAME per mile when compared to CA 91 octane premium. The reduction in MPG is roughly 20% (not even tried to tune for economy) and the cost is about 20-25% less. So it's a wash here in CA. I'd imagine that in texas you might even be saving money over premium. Something to look into. -
Do you know how hard it is to find examples of systems like these Tony? I'm sure I'll figure it out, but I haven't quite figured out the best way to control this for street use, that'll be reliable and easy to tune. I tried mocking up a table with turbo speed on one axis and engine speed on the other with the variable being percentage of the BOV opening... I realized after staring at my computer screen for about an hour that it's impossible to tune this without first setting a boost curve, because otherwise I can't calculate what CFM the engine will be using. Anyhoo, I've got a mock engine idea I'm making some tables for, we'll see where I get with it. Maybe one of these days I'll actually build me a megasquirt system, then I can play around coding something up.
As said, there really isn't such a thing as "perfect compressor" that would fit those three engines, despite their similar HP goals, and thus similar CFM/Min of air and fuel requirements to meet that HP goal. listed first is the 5.0, then 4.6 and then the 1.6. Vol. Eff. is based on dyno software emulating true factory torque curves. Should be close enough for theory's sake. http://www.squirrelpf.com/turbocalc/graph.php?version=4&pr0=1&pr1=1.07&pr2=1.66&pr3=2.26&pr4=2.26&pr5=2.26&pr6=2.26&pr7=2.26&airflow0=4.5&airflow1=7.3&airflow2=14.5&airflow3=24&airflow4=34.2&airflow5=44&airflow6=47.8&airflow7=49.3&product_id=109 http://www.squirrelpf.com/turbocalc/graph.php?version=4&pr0=1&pr1=1.07&pr2=1.41&pr3=1.75&pr4=1.75&pr5=1.75&pr6=1.75&pr7=1.75&airflow0=3.8&airflow1=6.1&airflow2=10.8&airflow3=17&airflow4=28.2&airflow5=40&airflow6=42.1&airflow7=42.7&product_id=109 http://www.squirrelpf.com/turbocalc/graph.php?version=4&pr0=1&pr1=1.07&pr2=1.86&pr3=2.66&pr4=2.66&pr5=2.66&pr6=2.66&pr7=2.66&airflow0=1.5&airflow1=5.6&airflow2=13.8&airflow3=26&airflow4=32&airflow5=37.6&airflow6=37.9&airflow7=37.8&product_id=109 Compressor surge might be an issue still for the 1.6 there, but it's in the decent range for the V8's. Though it's amazing how two V8's of similar displacement, with stock power levels being semi-close can read so differently on a map. The turbo used is the GT3076R. One of the larger compressor's for the GT30 turbine frame, not sure how it compares to a T3/T4 typical hybrid. If we were seeking IDEAL turbos I might choose something more like this: The 5.0 would get a GT3782R, leaving some room to shoot for 500hp and in a good efficiency area for street use http://www.squirrelpf.com/turbocalc/graph.php?version=4&pr0=1&pr1=1.07&pr2=1.66&pr3=2.26&pr4=2.26&pr5=2.26&pr6=2.26&pr7=2.26&airflow0=4.5&airflow1=7.3&airflow2=14.5&airflow3=24&airflow4=34.2&airflow5=44&airflow6=47.8&airflow7=49.3&product_id=44 The 4.6 would get a GT4294R letting it get into a really nice range for upper RPM use when you stretch out the motor and use those rev's it's got. Might be sacrificing some street performance but giving good race use and quite a bit of flow left on the table if more HP was desired. http://www.squirrelpf.com/turbocalc/graph.php?version=4&pr0=1&pr1=1.07&pr2=1.41&pr3=1.75&pr4=1.75&pr5=1.75&pr6=1.75&pr7=1.75&airflow0=3.8&airflow1=6.1&airflow2=10.8&airflow3=17&airflow4=28.2&airflow5=40&airflow6=42.1&airflow7=42.7&product_id=49 The 1.6 would get a GT3571 http://www.squirrelpf.com/turbocalc/graph.php?version=4&pr0=1&pr1=1.07&pr2=1.86&pr3=2.66&pr4=2.66&pr5=2.66&pr6=2.66&pr7=2.66&airflow0=1.5&airflow1=5.6&airflow2=13.8&airflow3=26&airflow4=32&airflow5=37.6&airflow6=37.9&airflow7=37.8&product_id=41 This is probably the most interesting of the choices. It's "within" use of this application, but it's hard to find a turbo for this application that doesn't say "danger danger" all over it, because you need the larger compressor to have enough air flow for the HP goals, but it's low displacement makes it easy to put into surge... So you end up doing what big phil did basically, go with a larger AR on the hot side, or a larger hot side all together. So this GT3571 has a huge turbine/hot side frame, and a smaller compressor than the other engines. But this prevents borderline surge constantly, and puts you in a decent efficiency range for street driving, but racing on this engine a lot might lead to early turbo failure... Hmmm... wonder why those turbo honda guys seem to blow up turbos a lot when they're pushing 500hp.... hmm....
Just because you say you're busy (which I believe) I won't ask any more questions for now, since I think I'm starting to get it. Again, everything you've said I've TOLD and tried to TEACH to others, to explain why PSI is poorly understood among people, and how little it really matters, but again, my language just isn't there to communicate it obviously. Here, I'll edit my last post to better reflect what I was getting at, which you in turn answered well enough for me. I think the irony in the three engines I gave examples of, is that though they'd all require very different setups, they could all in theory use around the same compressor, since the flow requirements are the same in the end. The exception would be that the Honda 1.6 liter will end up in a very different part of the map due to it's higher pressure ratio required in order to reach 400hp. If finding a compressor to meet the needs of all these engines, you'd probably end up with a compressor that's never really perfect for any of the engines. I'll calculate some load maps and see what I come up with, for theory sake.
I'm pretty sure I understood all that, so I'm wondering if I'm just not phrasing things correctly. I realize that pressure ratio/psi AND flow will be direct variables depending upon engine displacement, volumetric efficiency and power goals. If you have a large efficient engine it won't need as much PSI as a smaller less efficient engine to reach the same power. IE: Even a POOR efficiency ford 5.0 stock only needs a quarter the PSI to reach 400hp as a high efficiency honda 1.6 liter. But by the same token the 4.6 ford DOHC needs LESS PSI than the 5.0 to reach the same power, due to being a more efficient engine. Three engines, same power, very different pressure ratios/PSI requirements. I guess my point is that it seems as though YOUR point is that this system allows you to run a much larger compressor/smaller turbine (much more offset than the typical T3/T4). And I'm saying that by what I'm seeing on load calculations that you'll be well into surge territory under normal wastegate control (duh, I think we've covered that, thanks for your patience with me ). So in this system you dump the excess air the compressor is making at lower RPM (or any for that matter) to get it back into stable region of the map, but what I'm asking is "won't that be a low efficiency area of the map?" and "would you want to vent MORE air to create MORE flow through the compressor to FORCE it into the better region of the map?" I think that make sense. And honestly, based on the dyno in that other thread, I think by ramping up the boost gradually like they (electromotive) did, they're staying in a good area of the map anyways. They're obviously not shooting for JUST past the surge point at 4,000RPM. Though we don't have a compressor map for the turbo they used, so it's hard to guess that kind of stuff. PS On a side note I was looking through pictures of the F1 turbo systems back from the 80's and I saw on several of them obvious speed sensor devices. What I didn't expect was the pre-turbo throttle bodies. From some reading it looks like they were used in tandem with a regular throttle body usually to keep idle speed of the turbo higher. Interesting alternative to the modern conventional BOV.
Back to maps... So, in theory, with a system that's controlling flow through BOV control, can we program the BOV to not just blow off enough to prevent surge, but allow enough flow to let the compressor follow it's most effient path? (as long as pressure ratio request are met according the the PSI/RPM targets. Because we can set a target load line like this: http://www.squirrelpf.com/turbocalc/graph.php?version=4&pr0=1&pr1=1.07&pr2=1.78&pr3=2.5&pr4=2.5&pr5=2.5&pr6=2.5&pr7=2.5&airflow0=3.1&airflow1=3.1&airflow2=8.2&airflow3=15.7&airflow4=29.7&airflow5=42.4&airflow6=44.6&airflow7=46.2&product_id=42 So for this plot, it looks like 98,000rpm would be a good limit for the turbine. Then the BOV will be opening enough to make up the difference between the load line and where we want the compressor to end up. So say at the 1.5 pressure ratio, the engine would be at an estimated 6 lb/min of flow (for theory sake, i don't actually know), and then the BOV would be flowing around another 6lb/m to get past the surge line. What I'm still not quite understand is where the PSI the engine will see is actually going to end up. The engine will only "breathe" so much, hence the surge issues, but I'm assuming that if we vent JUST ENOUGH to bring the turbo out of surge range, then that will give us the MOST available PSI for the engine. If we were to vent MORE than needed to get into operable range for the compressor, then we'd be sacrificing more air than needed, thus also available usable PSI for the engine, right?
You know Tony, I'm VERY SORRY, but I hadn't read that sticky... Before that last post I'd just read 3 articles on surge, and you explained it better than all three COMBINED!!! Serious lack of UNDERSTANDING out there... One article was even from garrett's website and was just plain poorly written and not expansive enough. I see now that I was thinking of it reversed. Thank you. I can understand how people (and OEM'S) have stuck with a pure wastegate control for simplicity, but I'm seeing that now as a very sad reality. We have companies like nissan and BMW with throttles that are only used in warm up and then total valve timing control for "throttle change". This is only about a thousand times more complex than the BOV turbo pressure control we're talking about here. I'm also kinda lost as to why the OEM's don't do this since it would allow them to use a SMALLER hot side allowing some cost saving on materials, and also a smaller package. Seems like everything they're normally after.
I'm having ah ha moments, while creating more questions/problems for myself. I feel like I don't understand turbos at all anymore. It's one thing to understand the concept of how they work, it's another entirely to KNOW what's going to happens in a certain situation. Load created Compressor Surge = When the engine is requesting more air than the compressor is actually able to give, correct? This is why if your compressor is too large for your application at lower RPM if you full throttle it your compressor isn't up to speed yet and you hit the surge limit. The engine is suddenly drawing more air than the turbo has to give, now you have flow separation. Throttle change Compressor Surge = When the throttle is rapidly shut under boost conditions, causing air to reverse and force air back to the compressor, causing the compressor to be pushing against an "unmovable object" if you're thinking about it in fluid dynamics (I think) Now, I'm understanding (I think) why you don't need a second BOV. I believe this is because your BOV won't suddenly "close" or "open" just because you closed the throttle. But if you're at a peak PSI for a given RPM and you slam the throttle shut, the PSI will increase as your RPM's are dropping, and this will throw your BOV into an area of the map that it'll open anyways... correct? And for surge line following.... I'm thinking that in order to prevent surge, accord to how it's programmed, you'd be OPENING the BOV to let air IN if you're in surge terretory. IE: You're at 1000rpm in 5th gear and you opened the throttle to WOT. This would allow air into the engine bypassing the turbo acting as a restriction at this point, and then using that exhausted air to spool the turbo. Once the turbo is into non-surge area it will be creating PSI and the BOV will close to follow your requested PSI/RPM data. Looking back at the dyno you posted in the other thread, I believe they could have had full PSI much sooner, but they've tapered it the way they have in order to make the power more usable and come on smoother.
In most cases that I'm aware of, yes. Though there's many different block variants so I can't say they all swap with any real certainty.
i think MOST people were buying them "after the group buy" and where getting the group buy price. I think at this point it's more like "mention hybridZ and get a promo rate". It's been like 2 years now and he's still giving out the group buy price. Awesome guy if you ask me, despite the issues people have had at times getting a hold of him. He's never taken money and not delivered, and he's quite to ship out once he's got the money.
the Lincoln Mark 8, continental, mark 8 lsc, and aviator had DOHC mod motors,
Their classes seem pretty decently prices too. Too bad they're a solid hour and a half drive away. I wonder if there's anyone like them up in the sac area. I've actually considered trying to get in for classes at a school like Davis just for machine shop access, though that's a mighty expensive route to go.
So I'm back at it again!!! I'm working in solidworks this time around, and might even be able to manage some ghetto flow analyses going (I'm not nearly as versed as some like MONZTER on here). What got me back on this old idea of mine was that the more I learned about force induction systems the more I realize that runner length doesn't matter nearly as much as runner diameter. Sure in a NA trim length can have a huge impact, but when the intake is pressurized there isn't the same limitations when you're running on vacuum. I'll have to scan or take a pic of the intake dyno I referred o earlier in my last post a year and a half ago, but it's amazing how much better a short runner tunned for the 4th or 5th wave actually works in practice. Sure the 4th or 5th wave might not be as strong, but it has a much more even response between the waves and allows a much broader range of flow. A long runner tuned for the 2nd or 3rd harmonic has VERY strong harmonics, but their overall performance gets sacrificed greatly. You can really "see" how long OEM runners kill top end power in truck V8's and similar applications. Anyhoot, another reason I'm looking into this again is that I'm expecting to go E85 in the future, and plan on running NO intercooler. My plan is to actually find a way to run the intake piping from the compressor UNDER the engine and up towards the intake plenum, running a design similar to the last one posted with a throttle body in the middle. I'll probably have a similar air comb system as in that design but done a little differently. My estimated costs this time around are probably a bit more realistic at around $500, and that's if I can get some next to free time on a mill. We'll see if I can pull that one off. As people like MONZTER have said in other threads, doing one off machine work without cheap CNC access just doesn't make financial sense. It really is the key in doing DIY stuff like manifold flanges if you're just making it for yourself alone. Plans for the oil cap will be to move it between cylinders 3 and 4, and I will definitely be using a quick disconnect system, probably using heavy rubber with clamps. I figure if it's good enough for OEM's like BMW and Mercedes then it should be good enough for me if I engineer it right. This will require solid mounting on BOTH sides that basically get the runners within 1/16th of an inch or less and let the rubber at as a seal only, not a part of the runner. Same concept as quality intercooler piping really. Silicone couplers are NOT for getting pipes to meet to each other. I'll have some renders probably in about a month or so. I'm gonna wait until I at least get to where I was at before, which will take some time to build back up to. So far I've got a rough sketch of the flange and the runner.
Yea I was thinking that a compressor with a map that looked more like a squat pumpkin would be much easier to use in a control scheme like this. From what I'm understanding, it wouldn't be hard at all to program in a map to do this on megasquirt. It's just a basic table, same as spark or fuel. You have to big variables, speed and speed (opposed to speed and load for fuel) and a map that tells the ECU where to aim the wastegate. The complicated part is that you need TWO new tables. One for Wastegate control of the turbo and one for BOV control. I'm not exactly sure MS has enough room for that, I'll look into it though. As stated before, might be possible with some custom scripting done to the source code. Oh, and I'd been thinking about this... the BOV that's venting for a target PSI, being control by the ECU, can it also act as the BOV for when the throttle plate gets closed during shifts and coast down? I'd think you'd need a separate BOV just controlled by the manifold vacuum.
What I'm still not quite getting though tony, is that isn't the optimal speed for a turbo variable based upon the pressure ratio it's up against and also the air that's actually flowing? I thought that was kinda the point of a compressor map, so you can see if you engine will land the turbo in an efficient range. It does seem though that in theory by running high boost at the bottom and then tapering it back down at the top you actually STAY in the peak area of efficiency of the turbo easier.
So let's see if I understand this... at least kind of, as it comes to application. The more I've looked at compressor maps over the years the more I think I don't quite understand them completely. I think I grasp what it's displaying, but it seems like in application your load lines your draw won't be followed. They seem more like just a guess to where you'll end up. So according to this map/load line here: Compressor Picture Based on this config here (which might not be accurate volumetric efficiency for a relatively stock L28ET Config Now, according to the map, if the wastegate is fully closed I'll make 17psi by 2k. Sounds reasonable. But because these load lines are figured for wastegate control on the hot side, it says i'll be going way past the efficiency peak of the turbo by redline. BUT, if I'm controlling excess then I can make the turbo follow the "island" in the middle of the map, increasing RPM and pressure ratio as I reach redline, then vent the excess on the cold side, right? All that being said, that's WAY more turbo than you'd need for a meek 350hp on a stock L28ET. People have made 300 wheel on stock T3's, showing that a GT35 should be more than capable to blow up the stock bottom end.
It's also a pain to fit a BBF into a 65' stang, yet it fits quite nicely in a Z... The SOHC shouldn't have an issue fitting on the width. The Lincoln DOHC fits, so you're fine. Any fitment issues you'll have will be related to exhaust/steering and belly/x-member. From the looks of the fitments I've seen you'll have some clearance issues on the firewall that require the motor to sit forward a little, but it'll fit.
Thanks for the clarification Tony. That's along the lines that I was thinking as to why it would still be referred to as a BOV. Next question, or ponder. I'd assume there wouldn't be anything wrong with venting the air back into the inlet of the turbo, right? If anything I'd assume that'd actually be a GOOD thing helping the turbo to continue to spool easily and prevent compressor surge. So knowing what you know, do you foresee any issues getting megasquirt to control a system like this? I personally don't see any issues, just concerned I'll have to write a new version with the code for the loop. I must say I think I grasp that area under the curve is much better and important than peak numbers and making power where your gears can't utilize it. Obviously you still need some raw HP figures otherwise you have a torque only big rig that's mostly just useful for towing things and needs tons of gears to make use of that power. But we should all know and understand this. But that being said I'd rather have a 225hp V8 that makes peak torque more than 3k rpm bellow peak HP, than a 240hp NA 4 cylinder that makes peak torque about 2k before peak HP.
I didn't get into this in my last post but they're also obviously not setting their boost control method, whichever it may be, to max boost as early as possible, making the torque curve more tame down low. You can see it make it's jumps which leads me to think they would otherwise have problems keeping the engine controllable if they just fed it as much boost as the turbo was making.
Well turbos don't spool like that boost plot, so the boost HAS to be controlled through a BOV control like you're talking about. I'm curious to know how it's being actuated though. Because those steps in boost look like they're being electronically controlled the way they spike and then taper down. It looks the same the way an electronic boost controller usually can't quite hold boost at or bellow peak right as it opens. But the front of the ramp is completely different than an electronically controlled wastegate turbo control, especially for those power levels. Thank you for the insight though Tony. You da' man. It seems that controlling the turbo with a basic loop with a speed sensor is easy as cake! And upon a basic google search I found this - http://www.turbobygarrett.com/turbobygarrett/products/Accessories_continue_speed_sensor.html Seems like there might be others that agree with this form of turbo control.... surprise... A total side note, for arguments sake (which doesn't mean I disagree, just want clarification). Should we really be calling a BOV when it's being used for venting excess charge a BOV? Seesm like a Pop-off valve might be more accurate in this instance.
The new coyote is already proving capable of more power than the 5.4 GT motor. The heads flow MORE in a SMALLER package. Rebuild with SVT H bream rods and slightly lower compression pistons and I'm SURE that's a 1000hp engine. The block is a stronger design than the GT block too. Crank is better engineered imo. They'll be much more affordable in time as well. I'm not saying the GT motor isn't awesome, just that Ford really outdid themselves with the new 5.0
I find it SO funny that people bad talk the OHC ford motors so much. I've done it myself from time to time, but what it still comes down to for me is one big factor. Potential potential potential. Sure you CAN get a DART block 302 and make 600hp, but there's been many more blown 302 blocks at a mere 500hp than mod motors. It's much more solid platform, and what makes the 302 super-light weight it takes back in potential. The 302 is the best motor for getting an easy 300 wheel hp for sure. But a lincoln DOHC 4.6 can also make 300hp, and without changing many parts. For the 302 you'll most likely need decent heads, a cam, upper/lower intake, and tuning the sucker with something like megasquirt or tweecer. The mod motor will also need to be tuned, but just opening up the exhaust and intake, coupled with some other basic work will get you into the same HP range. Even the crappiest DOHC heads flow decently well, and have HUGE potential still with port work. And they're NOT as heavy as some people like to imagine. Sure they're BIG, but they're not THAT heavy. I'd argue it's better for weight and distribution of it compared to any of the modern DOHC inline 6 motors, which are common swaps on this site and highly drooled over... Read my lips (over the internet). The 302 isn't BAD, the RB and 2JZ aren't BAD, and the 4.6 isn't BAD either. Application application application application application. Past that it's preference. I say AWESOME, I'm GLAD to see another 4.6 swap in progress. Oh, and I bet you CAN fit the 5.4 liter. It'd just take a dry sump system and maybe some engine bay massaging.
Well I'm glad it was brought back up. Because I've been thinking about what you've been saying in regards to turbine speed/boost control in this thread tony and I'm still somewhat unclear on some things. What were you using to control the wastegate's movement? Was it basically a map based on the max flow of the engine at full RPM? If so how is part throttle flow calculated. Seems like this would be a serious headache to figure out, or is it just some basic tuning time to figure out? It makes sense that if you had a speed sensor on the turbine shaft that this is all an EASY thing to figure out. Just find the optimal RPM for the turbo and run the wastegate against that. You could even log the positioning and then make a map to follow to keep from any possible "control jitter" from happening. But without any way to tell what speed the turbo is really at it seems like it would be a challenge to tune. Also, how was this setup on the street? I'd image since you said it was akin to a supercharger setup, that it was quite tame if you kept your foot out of it, but had instant power with full throttle anything close to boost threshold, which was insanely low. I'd love to try this out on my car, and maybe even my friend's STI, since he hasn't been so happy with how hard boost comes on with just the stock electronic wastegate control. Adding a boost LEAK with a manual controller helped, but he's obviously loosing some threshold. But it makes it much more livable on the street. It doesn't help that he's a lead foot and knows it, but I think if he had more control like you have in a supercharged setup he'd be much happier overall. And he's certainly not going to be turning his boost DOWN anytime soon. He's hoping to get close to some records when it comes to using the stock turbo on a STI.
So tony, what coil-overs do I need for my car again? I honestly get his point though it took me several years to really take this concept to heart. We have so many threads of people asking "which engine should I go with" and "my stock brakes suck, where can I get some brembo's for my car?" These are questions that tell more about the person asking than we could possibly give them back in information. They don't really know what they're looking for and the best a good samaritan could do would be to point them towards finding the right question. Like the whole injector question. The real answer is that you can put as many injectors just about wherever you want and be ok. It's all in how you want to tune that system. For quite some time companies got away with basic throttle body injection on V8 engines. Sure it sucked like hell, but the problem wasn't in the inherent concept, but the way it was applied. So even in those cases someone might say "TBI sucks" showing their ignorance, because the idea doesn't suck, how it's been done sucks in many cases. A community can only be as strong as their communication allows them to be. If we fail to learn how to communicate then what we're doing here is pointless. Go hand around some serious F1 forums and you'll find many debates on how to use words and what their definitions should be. Because if we can't use words that mean the same thing to everyone then they're pointless. This thread has had some of the most spoon fed info I've ever seen from Tony, which is actually high praise that he's that interested in responding... Tony has more experience than many of us will ever come close to comprehending, and his advice and explanations shouldn't be taken lightly. That's not to say lift him up like a god or something. We have MANY people that are members here that are like Tony, which is why newcomers need to be so careful at times. Posting here is like getting to speak and ask questions at a panel discussion with race teams. Know your subject matter BEFORE standing up and making a fool of yourself. I say all this because I learned the hard way myself. Go back and read some of my earlier posts. I've been an utter newt at times.
L28 injector spacing & port dimensions
Gollum replied to Ferrariferg's topic in Fabrication / Welding
You have no idea how beautiful that is to me right now. Thank you so much ron. It's now save on my PC FOREVER!!! Muwahaha!
